    the worst corexz conveyor belt printer i've ever built
    My Duet controlled machine
    1.0k
    • planeguyundefined
      planeguy
      the worst printer
      It's the worst 3d printer i've ever built and designed. It's the first one, so there's that. A slanted-conveyor-belt-bed dealie. 🙂
      I wanted a proper z-probe down to the bed, so I set the duet to CoreXZ and set the conveyor as the Y axis. Blackbelt Cura will do the an angled slices and the whole conveyor-belt thing really well, but it assumes the bed is Z. I uses the post-processor in Cura to swap all the Ys and Zs in the G-code and it worked mostly!
      There's definitely some adjustment to do: Z is a little out of wack, leaning hard towards the front of the machine, and there's no on-board print cooling (hence the old case fan in the back). Honestly I was worried I was just going to get spaghetti instead of a kind-of-successful-conveyor-belt-stunt-print (the calicat's hollow inside).
      Thanks to the forum members who helped me out by replying to my idiotposting or just helping out others and popping up in searches!
        That's cool. I'd love to see it in action.
        planeguyundefined 1 Reply Last reply Reply Quote 0
        • planeguyundefined
          planeguy @Phaedrux
          @phaedrux said in the worst corexz conveyor belt printer i've ever built:
          i put together a vidjeo of that print: https://youtu.be/4sQmJCS3lQg
          since then I figured out a good chunk of my issues were due to not properly setting the conveyor belt steps/mm.
          • devleonundefined
            devleon
            Cool stuff. Did you design this yourself or is it based on something and is there a build guide?
            • planeguyundefined
              planeguy
              Self-designed with inspiration from Bill Steele's work, the Printrbelt, and Zechy's build. I'm working on writing some stuff up but nothing yet. I wasn't even sure if was gonna work! 😬
