    Laser turns of during straight lines
    Laser Cutters
    2.4k
    • Zandrundefined
      Zandr
      Config G
      G90 ; Sent absolute coordinates
      M550 PWorkBee CNC Machine ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S0 ; Drive 0 goes forwards
      M569 P2 S0 ; Drive 2 goes forwards
      M584 X0 Y1:3 Z2 ; Apply custom drive mapping
      M92 X400 Y400 Z400 ; Set steps per mm
      M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation
      M566 X500 Y500 Z500 ; Set maximum instantaneous speed changes (mm/min)
      M203 X2500 Y2500 Z2500 ; Set maximum speeds (mm/min)
      M201 X150 Y150 Z150 ; Set accelerations (mm/s^2)
      M906 X2400 Y2400 Z2400 I100 ; Set motor currents (mA)
      M208 X800 Y770 Z94 S0 ; Set axis maxima
      M574 X2 Y2 Z2 S0 ; Set active low endstops
      ; LASER SETTINGS
      M307 H2 A-1 C-1 D-1 ; disable heater 2 to make it available as a general purpose output pin
      M452 P2 I0 R255 F200
      ; Custom settings
      M564 H0 ; Enable jog commands when not homed
      M140 H-1 ; Disable heated bed
      M501 ; Load Stored Parameters
      M563 P1 S"XYZ-Probe" ; Define XYZ Touch Probe Tool
      Home All
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool on Mon Mar 12 2018 16:19:25 GMT+0000 (GMT Standard Time)
      G91 ; relative positioning
      G1 H1 Z94 F900 ; move quickly to Z axis endstop and stop there (first pass)
      G1 Z-3 F2400 ; go back a few mm
      G1 H1 Z94 F300 ; move slowly to z axis endstop once more (second pass)
      G1 H1 X1500 Y1500 F2400 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 X-3 Y-3 F2400 ; go back a few mm
      G1 H1 X1500 Y1500 F300 ; move slowly to X and Y axis endstops once more (second pass)
      G90 ; absolute positioning
      Home x
      ; homex.g
      ; called to home the X axis
      G1 H1 X1500 F2400 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 X-3 F2400 ; go back a few mm
      G1 H1 X1500 F300 ; move slowly to X and Y axis endstops once more (second pass)
      Home y
      ; homey.g
      ; called to home the Y axis
      G1 H1 Y1500 F2400 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 Y-3 F2400 ; go back a few mm
      G1 H1 Y1500 F300 ; move slowly to X and Y axis endstops once more (second pass)
      Home z
      ; homez.g
      ; called to home the Z axis
      G1 H1 Z94 F1500 ; move quickly to Z axis endstop and stop there (first pass)
      G1 H1 Z94 F300 ; move slowly to Z axis endstop once more (second pass)
      • Zandrundefined
        Zandr
        https://www.dropbox.com/s/bvmhu6aodccqmqt/Video 25-03-2019%2C 4 32 20 pm.mov?dl=0
        Added a video hope this helps also. If you look between 20 and 30s into it you can see where i have tried to do a simple HI text and the straight lines within the text dont complete, i will do another video showing that.
        Thank you
        • whosrdaddyundefined
          whosrdaddy
          I don't know if it makes a difference but you did not home your axes in your video, maybe try homing them first?
          Zandrundefined 1 Reply Last reply Reply Quote 0
          • Zandrundefined
            Zandr @whosrdaddy
            @whosrdaddy thank you but i homed before i started just didnt show it in the video and then set the work once and then realised i coudent get a good video so moved and set work zero again. Thanks tho 🙂
            • Zandrundefined
              Zandr
              https://www.dropbox.com/s/nmfwcr52qj705u3/Video 25-03-2019%2C 7 41 59 pm.mov?dl=0
              Circles work ok 1000mm/min
              • Zandrundefined
                Zandr
                https://www.dropbox.com/s/85r4dxatwe89pzq/Video 25-03-2019%2C 7 54 05 pm.mov?dl=0
                Same circle at 20mm/min is it corect that it should flick on and off? Per g1 move
                  I still can't reproduce the problem you describe, but I've found an error in your GCode. You have this in config.g:
                  The relevant commands in your GCode file are:
                  G0 X14.3143 Y50.0000 Z0.0010
                  M3 S200
                  G1 X83.3143 Z-0.0010 F1000.0 S200
                  The last G1 command has endpoint Z=-0.0010 but you have set the Z minimum to zero. So that command is to an out-of-bounds position and it won't be executed. You should get an error message in the console.
                  Zandrundefined 2 Replies Last reply Reply Quote 0
                  • Zandrundefined
                    Zandr @dc42
                    @dc42 yep i get an error only when i dont drop my z down after it has been homed so home z, drop z down by about 15 then set work zero then i run the g code.
                    Do you have a g code you would like me to try ?
                    Shall remove the z comands and see if it will work?
                    • Zandrundefined
                      Zandr @dc42
                      @dc42 did you view the videos they show my issues?
                        Yes I looked at your videos. What I think is happening is that heater 2 has become re-enabled, and the heater monitoring system is turning it off.
                        1. Please check that you do not have a M307 H2 command in config-override.g.
                        2. Please run M307 H2 with no additional parameters and report the results.
                        3. Please attach to your next post your config.g and config-override.g files, also a simple GCode file that should cut out a square or rectangle and that demonstrated this problem. Do not do any Z movements in the cutting moves.
                        • Zandrundefined
                          Zandr @dc42
                          @dc42 you are amazing there was a M307 H2 in the config override g, i removed it and rebooted and all works like a charm.
                          i have included my override g just to see if there is anything that shoudent be there.
                          the line g code now works 🙂 i owe you a drink
                          ; config-override.g file generated in response to M500 at 2019-03-26 17:29
                          ; Heater model parameters
                          M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1
                          M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                          M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                          M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                          M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                          M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                          M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                          G10 L2 P1 X0.00 Y0.00 Z0.00
                          G10 L2 P2 X250.00 Y420.00 Z59.00
                          G10 L2 P3 X0.00 Y0.00 Z0.00
                          G10 L2 P4 X0.00 Y0.00 Z0.00
                          G10 L2 P5 X0.00 Y0.00 Z0.00
                          G10 L2 P6 X0.00 Y0.00 Z0.00
                          G10 L2 P7 X0.00 Y0.00 Z0.00
                          G10 L2 P8 X0.00 Y0.00 Z0.00
                          G10 L2 P9 X0.00 Y0.00 Z0.00
                            dc42 administrators @Zandr
                            Thanks, I'll mark this as solved then.
