    Duet 2 Wifi new install - Ender 3
    36
    11.7k
    • Excelonundefined
      Excelon @dc42
      @dc42 Yes, I rebooted the machine and still the same problem. I got it to work by switching USB ports.
      • Danalundefined
        Danal
        I do understand that you are pretty far down the USB path... and it may be hard to convince you to change... but...
        I don't believe I've ever plugged USB into any of my Duets. Just edit the files on the card in a PC or Mac enough to get wireless working, and then did everything else via the web interface. The key file & statements for the first wireless connection are:
        /sys/config.g
        M550 PDanal's BFD ; Set machine name
        M551 P ; Set password (for Duet Web interface, not for WiFi network)
        M587 S"MySSID" P"myPassWoRD" ; Set SSID and network key password for WiFi network.
        M552 S1 ; Enable network
        After you get connected the first time, remove the M587 so that you don't have your WiFi password floating around in a file. The Duet will 'remember' it.
        Doing it that way, you need never connect USB.
        • Agniusmundefined
          Agniusm @A Former User
          @calvinx Maybe they are different in assembly but the boards and the steppers are the same. it would be a huge unnecessary expense to them to change any part of this. All is based on one, same steppers and wiring so there is less confusion and QC issues. I have 4 enders from different times and suppliers and all of them wire the same. Oh, CR10S4 too which is the same, except for the bigger Y motor.
          OP will be able to confirm that
          • 3dmntbighkerundefined
            3dmntbighker
            Injecting a comment about Ender 3 revisions... I just saw the other day they have started shipping with silicone boots on the hot end instead of tape. 👍
            Scratch built CoreXY with Maestro
            Heavily modified Ender 3 with Maestro
            MPCNC work in progress with Duet WiFi
              A Former User @Agniusm
              @agniusm said in Duet 2 Wifi new install - Ender 3:
              Again if you say so, I can and will only go with what i have physically seen creality doing, the changes i have seen are not to the boards or the motors but to the wiring looms which in the case we are seeing differing looms not following the logical wiring method.
              As a side note to admin is there anyway to block seeing certain users on the forum ?
              • jon_stoskiundefined
                jon_stoski
                I find it very confusing that the coils are labelled 2B,2A,1A,1B on the Duet Drive outputs when the motor specifications use A, B, not A, not B for the coils. Specifically, 2B and 2A are on one coil while 1A and 1B are on the other. I was reading it for quite a while as 1A and 2A as the same coil, could somebody tell me why you use this nomenclature on the hardware drawing?
                  dc42 administrators @jon_stoski
                  @jon_stoski said in Duet 2 Wifi new install - Ender 3:
                  It's because that's how Trinamic label the motor outputs on their driver ICs. We intend to change the labels at the next PCB revision.
                  • SeahorseRiderundefined
                    SeahorseRider
                    Hi, I have a new Ender3 to supplement my efforts with my M3D Promega 3D printer so I am familiar with using and configuring the Duet 2 Meistro board. I want to upgrade my Ender 3 with the Duet2 WIFI controller, the Titan Aero hotend extruder, the BT-Touch probe, and the Panel Due 7i. I presently have these components for my upgrade on hand. What I need is a sample config.g file to use as a model to ease the installation pains along with tips on order of install (ie go "cold turkey" and install all at once, Duet first to get it going, etc). What I don't want to bother with is flashing firmware on the original Ender3 controller. On Dec 13, 2018 CalviNx mentioned he could share his config.g file from his Ender3+Duet2-WiFi+Titan Aero system. Anyone have additional tips for configuring all of this using the BT-Touch? I still need to print the Titan Aero mounts so this is an area for finding recommended .stl files. Any assistance is welcomed.
                    lodgerundefined 1 Reply Last reply Reply Quote 0
                    • lodgerundefined
                      lodger @SeahorseRider
                      @seahorserider
                      I use this mount on mine ender3, https://www.thingiverse.com/thing:3279302
                      I am not by my printer right now or i would send you my config.g.
                      Mind you I am using a probe so i cannot help with the BL Touch..
                        SeahorseRider
                        Here's themount I'm favoring so far for the Ender3+TitanAero+BLTouch: https://www.thingiverse.com/thing:3078853
                        Any better ones?
                          SeahorseRider
                          I can still use a config.g file for this combo upgrade for the Duet3dWIFI+TitanAero+BLTouch Ender3 upgrade. Also, any better order of install over "cold turkey" attempt of install all, then test, giving a working default ENDER3 original configuration? Or, is it better to get the Duet wifi going with the original extruder first before attempting the Aero install?Comments? Recommendations?
                            @SeahorseRider I'd probably do it all at once. If you know the mechanical details of the printer you can use the web configurator to get a config file set that should get you the basics. I'm not familiar with the ender 3 specifics off hand, but it's not exotic. This should give you an idea of what sort of details you need to know about the ender 3 to successfully populate the configurator.
                            Adapting an existing 3d printer to the Duet
                              SeahorseRider
                              Thanks, Phaedrux. Can you give me some tipss on how to implement the BLTouch probe in my planned configuration? Specifically, how to set xyz offsets for the probe, when engaged so Duet mesh mapping really knows where the probe is at. This is where a sample config.g file for my planned mod would be useful. Someone else's implementation may only differ by offsets from nozzle to probe tip. Doint the mesh mapping could be set up with macros like the Promega uses on the Duet Maestro.
                                Phaedrux Moderator @SeahorseRider
                                @seahorserider For the offset in X and Y you can measure, either with a ruler, or by marking the spot on the bed where the nozzle tip is and then jogging X and Y until the probe is over the spot where the nozzle is. Take the amount you jogged as your X and Y offset. For Z you should use the Z probe trigger height calibration.
                                https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                                  SeahorseRider
                                  Thanks. Z-Height Calibration I think is Macro #1 on the promega. Forgot about that.
