Power supply advice please
@cap:
would this do me
http://www.auberins.com/index.php?main_page=product_info&cPath=2_30&products_id=30No it wont as that is for an AC bed think you need one for DC so look at
http://www.auberins.com/index.php?main_page=product_info&cPath=2_30&products_id=288
Doug
hi again thanks for your help
i am trying to find one local but i do not fancy my chancesalso ran into this may help other so ill post it here
http://sublimelayers.blogspot.co.uk/2016/03/how-to-choose-ssr-to-drive-your-heated.htmlthink ill have to pay more for postage than i will for the part lol
where are you?
uk
cost £29.31 pound shipped -
OK I think RS do some decent ones but not looked into it as I only ever use AC Heaters on My Printers so a bit of Valots drop is insignificant however at DC it is a major problem as you have found out?
Doug
well ive read a couple of poeple have ran into problems with 12v dc heaters (doh live and learn) and that the linked ssr above work well with just a heat sink
so my thinking is run a 32amp 400w psu via ssr to run my 12v 280w heat-bed leaving a big safety margin 40%
and then run my 25amp 300w psu to run my duetwifi board with all attached bits also leaving a large safety marginim thinking ill let it run like this for a year then ill iver by better psu when funds arrive are recycle the psu into new projects
any safety tips would be gratefully received
are safer ways to achieve me goals -
See the section on connecting a bed heater on the wiki. I included SSR recommendations in it.
Printers with beds larger than 200mm square are usually run with 24V power, to keep the bed heater current to manageable proportions. For example, if you had a 24v 280W bed heater instead of 12V 280W, the current draw would be 11.7A which is within the rating of the Duet WiFi.
well its all ordered now and in the post so ill try ill move everything into the shed for a good long test run it can make big smokey mess at the bottom of the garden (worst case) and ill fit a big red switch in shed to kill all shed power
and anther big red switch at back door -
The Single 32 amp PSU should be able to manage the whole lot to be fair sure DC will be along to give his advise soon enough.
The Auberin ones should be fine mounted to just an Alloy plate I think I reckon you will need to sink approx 2 watts of heat away from it so not excessive Remember you can use the Heatbed output from the Duet to switch it on and off and the output of the PSU would have the O/P of the SSR In series with the Bed.
hi only me the ssr is in the post and i get how to wire the ssr and the power supply to the board but what i cart find is do i need to change anything in the config file for it to work
You don't need to change anything in the config file to use an SSR to control the bed.
