    A bug in 2.02
    1.5k
    • Anidalundefined
      Anidal
      Good day!
      Maybe I found a bug in the firmware DuetWifi 2.02
      The error occurs in a complex sequence of actions:
      My printer is always on via the + 5V line.
      The power unit is turned on before print by the macro
      / macros / Preheat.g
      M80
      M106 P0 S0.4
      M106 P1 S0.98
      M106 P2 S0.98
      M106 P3 S0.6
      M140 S130
      G10 P0 R210 S210;
      G10 P1 R210 S210;
      G10 P2 R50 S50;
      T0
      T1
      T2
      and after the end of printing is called the command M0
      macro /sys/stop.g
      ; stop.g
      ; called when M0 (Stop) is run (e.g. when a print from SD card is canceled)
      M106 P0 S255; fan at 100% to cool nozzle
      M106 P1 S255; fan at 100% to cool nozzle
      M106 P2 S255; 100% extruder fan
      M106 P3 S200
      M1; heaters and motors off
      G4 S180; Wait for 3 minutes
      M106 P0 S0; fan off
      M106 P1 S0; fan off
      M106 P2 S0; Stop extruder fan
      M81; power off
      With these settings, the printer worked for many days and printed many times. Without crashing.
      I recently added tool switching macros
      ; tpost0.g
      G1 X100 Y244 F12000
      G1 X195 Y244 F12000
      G1 X170 Y244 E0 F1000
      G1 X190 Y242 E4.00 F2400
      G1 X130 Y242 E5.0 F2000
      G1 X120 Y236 F2000
      G1 X131 Y236 F12000
      G92 E0
      and
      ; tpost1.g
      G1 X100 Y244 F12000
      G1 X195 Y244 F12000
      G1 X120 Y236 F2000
      G1 X131 Y236 F12000
      G92 E0
      Now, if printing is completed normally, and the stop.g macro is executed, the next print (I run preheat.g, wait for warm-up and start printing any file), the head can only move in the direction of increasing X and Y coordinates
      Exit from the error state can only by reboot the printer.
      If printing is forced to stop (pause-> cancel), then the next printing will start without error.
      cancel.g is present, but empty
      • Jacotheronundefined
        Jacotheron
        Typically when you can only move to increasing coordinates, is when the Duet lost its Homing position.
        Since the Stepper motors are powered by the Vin of the board, they lost their position when there were no power for them (although your 5V and 3.3V logic circuits had power). The result is that it assumes it is at 0,0,0 and to not damage your printer, will not go into the negative space. There is also the change where move commands prior to Homing, needs an extra parameter S2 (see the table at https://duet3d.dozuki.com/Wiki/Gcode#Section_G0_G1_Move)
        Does your print jobs perform a full Home, before starting?
        Alternatively go into the Console (either on DWC or the PanelDue if you have one), and see what error is being given - The Duet is smart enough to tell you what problem it is facing.
        Anidalundefined 1 Reply Last reply Reply Quote 0
          As @Jacotheron says, the M81 command will turn off VIN power so the machine will be flagged as not homed. You will need to home the printer again when you re-apply power.
          Also, I suggest you add T-1 to your stop.g file to make sure that no tool is selected before you power off.
          • Anidalundefined
            Anidal @Jacotheron
            @jacotheron
            Yes, the printer was homed.
            The problem occurs after G28.
            • Anidalundefined
              Anidal
              @dc42 said in A bug in 2.02:
              OK. I try to do it.
              • Anidalundefined
                Anidal @dc42
                Good day!
                Your recommendations with the addition of T-1 did not help.
                At the same time, the printer, before starting the movement to [Xmax, Ymax], first executes the G28 command, and then starts moving along the program.
                Here is an example of the file that failed:
                ; FLAVOR: RepRap
                ; TIME: 2300
                ; Filament used: 0.181584m, 5.93267m
                ; Layer height: 0.25
                ; Generated with Cura_SteamEngine 4.0.0
                T0
                M190 S130
                M104 S260
                M104 T1 S210
                M109 S260
                M109 T1 S210
                M82; absolute extrusion mode
                G28; home all axes
                T0
                G1 X70 Y244 F12000
                G1 X71 Y244 F2000
                G92 E0
                G1 X75 Y244 E8 F2000
                G92 E0
                G92 E0
                G1 X120 Y236 F2000
                G1 X131 Y236 F12000
                G92 E0
                T1
                G1 X70 Y244 F12000
                G92 E0
                G1 X71 Y244 F2000
                G92 E0
                G92 E0
                G1 X120 Y236 F2000
                G1 X131 Y236 F12000
                G92 E0
                T0
                M83; relative extrusion mode
                G1 F1800 E-6
                A reboot corrects the status of the printer until the next stop.g
                Manual re-homing did not help.
                  I don't understand this issue. You are saying that when the two tool change files are added, this problem started. Correct?
                  Can you pin down a little more what it is about the tool change files that triggers the problem? For example, does it happen if only one of the files is present? Does it happen if the files are empty?
                  • Anidalundefined
                    Anidal @dc42
                    Good day!
                    Yes, the problems started when I added a code to move the head to the cleaning site in post0.g and post1.g files. Before adding files were present, but were empty.
                    Previously, I used another slicer, where you could insert a cleanup code with a slicer.
                    There are no more differences in the printer setup.
                    What is interesting is that when the printer crashes on the error code and moves to [Xmax, Ymax], pressing PAUSE on the screen returns the head to the home position.
                    • Anidalundefined
                      Anidal
                      Hello!
                      At the moment I have not managed to solve the above problem. As a temporary solution, I added the command M112 to the end of stop.g to restart the printer after printing.
                        1. After the print completes, before doing anything else, please run these commands and report the responses:
                        M114
                        G10 P0
                        G10 P1
                        G10 L2
                        Then check that the error is still present (i.e. you can only move in the +X and +Y directions).
                        1. Please try adding an extra comment line at the end of your tpost files, and see if that makes any difference.
                        • Anidalundefined
                          Anidal
                          OK, I try to do it.
                          • Anidalundefined
                            Anidal
                            G10 L2
                            Good day.
                            I disabled the restart of the printer from stop.g and tried your commands.
                            At this point, the printer completed printing the model, completed stop.g, turned off the power, and only + 5V PS_ON is active.
                            ; stop.g
                            ; called when M0 (Stop) is run (e.g. when a print from SD card is cancelled)
                            T-1 ;
                            M106 P0 S255 ; fan at 100% to cool nozzle
                            M106 P1 S255 ; fan at 100% to cool nozzle
                            M106 P2 S255 ; 100% extruder fan
                            M106 P3 S200
                            M1 ; heaters and motors off
                            G4 S180 ; Wait for 3 minutes
                            M106 P0 S60 ; fan off
                            M106 P1 S60 ; fan off
                            M106 P2 S60 ; Stop extruder fan
                            M106 P3 S60
                            M81 ;power off
                            ;M112
                            19:01:38
                            G10 L2
                            Origin of workplace 1: X0.00 Y0.00 Z0.00 U0.00
                            19:01:08
                            G10 P1
                            Tool 1 offsets: X-18.00 Y0.00 Z0.00 U0.00, active/standby temperature(s): 0.0/0.0
                            19:01:00
                            G10 P0
                            Tool 0 offsets: X0.00 Y0.00 Z0.00 U0.00, active/standby temperature(s): 200.0/200.0
                            19:00:44
                            M114
                            X:109.373 Y:167.258 Z:36.025 U:0.000 E0:882.9 E1:18049.1 E2:0.0 E3:0.0 E4:0.0 E5:0.0 E6:0.0 E7:0.0 Count 88522 -18523 22516 0 Machine 109.373 167.258 36.025 0.000
                            19:00:37
                            Connection established!
                            19:00:37
                            Page Load complete!
                            Then I powered the printer and ran the G28.
                            The printer worked the command correctly and moved right after that.
                            19:02:46
                            M120
                            G91
                            G1 Y-50 F6000
                            M121
                            19:02:44
                            M120
                            G91
                            G1 X-50 F6000
                            M121
                            19:02:41
                            M120
                            G91
                            G1 Y50 F6000
                            M121
                            19:02:39
                            M120
                            G91
                            G1 X50 F6000
                            M121
                            19:02:24
                            G28
                            19:01:45
                            M98 P"0:/macros/Power Up"
                            Then I started the heating macro. During its execution, the nozzles are cleaned and movement and extrusion occurs.
                            Macro worked correctly.
                            19:07:00
                            Heater 3 switched on
                            19:04:58
                            Heater 2 switched on
                            19:03:04
                            Heater 1 switched on
                            19:03:01
                            Heater 0 switched on
                            Then I started to print the previously normally printed file.
                            ***File start:
                            ;FLAVOR:RepRap
                            ;TIME:1849
                            ;Filament used: 7.37841m, 0m
                            ;Layer height: 0.3
                            ;Generated with Cura_SteamEngine 4.0.0
                            T0
                            M190 S130
                            M104 S260
                            M104 T1 S210
                            M109 S260
                            M109 T1 S210
                            M82 ;absolute extrusion mode
                            G28 ; home all axes
                            T0
                            G1 X70 Y244 F12000
                            G1 X71 Y244 F2000
                            G92 E0
                            G92 E0
                            G92 E0
                            G1 X120 Y236 F2000
                            G1 X131 Y236 F12000
                            G92 E0
                            T1
                            G1 X70 Y244 F12000
                            G92 E0
                            G1 X71 Y244 F2000
                            G92 E0
                            G92 E0
                            G1 X120 Y236 F2000
                            G1 X131 Y236 F12000
                            G92 E0
                            T0
                            M83 ;relative extrusion mode
                            G1 F1800 E-6
                            ;LAYER_COUNT:56
                            ;LAYER:0
                            M107
                            M204 T5000
                            ;MESH:derjatel.stl
                            G0 F5400 X50.599 Y122.5 Z0.3
                            M204 P3000
                            ;TYPE:WALL-OUTER
                            G1 F1800 E6
                            G1 F3000 X50.898 Y128.187 E0.56823
                            And at the beginning of printing, after the G28 the printer started to behave abnormally.
                            I paused printing and invoked debug commands again.
                            19:10:42
                            G10 L2
                            19:10:34
                            G10 P1
                            Tool 1 offsets: X-18.00 Y0.00 Z0.00 U0.00, active/standby temperature(s): 210.0/210.0
                            19:10:15
                            Printing paused at X228.0 Y245.0 Z0.0 U360.0
                            19:10:12
                            G10 P1
                            Paused print, file offset=159
                            Resume state saved
                            19:09:53
                            G10 P0
                            Tool 0 offsets: X0.00 Y0.00 Z0.00 U0.00, active/standby temperature(s): 260.0/260.0
                            19:09:38
                            M114
                            X:228.000 Y:245.000 Z:0.000 U:360.000 E0:43.0 E1:17.5 E2:0.0 E3:0.0 E4:0.0 E5:0.0 E6:0.0 E7:0.0 Count 151360 -5440 0 3200 Machine 228.000 245.000 0.000 360.000
                            X228.0 Y245.0 Z0.0 U360.0 - abnormal coordinates
                            • Anidalundefined
                              Anidal
                              @anidal said in A bug in 2.02:
                              In macros and printable file coordinate X228 Y245 is not present.
                              Is it possible that the macro command M82 is missing in the macros, but is it present in the print file and is somehow affected?
                              • Anidalundefined
                                Anidal
                                I try to delete M82 - no effect.
