    Unable to run Gcodes from Estlcam in Web control
    Duet Web Control
    2.9k
      deckingman
      Are those files really OK? I know nothing about CNC so please forgive my ignorance but it looks like "G03 X00.162 Y00.215 I00.004 J-00.009 F01.200" is commanding movement for X, Y, I and J axes yet X,Y U and V are what are in config.g. And feed rate of 01.200?
        dc42 administrators @deckingman
        @deckingman said in Unable to run Gcodes from Estlcam in Web control:
        In G2 and G3 commands, the I and J parameters specify the relative XY coordinates of the centre of the arc.
        EDIT: I agree that a feed rate of 1.02mm/min looks low, even for a CNC machine. And I've just remembered that the default minimum feedrate in RRF is 0.5mm/sec i.e. 30mm/min.
          deckingman @dc42
          @dc42 Ahh OK. - Thanks.
          • 3DRikatundefined
            3DRikat
            ; homey.g
            ; called to home the Y axis
            ; generated by RepRapFirmware Configuration Tool v2 on Sat Mar 09 2019 22:37:11 GMT+0100 (Mitteleuropäische Normalzeit)
            M584 Y1 P5; split y axis
            G1 S1 Y-730 V-730 F500 ; move quickly to X and Y axis endstops and stop there (first pass)
            G1 Y3 V3 F500 ; go back a few mm
            G1 S1 Y-730 V-730 F150 ; move slowly to X and Y axis endstops once more (second pass)
            M584 Y1:3 P3 ; join y axis
            G90 ; absolute positioning
            ; homex.g
            ; called to home the X axis
            M584 X0 P5; split x axis
            G1 S1 X-730 U-730 F500 ; move quickly to X and Y axis endstops and stop there (first pass)
            G1 X3 U3 F500 ; go back a few mm
            G1 S1 X-730 U-730 F150 ; move slowly to X and Y axis endstops once more (second pass)
            M584 X0:4 P3 ; join x axis
            I home Z with G92 Z0, because I have no endstop on Z.
              There are some errors in your homing files, although I am not sure they are the cause of the problem. I suggest the following (changes in bold). After making these changes, if it still doesn't work, please check whether you can jog the printer using the jog buttons in Duet web Control, after you have homed it.
              ; homey.g
              G91
              G1 S1 Y-740 V-740 F500 ; move quickly to X and Y axis endstops and stop there (first pass)
              G1 S1 Y-10 V-10 F150 ; move slowly to X and Y axis endstops once more (second pass)
              ; homex.g
              G91
              G1 S1 X-740 U-740 F500 ; move quickly to X and Y axis endstops and stop there (first pass)
              G1 S1 X-10 U-10 F150 ; move slowly to X and Y axis endstops once more (second pass)
              • 3DRikatundefined
                3DRikat
                I changed the home files for X and Y with your values. Everything works like before. I can home and jog it after homing. What else can I do?
                Edit: At some point the Z axis rises unreasonably high and I get the error message "G0/G1 outside machine limits".
                  I'll run those files on my bench system. Which firmware version are you running? Send M115 to check.
                  • 3DRikatundefined
                    3DRikat
                    Thank you. Here's the firmware:
                    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03beta2
                      I've just run your config.g file, homing files (with my changes) and print file on my bench system. I didn't see any error messages or large Z movements. But the job completed very quickly.
                      I notice that the movement amounts in the GCode print file are tiny. I've already commented on the very low feed rate. Are the units supposed to be inches instead of mm? I tried inserting G20 at the start and G21 at the end, so that the values would be interpreted as inches, and the job took around a minute.
                      • 3DRikatundefined
                        3DRikat
                        The print file was from yesterday. I think Estlcam wasn't setup correctly, but now it should be. I just want to test something, to see if it works and then finetune from there. First I want to draw this picture with a pen to see if its square and later I want to try it with the spindle:Estlcam
                        Maybe you could try the new test file:
                        ;Project test
                        ;Created by Estlcam version 11 build 11,105
                        ;Machining time about 00:03:30 hours
                        G90
                        G00 X0.0000 Y0.0000 Z0.0000
                        G00 Z5.0000
                        ;No. 1: Gravur 1
                        G00 X100.0000 Y100.0000
                        G01 Z-0.0100 F1200 S1
                        G01 Y363.9995
                        G01 X364.0001
                        G01 Y100.0000
                        G01 X100.0000
                        ;No. 2: Gravur 6
                        G00 X100.0000 Y231.9997
                        G00 Z0.5000
                        G01 Z-0.0100 F1200
                        G01 X364.0001
                        ;No. 3: Gravur 5
                        G00 X217.2431 Y248.3160
                        G01 Z-0.0100 F1200
                        G02 X253.5093 Y236.6217 I14.7572 J-16.3163
                        G02 X225.2486 Y211.0614 I-21.5090 J-4.6220
                        G02 X217.2431 Y248.3160 I6.7517 J20.9383
                        ;No. 4: Gravur 4
                        G00 X206.4779 Y267.8410 Z5.0000
                        G00 Z0.5000
                        G01 Z-0.0100 F1200
                        G02 X275.8010 Y236.1822 I25.5225 J-35.8413
                        G02 X213.7221 Y191.9760 I-43.8007 J-4.1825
                        G02 X206.4779 Y267.8410 I18.2782 J40.0237
                        G00 Z5.0000
                        ;No. 5: Gravur 3
                        G00 X169.7751 Y294.2244 Z5.0000
                        G00 Z0.5000
                        G01 Z-0.0100 F1200
                        G02 X317.0017 Y254.7751 I62.2253 J-62.2253
                        G02 X209.2243 Y146.9978 I-85.0013 J-22.7760
                        G02 X169.7751 Y294.2244 I22.7760 J85.0013
                        G00 Z5.0000
                        ;No. 6: Gravur 2
                        G00 X129.6062 Y315.3036 Z5.0000
                        G00 Z0.5000
                        G01 Z-0.0100 F1200
                        G02 X355.3407 Y279.0238 I102.3942 J-83.3038
                        G02 X211.0542 Y101.6719 I-123.3403 J-47.0240
                        G02 X129.6062 Y315.3036 I20.9462 J130.3279
                        G00 Z5.0000
                        ;No. 7: Gravur 7
                        G00 X232.0004 Y363.9995 Z5.0000
                        G00 Z0.5000
                        G01 Z-0.0100 F1200
                        G01 Y100.0486
                        G00 Z5.0000
                        G00 X0.0000 Y0.0000
                        Edit: After the outer square is done the Z axis rises unreasonably high and I get the error message "G0/G1 outside machine limits".
                          dc42 administrators @3DRikat
                          I now get "Error: G0/G1: outside machine limits". The reason is this line:
                          This commands Z to -0.01 which is below the limit of 0 set by your M208 S1 command. If I send M208 S1 Z-1 before I run the job, then it continues at that point.
                          When it fails, I don't see a Z movement to a high value. Do you have a cancel.g or stop.g file that might be commanding that movement?
                          • 3DRikatundefined
                            3DRikat
                            I already tryed to change the M208 command to: M208 X0 Y0 Z-100 U0 V0 S1, but it doesn't help.
                            This is cancel.g:
                            ; stop.g
                            ; called when a print is cancelled after a pause.
                            This is stop.g:
                            ; stop.g
                            ; called when M0 (Stop) is run (e.g. when a print from SD card is cancelled)
                            ; generated by RepRapFirmware Configuration Tool v2 on Sat Mar 09 2019 22:37:11 GMT+0100 (Mitteleuropäische >Normalzeit)
                            Do you have any other idea what it could be?
                              @3drikat said in Unable to run Gcodes from Estlcam in Web control:
                              Are you saying that with that change, it still gives the "outside machine limits" error? It doesn't on my bench system, when I use Z-1 where you have used Z-100. Did you allow the machine to restart after you saved this change to config.g?
                              3DRikatundefined 1 Reply Last reply Reply Quote 0
                              • 3DRikatundefined
                                3DRikat @dc42
                                @dc42 yes still the same error with either Z-1 or Z-100 and I restarted everytime I changed something in the config.g.
                                  That is odd, the whole file works for me. Please try the following:
                                  1. Send M208 without parameters, and check that the Z minimum is reported as -100 or whatever you have set it to.
                                  2. Try entering the lines of your print one at a time into the GCode Console and see which one is failing.
                                  • 3DRikatundefined
                                    3DRikat
                                    @dc42 said in Unable to run Gcodes from Estlcam in Web control:
                                    M208
                                    Axis limits X0.0:731.0, Y0.0:731.0, Z-1.0:108.0, U0.0:731.0, V0.0:731.0
                                    Looks fine to me
                                    1. Try entering the lines of your print one at a time into the GCode Console and see which one is failing.
                                    ;Project test
                                    G90
                                    G00 Z5.0000
                                    ;No. 1: Gravur 1
                                    G00 Z0.5000
                                    G01 Y363.9995
                                    G01 X364.0001
                                    G01 Y100.0000
                                    G01 X100.0000
                                    G00 Z5.0000
                                    The error appears in the bold line. The Z axis rises unreasonably high and I have to stop with the emergency stop button.
                                      • In your M92 command you specified 200 steps/mm @ x16 microstepping. Is that correct?
                                      • If you send M92 without parameters, does it report that the Z steps/mm is 200?
                                      • If you use the jog buttons to jog Z up 5mm, does it rise the correct amount?
                                      • 3DRikatundefined
                                        3DRikat @dc42
                                        Changed it to 400 steps/mm (T8 screw)
                                        Steps/mm: X: 100.000, Y: 100.000, Z: 400.000, U: 100.000, V: 100.000, E: 420.000:420.000
                                        Yes, I measured the correct amount with my digital caliper. The difference is only 0,01mm.
                                        • radiomodellundefined
                                          radiomodell
                                          @3DRikat Please try to use a work piece coordinate system. If you generated G-code with a Z-axis zero position at work piece upper surface, Z-axis will move outside machine limits when the tool dives into the material. Same can happen if your cad design touches X- or Y Axis zero in Estlcam and you add cutter radius compensation. Toolpath will be outside machine limits.
                                          I used following G-code: G10 L2 P2 X5 Y5 Z25 to select 2nd coordinate system and activated it with G55.
                                          • 3DRikatundefined
                                            3DRikat @radiomodell
                                            @radiomodell I tryed it but it was just like before. After the outer square is done the Z axis rises and I have to stop it. There's the error message "outside machine limits".
                                            I really don't know why the Z axis rises so high.
