    Trying to avoid running levelling before every print
    1.2k
      It's covered at https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation. Let us know if it isn't clear.
      • totalitarianundefined
        totalitarian
        Thanks!
        So just to comfirm,
        G28; home
        G29; level and save mesh
        Then in my gcode I can just run
        G28
        G29 S1; recall
        No need to home after the G29 S1?
          dc42 administrators @totalitarian
          @totalitarian said in Trying to avoid running levelling before every print:
          Thanks!
          So just to comfirm,
          G28; home
          G28
          G29 S1; recall
          That's correct. You can do a single G30 probe at the centre of the bed after the G29 S1 if you want.
            totalitarian
            Thanks again, what is the advantage of adding in the extra G30?
              If you home Z using the Z probe by doing a G30 at or near bed centre, then probably none. If you home Z using an endstop switch, then you may get a more precise Z=0 height by doing the extra G30.
                totalitarian
                @dc42 said in Trying to avoid running levelling before every print:
                G28; home
                I am homing using my probe but use G28 rather than G30.
                  Phaedrux Moderator @totalitarian
                  @totalitarian G30 would be used in your homeall.g file to probe the Z axis height. G28 calls homeall.g
                  totalitarianundefined 1 Reply Last reply Reply Quote 0
                    totalitarian @Phaedrux
                    @phaedrux Good point!
                    • IOIIOOOundefined
                      IOIIOOO
                      If I put G29 S1 in my config.g, do I still need to run it before each print as well or will the mesh stay in memory between prints?
                      Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
                        Phaedrux Moderator @IOIIOOO
                        @ioiiooo https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation#Section_Using_mesh_bed_compensation_before_printing
                          dc42 administrators @IOIIOOO
                          @ioiiooo said in Trying to avoid running levelling before every print:
                          It stays in memory, unless you cancel it with M562 or G29 S2.
