    Firmware 1.16 released
    Firmware installation
    8
    23
    3.9k
      @terabyte:
      Thank you! Awesome! I hope that 1.17 will come just as fast:) Update went without a hitch! By the way does it make a difference which firmware should be uploaded first?
      DWC 1.13 won't work with RRF 1.15 and all beta and some RC versions of 1.16. So install DWC 1.13 last.
      I am aiming to do about one major firmware release a month but I am not promising it. I have other work scheduled too relating to ongoing development of the Duet WiFi product range.
      • W3DRKundefined
        W3DRK
        Hey David, you mentioned in the RC2 thread about the possibility of using "inverted PWM" with the new servo support/M280.
        Is it possible to enable inverted PWM on the heater channels when used for servos? According to the RepRep Gcode wiki, I only see that as being an option for the fan channels. Since my particular configuration is using a Duet 0.6 I don't have fan channels to spare, hence my need to use one of the surplus heater channels…
          Servo PWM inversion is completely separate from fan PWM inversion and works on all pins for which servo support is available. See http://reprap.org/wiki/G-code#M280:_Set_servo_position.
          • W3DRKundefined
            W3DRK
            Did you just update that document? Because I looked before posting my question and there was no mention of an I parameter for M280 at the time. I always RTFM before posting questions….
            In any event, it works! So BLTouch appears to be 3.3v tolerant.
            @dc42:
            • roboduetundefined
              roboduet
              @W3DRK:
              Did you just update that? Because I looked before posting my question and there was no mention of an I parameter at the time. I always RTFM before posting questions….
              You can see edit history here: http://reprap.org/mediawiki/index.php?title=G-code&diff=prev&oldid=177383
              • hackerundefined
                hacker
                Hey, what would be the easy way to find out (short of extracting the board from under the bed or reading through the diffs) what is the new P3? I mean, what was P3 (in terms of M42) before the upgrade is now what? I can't clean my nozzle without find that out 😉 I'm not sure the wiki reference helps much…
                  P3 was never officially supported because it is the I2C Data pin, now used to communicate with Duet expansion boards. Try another pin. For example, P60 = CS5 = physical pin 50 on the expansion connector.
                  • hackerundefined
                    hacker
                    @dc42:
                    Thanks! That means having to remove bed, but at least I know why now 😉
                    I tried to find what pins are officially supported, but IIRC all I found was "temporary" 0xff bitmask in "#if 1" block or something like that 😉
                    • hackerundefined
                      hacker
                      @dc42:
                      P60 doesn't seem to do anything to CS5, though P61 does affect E3_STOP, so I'm fine.
                      • hackerundefined
                        hacker
                        BTW, the wiki page about unused pins https://duet3d.com/wiki/Using_servos_and_controlling_unused_I/O_pins mentions M206 as a command to disable fan, which, I believe, is M106.
                          Thanks for pointing that out, I have corrected it.
                          • piankocundefined
                            piankoc
                            I tried upgrading all updates through the web interface and it didn't update. I then tried the alternate method and loaded the files into the /sys folder and connected to through USB. I updated the main firmware and the web controls but got an error on the Web server file saying the file was not found (even though it was there). I continued to try different files and it continued not to work. now when I try to log into the web interface I get an error. {"err": "404: / NOT FOUND"}
                            Any idea why the error is there? I am assuming it is because of the web server file not found issue. Any idea why the file cant be found? Or why I keep having trouble updating firmware through the web interface?
                              If it's a Duet WiFi then the DuetWebControl.bin hasn't installed correctly. Download DuetWebControl-1.13.bin, rename it to DuetWebControl.bin and copy it to the /sys folder on the SD card. Then put the SD card in the Duet, start and connect to the Duet, and send M997 S2 to install it. Installation takes several minutes, until the blue LED on the wifi module stops flashing.
                              • piankocundefined
                                piankoc
                                Sorry should have said that, yes it is a Duet WiFi. Ill check this when I get back home to see if it helps.
                                Thanks for the help!
                                • Russ Griesundefined
                                  Russ Gries
                                  on the http://reprap.org/wiki/G-code#M280:_Set_servo_position
                                  the Example is
                                  "Example
                                  M300 P1 S50 "
                                  its M280 right?
                                  I'm not sure if you guys can edit that… I'm sure you can.
                                  Fantastic work all!!!! just in time ! needed that servo functionality! 🙂
                                  ~Russ
                                  One Day At A Time…
                                  My Main Research Page:
                                  http://rwgresearch.com/open-projects/3d-printing-research/
                                    Thanks for pointing that out. I have corrected it.
                                      Russ Gries
                                      NP,
                                      also, is the current 1.16 firmware the same as the 1.16 RC3? ( i cant even find that version)
                                      i used a file that was updated "8 hrs ago" and when checking using the web interface… i get V1.16 but no other info, the date is 11-9-16
                                      it was stated in the other thread that you fixed some PWM errors for the Duet 8.5 for servo control, i just want to make sure i have the correct version as I'm trying to test some servo controls with a duet 8.5
                                      Thanks !!!
                                      ~Russ
                                      One Day At A Time…
                                        Russ Gries
                                        also, when using the command "M307 H# A-1 C-1 D-1"
                                        i get no feed back in the command line.
                                        but if i just enter "M307 H#" after using "M307 H# A-1 C-1 D-1" then and only then do i get "Heater # is disabled"
                                        just FYI
                                        ~Russ
                                        One Day At A Time…
                                          @Russ:
                                          just FYI
                                          ~Russ
                                          That is as intended. Most commands generate no output when they succeed, and most commands report current values if you invoke them with no or minimal parameters.
                                          • guywinslowundefined
                                            guywinslow
                                            I installed all three binaries in my printer, and tried a print. Temperature control and fan control a Lot better. But all my stepper motors start and stop now all going in a Strate line. Is there a Configuration change?
                                            [[language]]
                                            ; Configuration file for RepRap Ormerod
                                            ; RepRapPro Ltd
                                            M111 S0                                          ; Debug on
                                            M550 PTricolour Mendel WIFI
                                            M551 Pgdww1620
                                            M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xEA              ; Set the MAC address
                                            M552 S1				                             ; Enable WiFi
                                            M555 P2                                          ; Set output to look like Marlin
                                            M575 P1 B57600 S1                                ; Comms parameters for PanelDue
                                            M906 X800 Y1000 Z800 E800:800                    ; Motor currents (mA)
                                            M305 P0 R4700 T10000 B3988                       ; set bed thermistor parameters
                                            M307 H0 A117.7 C395.8 D1.8 B0                    ; set Heater 0 PID
                                            M307 H1 A662.1 C75.5 D5.9 B0                     ; set Heater 1 PID
                                            M574 X0 S1                                       ; Set endstop configuration
                                            M574 Y2 S0                                       ; Set endstop configuration
                                            M574 Z0 S1                                       ; Set endstop configuration
                                            M569 P0 S0                                       ; Set X Axis Direction
                                            M569 P1 S1                                       ; Set Y Axis Direction
                                            M569 P2 S0                                       ; Set Z Axis Direction
                                            M569 P3 S0                                       ; Set E0 Axis Direction
                                            M569 P4 S0                                       ; Set E1 Axis Direction
                                            M558 P1 X1 Y0 Z1                                 ; Set Z probe type
                                            M92 X100.25 Y100.25 Z4001.50 E420.00:420.00      ; Set axis steps per unit
                                            M570 S180                                        ; Set heater timeout
                                            M667 S0                                          ; set Cartesian mode
                                            M350 X16 Y16 Z16 E16:16 I0                       ; Set microstepping mode
                                            M563 P0 D0 H1                                    ; Create tool 0 = Color 1
                                            M563 P1 D1 H1                                    ; Create tool 1 = Color 2
                                            M563 P2 D2 H1                                    ; Create tool 2 = Color 3
                                            G10 P0 X00.0 Y0.0 Z0.0 S0 R0                     ; Set tool 0 operating and standby temperatures
                                            G10 P1 X00.0 Y0.0 Z0.0 S0 R0                     ; Set tool 1 operating and standby temperatures
                                            G10 P2 X00.0 Y0.0 Z0.0 S0 R0                     ; Set tool 2 operating and standby temperatures
                                            M106 P2 T45 H1                                   ; Fan control, Thermostatic on Heater H1
                                            M106 P0 F75 B1                                   ; Fan control, Cooling fan
                                            M572 D0 S0.05                                    ; Set extruder 0 pressure advance
                                            M572 D1 S0.05                                    ; Set extruder 1 pressure advance
                                            M201 X800 Y800 Z15 E1000                         ; acceleration tweaks for improved finish
                                            M203 X15000 Y15000 Z150 E3600                    ; speed tweaks for improved finish
                                            M208 X200 Y200 Z120                              ; set axis max travel
                                            M208 X0.0 Y0.0 Z0.0 S1                           ; set axis minimum (adjust to make X=0 the edge of the bed)
                                            G21                                              ; Work in millimetres
                                            G90                                              ; Send absolute coordinates...
                                            M83                                              ; relative extruder moves
                                            G31 P500 Z0.35                                   ; Set the probe height and threshold PLA = 0.65, ABS = 0.75
                                            T2
                                            M500                                             ;Store setting in EEPROM
