    Flakey Behaviour from Duex 5
    1.4k
    • DougJonesundefined
      DougJones
      Background Info:
      I've have the Duet Ethernet Duex 5 setup running for many months. This on my bigger printer, so I don't run it a bunch, but enough to know it was functioning fine. I was cleaning up the electrical panel a few days ago (adding some cooling fans to the boards because I was getting temp warning from the drivers and removing some unused hardware). In cleaning up the panel, I removed the Duet and Duex to remount them on some tall standoffs to get better airflow underneath the boards. I had also intermittently had issues with the ethernet module not starting (very intermittently maybe once or twice in the last few months, usually a power cycle or two would resolve the issue.
      Once I restarted after cleaning up the panel, I have had some really flakey results from the system. I struggled for about 2 hours trying to get the ethernet working, I finally pulled the module and re-seated it and that seams to have done the trick. The only mistake I made was I connected a thermistor to the always on fan, thinking it was a fan. I blew the thermistor. After it was replaced, no issue, temp reads fine.
      The Problem:
      • Sometimes the board powers up and does not recognize the Duex. Under the settings screen, it does not say Duet Ethernet + Duex 5, just Duet Ethernet. A power cycle or two and unit will detect the Duex again. I cannot seem to get it to reliably detect the Duex. I have replaced the ribbon cable with a new one. Seemingly no change to the problem. Sometimes it is detected, sometimes not.
      • The endstop for E2_Stop is not changing state. Although the lights on the board are changing state, the settings screen is not showing the endstop as changing state. This is when the Duex is being detected. The drivers on the Duex are functioning and the temp inputs on the Duex are working properly.
      • I was having issues with my V and W Axis homing as the drives were not moving, but I think this was because the Duex was not being detected properly.
      • The thermostatic control on the extruders is no longer working reliably. The fans on the 2 extruders on the main board (Duet Ethernet) are set to run once the hotend gets above 45deg C. This keeps the unit from making a bunch of noise in my office when it is not actively printing. Now, once the temp gets above 45 degrees, they turn on, but only for a few minutes and then cut out even though the temp is 245 deg. I have checked the meter going back to the board and no power from the board.
      I am concerned that I have damaged the electronics in some way. I have ordered a new Duet and Duex5 last night. I have another printer that I would like to convert to these electronics. So, not a waste if the issue on the current ones can be resolved.
        Do you have a short thick wire directly between the ground sides of the VIN terminals of the Duet and DueX, as instructed in the DueX wiring instructions? This is vital.
        I am surprised the you blew a thermistor by connecting it to a fan output. The thermistors used in 3D printers normally have a resistance of 100K or more at room temperature, and should easily survive 24V.
          DougJones
          Well I actually blew 3 of them trying to test different fan outputs before I realized that I had the wrong plug.
          I had originally run the separate power from the din rail fuse holder to each of the Duet and the Duex, likewise the ground were run separately to a din rail mount terminal strip (about 500mm away). In troubleshooting over the last couple days, I saw the wiki about wiring them together. I fixed it last night as per the wiki, but no change in the results. Could having it the boards connected incorrectly have permanently damaged either of the boards?
            dc42 administrators @DougJones
            @dougjones said in Flakey Behaviour from Duex 5:
            If the DueX is sometimes recognised and sometimes not, I think it's unlikely that this is due to damage, although not impossible. OTOH having separate ground wires from the PSU to the Due and DueX is known to cause problems, especially after motors connected to either board have been energised.
            Which firmware version are you using? I made a change a few versions ago made to increase the reliability with which the DueX was detected at power up.
              DougJones
              Firmware version 2.02 RC2
              web version 1.22.3
                DougJones
                I have upgraded to 2.02 (RTOS) and Web Version 1.22.6 and still have the same problem.
                E2_STP is not being seen by the board. The light on the board is changing state, but the screen under Settings->Machine Settings is not changing state when I move my carriage over and back.
                  Is it just E2_STP not working, or all of the DueX endstop inputs? Are the DueX fans working?
                    DougJones
                    I appears to be all the end stops on and the fan outputs on the Duex. I confirmed the sensors used and fans used to test work on the Duet. I used M106 and M107 to turn the fans on and off on fan 0 then moved that fan to fan 7 and 8 and could not get them to turn on.
                    The endstops are working on the main board and then moved to the Duex and the lights come on on the board, but the state does not change on the Settings page on the web interface.
                    The 3 extruder fans that are acting up are also on the Duex (not on the main board).
                    So I am gathering that I have a Duex that is goosed, correct? But the main board seems to be functioning properly.
                      If it doesn't recognise the DueX then the DueX endstops and fans will not work.
                        DougJones
                        When it does connect, This is happening.
                        The stepper drivers appear to work thermister inputs work. The Endstops and Fan outputs do not seem to be working.
                          That indicates that I2C comms between the Duet and the DueX has broken down, even though it must have been working well enough when the DueX was recognised at startup. If you run M122, I expect you will see a lot of I2C errors reported.
                            DougJones
                            I cannot seem to get the Duet to reliably start. Meaning, the red diag led by the ethernet just blinks and I cannot connect to the web interface.
                            When it does start sometimes it finds the duex 5 board and sometimes not.
                            When the board is found it almost never shows the endstops changing state.
                            That said, after a whole lot of screwing around tonight, removing and re-seating connectors, checking contacts and replacing cables. I got it to all connect properly and the drivers were working, endstops functioning, I even homed the machine. I re-taught my z-probe height (un-related by i had removed my bracket and needed to reset zero position).
                            Everything was grand, decided to power cycle the machine again and double-check to make sure I had fixed it. And nope, same set of problems, won't detect Duex or devices on Duex won't respond.
                            I checked M122 and am getting nak errors. No other IIC errors reported.
                              Possible causes:
                              • Power supply problem
                              • Problem reading the SD card
                              • The blinking LED could indicate that the Duet is in a reboot loop. Next time you succeed in starting it, run M122 and check the software reset data.
                                DougJones
                                I have replaced the Duex5 and the unit fired up the first time.
                                See below for reset details from M122.
                                Software reset code 0x4033 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x0041f803 BFAR 0x43910046 SP 0x2000464c Task 0x4e49414d
                                Stack: 00420831 00421220 21000000 20000168 200001c8 20004954 00000000 0000008d 20013da0 a5a5a5a5 00452ff7 200001c8 00000000 0000000a 00000035 2000ac10 004236cf 2000ac10 20004954 00000000 2000ac10 20009aa8 2000ac10
                                  DougJones
                                  Update: I rebooted and the unit would not restart. The red Diag light just blinked. It took me 10 power cycles before the controller would boot properly and I could re-connect to the web interface.
                                  Note that all the power leds come on but no interface lights on the rJ45 connector.
                                  I have received a new Duet Wifi and I am going to pull this board off the machine and set it up on the bench until I can figure out what is wrong.
                                    DougJones
                                    Update:
                                    I have removed the Duet Ethernet and put in a brand new Duet Wifi. Everything seems to go fine, until I put in my config file. I could not get the web interface to start, similar to the previous board after I copied my old config files over. So, I wiped the config file down to basics and added line by line the config file items and traced the problem down to the chamber heater.
                                    If I leave the code below out, the system boots up just fine every time. If it is included, it fails to boot. This doesn't seem like it should be an issue, but I have confirmed the problem about a dozen times. I can't see what about the chamber heater code could be the problem. Note: my chamber heater is a little underpowered, hence the long D value for the M307 settings. This was not previously a problem on prior firmware versions.
                                    This new wifi board is 2.02 (RTOS) out of the box I had recently upgraded the Ethernet board to 2.02 (RC2) and I am wondering if this explains some of the booting problems on both boards (granted, I might still have an I2C problem on either the old ethernet board/old duex5 board).
                                    By omitting the offending code below, everything seems to be running just fine. I've got the new unit powered up, homing and doing a small test print.
                                    What are your thoughts? I do need to get the chamber heater running again.
                                    ; Chamber Heater
                                    M141 H5                        ; heater 5 is the chamber heater
                                    M305 P5 R4700 T100000 B3950    ;heater 5 is monitored by a 100K thermistor with B=3950 and a 4.7K series resistor
                                    M307 H5 A21.5 C171.8  D60     ; Setup Heater PID Settings
                                    M307 H5 B1                    ; setup bang-bang control]
                                      It sounds like either a firmware bug or running out of memory. Please can you post the complete config.g file that makes it fail to boot.
                                      When the board failed to boot prior to you getting that software reset data report, which firmware version was it running?
                                        Scratch that, I've just found the bug in the chamber heater setup code. It will be fixed in the forthcoming 2.03beta3 release, which I am aiming to do later today.
                                        Thanks for your help in pinning this down. The software reset data you posted located the problem.
