consistent layer shift in both x/y using clear-path servos ?
i made an attempt at using clearpaths (not on a duet, but with a mightyboard) and I was able to get it functional, but was never able to get rid of servo tuning related issues. I think the direction you should go (once you get layer shifting figured out) is to have a 2:1 reduction or greater off of the motor before your drive pulley. This should allow for sharper tuning.
@thatbigprint said in consistent layer shift in both x/y using clear-path servos ?:
@dc42 for the z i have skipped the enable and soldered into 5v so the z is always enabled i will probs do this to the rest in that case ?
When you upgrade to firmware 2.02 you will get warnings that the motors are disconnected.
@nhof apologies for the late reply i have sorted most of the surface finish issues (single wall with an 8mm nozzle and doing infill first) and as for motors mine are 800 count or the lesser model... and for tuning, I had locked down the opposite motor shaft and run the auto-tune feature they seem to be behaving z-axis is a tiny bit noisy but I can tune that in better later this weekend when I have uninterrupted time i think its duet to weight and the fact its belt drive through a jackshaft (totally unideal but easy/cheap for a super quick turn around) but in theory i can wack up the motor counts per rev and have it actually be more accurate ? i had initially thought this would just make the motors always hunt too much?
@timothyz i will be going to a planetary reduction gearbox on all axis although I'm apprehensive due to clearpaths odd choice of motor shaft? the jackshaft on z was a last min thing as a workaround seems to be doing ok so far for a printed pulley moving around 20mm of tooling plate
@dc42 will this be the case for the super early duet wifis ? as in ones without motor feedback? and if not will there be a firmware workaround ? or just don't upgrade?
Why don't you connect the servo drives as we instruct on the wiki page instead?
@dc42 apologies for late reply reason for doing this is because it looks cleaner in terms of cable management but if it is causing me aforementioned issues I will go to flat flex expansion header
so i am still having the issue where the bed for whatever reason is not remaining level ie goes through probing etc starts printing (you can see it adjusting z) suggesting its trying to work but one end for the print (600x600x20mm) the layer fades out completely and the other end the layer is fine ?
below are my current settings gone way higher on the t values to no avail?
Taa:bb:cc:dd (firmware 1.21 and later) Minimum driver step pulse width, step pulse interval, direction setup time and direction hold time, in microseconds
M569 P0 S1 T10:5:1:1
M569 P1 S1 T10:5:1:1
M569 P2 S0 T10:5:1:1
M569 P3 S0
M350 X16 Y16 Z16 E16 ; Configure microstepping with interpolation
M92 X26.676 Y26.676 Z89.233 E804.81 ; Set steps per mm
M566 X1500 Y1500 Z900 E1500 ; Set maximum instantaneous speed changes (mm/min)
M203 X6000 Y6000 Z2000 E2000 ; Set maximum speeds (mm/min)
M201 X800 Y800 Z500 E250 ; Set accelerations (mm/s^2)
M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeoutgetting pretty desperate now as work needed to go to another company to get 2 done at a huge cost to them
layer hight may also be inaccurate but not sure on that as the test cube i print appears to be over extruding but the actual extrusion is spot on ?
also, I have looked at ways of testing the repeatability of the bed probe but not much info for the duet i did try the.....
;prob testing single point.
G30 P0 X200 Y200 Z-99999 F2000
G30 P1 X200 Y200 Z-99999 F2000
G30 P2 X200 Y200 Z-99999 F2000method but it errors out at the end?
Could be an issue with the probing / compensation rather than the motor drive at this point.
Maybe try disabling the auto level and try leveling the bed with a shim or a indicator to see if you can narrow the problem down.
The reason I mention this is because I have had problems in the past with my BL Touch probes creating inconsistent height maps where it looked like one side of the bed was way higher than the other, while my dial indicator indicated that everything was actually flat.
@nhof i have moved away from grid and gone to 5 point bed level now works fine
think it was the probe picking up the edge of the printbite ?
Try a smaller mesh then?
@dc42 tried a smaller constrained mesh but no luck its ok for now using 5 point level as the plate is flat tooling plate just how its mounted will not allow for adjustment prints are coming out perfectly flat now
just need to work on quality now
Right guys i have revisited the printer so things i have done so far
added io expansion board in a sinking 5v style control for step direction and enable
tried adjusting the m569 values
but i get the same issue the centre of the bed is closer to the nozzle than the perimeter i have mechanically levelled bed as best as i can the z motor has now got significant gear reduction now dimensionally the printer movers are accurate as individual entities but both mesh levelling and bed levelling are not doing as intended.... the motor is moving as though its attempting to level but it feels a bit rough in its movements as in it jerks not smooth
not sure what to try next i have had better success with t values all set to 4 but this adds ringing.... i have used recommended settings suggested by mr DC42
"The setup time is 25ns not 25us, so instead of 1:1:25:1 I suggest 1:1:0.5:0 in the M569 T parameter. My suggestion to use 0.5us setup time is to allow for possible skew in the opto isolators."
but i get constant skipped layers in x and y immediately as in shell is printed and fill is not within the boundary
but i get constant skipped layers in x and y immediately as in shell is printed and fill is not within the boundaryIf 1:1:25:0 works but 1:1:0.5:0 doesn't work, try something like 1:1:1:0 or 1:1:2:0.
@thatbigprint Can you also shoot a picture of your mechanical setup including how your probe is physically mounted to the machine?
I had major problems with the probe creating 'tilted' height maps on a large printer and it turned out the X axis was twisting slightly across the stroke which caused the probe reading to vary significantly (0.5mm+) from side to side.
Thanks both of you i have got it to perform better now setting t values to
T1.25:1.25:1.25:1.25 what is the end value for the one that is zero in aforementioned example ?
i thought it was set up time or stop delay ?
@nhof how do i upload pictures ?
The last one is direction hold time after the step pulse leading edge.
@dc42 said in consistent layer shift in both x/y using clear-path servos ?:
would this being set to zero previously cause the issues i was having ?
It could do, depending on the requirements of your driver.
