    [SOLVED] Nozzle too low by 1mm after Z homing - any ideas?
    906
    • lowracerundefined
      lowracer
      UPDATE: Problem is SOLVED. Y Axis crossbar was out of joint.
      I have a new Duet Wifi installed as an Ultimaker 2+ upgrade.
      M115 reports: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.02(RTOS) ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-12-24b1.
      Authentic BLTouch classic is handling the Z axis homing & bed compensation, seems to work fine, got a few tree frogs here to prove it.
      ...Except that when a print starts, it starts with the nozzle desiring to go 1mm below(!) the bed surface.
      I have a workaround right now in that Simplify3D lets me raise that initial Z by 1mm in the gcode and I have a perfect first layer every time, but this is a Band-Aid. Would like to find out why this is happening and correct it. Any ideas?
      Here's the obligatory config.g:
      ; generated by RepRapFirmware Configuration Tool on Fri Mar 15 2019 21:53:32 GMT-0700 (Pacific Daylight Time)
      M555 P1 ; Set firmware compatibility to look like RepRapFirmare
      M550 PCharlie_Brown ; Set machine name
      M551 P[redacted] ; Set password
      M552 S1 ; Enable network
      M552 P192.168.1.125 ;
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S0 ; Drive 0 (X) goes backwards
      M569 P1 S1 ; Drive 1 (Y) goes forwards
      M569 P2 S0 ; Drive 2 (Z) goes backwards
      M569 P3 S1 ; Drive 3 (E0) goes forwards
      M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation
      M350 E16 I1 ; Configure microstepping with interpolation
      M92 X80 Y80 Z400 E537 ; Set steps per mm
      M566 X900 Y900 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
      M203 X18000 Y18000 Z980 E1200 ; Set maximum speeds (mm/min)
      M201 X500 Y500 Z500 E1000 ; Set accelerations (mm/s^2)
      M906 X1250 Y1250 Z1250 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S15 ; Set idle timeout
      M208 X223 Y223 Z205 S0 ; Set axis maxima
      M574 X1 Y2 S1 ; Set active high endstops
      M307 H3 A-1 C-1 D-1 ; release heater 3 for use by probe
      M558 P9 H5 F1200 T8000 ; https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
      ; explanation of M558 parameters: https://reprap.org/wiki/G-code#M558:_Set_Z_probe_type
      G31 X22 Y-21 Z1.582 P25 ; https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
      M574 Z1 S2 ; Set endstops controlled by probe
      M557 X15:208 Y15:208 S20 ; Define mesh grid
      M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
      M305 P0 X201 ; Configure thermocouple for heater 0 (Bed)
      M305 P1 X200 ; Configure thermocouple for heater 1 (Hotend)
      M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H-1 ; Set Case LEDS PWM signal inversion and frequency. Thermostatic control is turned off
      M563 P0 D0 H1 ; Define tool 0
      M501 ; https://forum.duet3d.com/topic/3055/having-trouble-setting-the-z-offset/6
        What do your homing files look like?
        • lowracerundefined
          lowracer
          Here's the homing macros:
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool on Fri Mar 15 2019 21:53:29 GMT-0700 (Pacific Daylight Time)
          G91 ; relative positioning
          G1 S1 X-228 Y228 F4800 ; move quickly to X and Y axis endstops and stop there (first pass) (was F1800)
          G1 X5 Y-5 F6000 ; go back a few mm
          G1 S1 X-228 Y228 F360 ; move slowly to X and Y axis endstops once more (second pass)
          G90 ; absolute positioning
          G1 X110 Y110 F7200 ; go to first probe point (approx center of bed)
          G1 S2 Z5 F100 ; lift Z relative to current position
          ; homex.g
          ; called to home the X axis
          G1 S1 X-228 F7200 ; move quickly to X axis endstop and stop there (first pass)
          G1 X5 F6000 ; go back a few mm
          G1 S1 X-228 F360 ; move slowly to X axis endstop once more (second pass)
          G1 Z-5 F6000 S2 ; lower Z again
          ; homey.g
          ; called to home the Y axis
          G1 S1 Y228 F7200 ; move quickly to Y axis endstop and stop there (first pass)
          G1 Y-5 F6000 ; go back a few mm
          G1 S1 Y228 F360 ; move slowly to Y axis endstop once more (second pass)
          ; homez.g
          ; called to home the Z axis
            Are you using any mesh grid compensation? Or automatic leveling?
            • lowracerundefined
              lowracer
              Yes, I have done the G29 to establish a height map file and load the resulting heightmap.csv from a startup script in Simplify3D:
              M907 E1000 ; BONDTECH Extruder Only
              G28 XY ;Home XY
              M561 ; Clear any bed transform that might be in place
              G1 X104.5 Y130 ; Move Probe to middle of bed
              G30 ; Do a single probe
              G29 S1; load heightmap
              G1 Z20.0 F6000 ; Move Z to 20
              G1 X20 Y10 F3000 ; bring extruder to front
              G92 E0 ; zero the extruded length
              G1 Z10 ; lower
              G1 E19 F200 ; purge nozzle quickly
              G1 E26 F60 ; purge nozzle slowly
              G92 E0 ; zero the extruded length again
              G1 E-5.5 F400 ; retract
              G1 X190 Z0 F9000 ; pull away filament
              G1 X210 F9000 ; wipe
              G1 Y20 F9000 ; wipe
              G1 E0 ; feed filament back
                Can you post an image of the height map?
                Does the Displayed z height say 1mm or does it indicate the set first layer height?
                • lowracerundefined
                  lowracer
                  I should also report that I have run this procedure (https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height) about twenty times, consistently coming up with very similar results around 1.6mm, and averaged these runs to come up with the value in the G31 command for Z offset.
                  Here's the screenshot of the heightmap:
                  Just started a print after having the machine turned off for a few hours. Z on first layer showed 1.08. It was printing about a millimeter too high. Removed the +1mm Z offset "band-aid" from the GCODE, and have got a perfect first layer. No idea why it is working now.
                  I appreciate the help. Will post up again if the problem recurs.
                  • Vetiundefined
                    Veti
                    @lowracer said in Nozzle too low by 1mm after Z homing - any ideas?:
                    change the z offset to increase by 1mm
                    G31 X22 Y-21 Z2.582 P25
                    lowracerundefined 1 Reply Last reply Reply Quote 0
                    • lowracerundefined
                      lowracer @Veti
                      @veti said in Nozzle too low by 1mm after Z homing - any ideas?:
                      First thing I tried. Didn't have any effect. The problem is solved, have done several prints all perfect first layer without any slicer adjustments.
                      I think what happened is that the crossbar that holds the Y axis in place had slipped out of joint, throwing the XY gantry out of level. Once I snapped that bar back in, no more problem. Going to mark this one solved. Thanks for the help everyone.
