    Laser turns of during straight lines
    Laser Cutters
    2.2k
    • whosrdaddyundefined
      whosrdaddy
      I don't know if it makes a difference but you did not home your axes in your video, maybe try homing them first?
      Zandrundefined 1 Reply Last reply Reply Quote 0
      • Zandrundefined
        Zandr @whosrdaddy
        @whosrdaddy thank you but i homed before i started just didnt show it in the video and then set the work once and then realised i coudent get a good video so moved and set work zero again. Thanks tho 🙂
        • Zandrundefined
          Zandr
          https://www.dropbox.com/s/nmfwcr52qj705u3/Video 25-03-2019%2C 7 41 59 pm.mov?dl=0
          Circles work ok 1000mm/min
          • Zandrundefined
            Zandr
            https://www.dropbox.com/s/85r4dxatwe89pzq/Video 25-03-2019%2C 7 54 05 pm.mov?dl=0
            Same circle at 20mm/min is it corect that it should flick on and off? Per g1 move
              I still can't reproduce the problem you describe, but I've found an error in your GCode. You have this in config.g:
              The relevant commands in your GCode file are:
              G0 X14.3143 Y50.0000 Z0.0010
              M3 S200
              G1 X83.3143 Z-0.0010 F1000.0 S200
              The last G1 command has endpoint Z=-0.0010 but you have set the Z minimum to zero. So that command is to an out-of-bounds position and it won't be executed. You should get an error message in the console.
              Zandrundefined 2 Replies Last reply Reply Quote 0
              • Zandrundefined
                Zandr @dc42
                @dc42 yep i get an error only when i dont drop my z down after it has been homed so home z, drop z down by about 15 then set work zero then i run the g code.
                Do you have a g code you would like me to try ?
                Shall remove the z comands and see if it will work?
                • Zandrundefined
                  Zandr @dc42
                  @dc42 did you view the videos they show my issues?
                    Yes I looked at your videos. What I think is happening is that heater 2 has become re-enabled, and the heater monitoring system is turning it off.
                    1. Please check that you do not have a M307 H2 command in config-override.g.
                    2. Please run M307 H2 with no additional parameters and report the results.
                    3. Please attach to your next post your config.g and config-override.g files, also a simple GCode file that should cut out a square or rectangle and that demonstrated this problem. Do not do any Z movements in the cutting moves.
                    • Zandrundefined
                      Zandr @dc42
                      @dc42 you are amazing there was a M307 H2 in the config override g, i removed it and rebooted and all works like a charm.
                      i have included my override g just to see if there is anything that shoudent be there.
                      the line g code now works 🙂 i owe you a drink
                      ; config-override.g file generated in response to M500 at 2019-03-26 17:29
                      ; Heater model parameters
                      M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1
                      M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                      M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                      M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                      M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                      M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                      M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                      G10 L2 P1 X0.00 Y0.00 Z0.00
                      G10 L2 P2 X250.00 Y420.00 Z59.00
                      G10 L2 P3 X0.00 Y0.00 Z0.00
                      G10 L2 P4 X0.00 Y0.00 Z0.00
                      G10 L2 P5 X0.00 Y0.00 Z0.00
                      G10 L2 P6 X0.00 Y0.00 Z0.00
                      G10 L2 P7 X0.00 Y0.00 Z0.00
                      G10 L2 P8 X0.00 Y0.00 Z0.00
                      G10 L2 P9 X0.00 Y0.00 Z0.00
                        dc42 administrators @Zandr
                        Thanks, I'll mark this as solved then.
