    M109 command does not run tool change macro's
    886
    • St Tawundefined
      St Taw
      I posted a problem regarding
      Using Slic3r with Tool Changer
      But have not had a follow up response so posing the question differently.
      Should the command
      M109 S200 T3 ;
      Run tool change macro's for current tool followed by T3 macro?
        If all axes are flagged as having been homed, then the tfree file for the current tool should be run (if a tool is already selected), followed by the tpre and tpost files for tool 3.
        • St Tawundefined
          St Taw
          Thanks for reply.
          Well after homing I run
          M109 S200 T3
          Tool 3 gets to 200C but no macro has run to get it.
          I then did a
          M109 S40 T0
          Tool 0 rises to 40C. However tool 3 remains the active tool although no physical tools are loaded.
          In panel due I can deselect T3 and it runs macro to unload T3 (though it was not present)
            Firmware version?
            • St Tawundefined
              St Taw
              Firmware details.
              Firmware Electronics: Duet WiFi 1.02 or later + DueX5
              Firmware Version: 2.02(RTOS) (2018-12-24b1)
              WiFi Server Version: 1.22
              Web Interface Version: 1.22.6
                On my list to investigate.
                  dc42 administrators @dc42
                  I confirm there is a problem, at least in the case where no tool is selected initially.
                  • NicoLab28undefined
                    NicoLab28
                    take a look to this thread
                    https://forum.duet3d.com/topic/9405/first-t0-in-gcode-does-not-work
                      dc42 administrators @NicoLab28
                      @nicolab28 said in M109 command does not run tool change macro's:
                      That looks like the same issue. There is a M109 S225 T0 command in the GCode file, before the T0 command.
                      • St Tawundefined
                        St Taw
                        Note sure if associated or a different issue but if I Pause and then Cancel a print from Panel Due the tool becomes deselected but no macro run. Hence the tool remains attached to the head.
                        • clegg78undefined
                          clegg78
                          @dc42 said in M109 command does not run tool change macro's:
                          Ha, happy I found this, I was just finding this same issue when troubleshooting a related odd tool selection behavior of M109.
                          Simplify runs the HE heat up sequence before the custom scripts can be run, so I see this :
                          "M104 S255 T1
                          M109 S255 T1"
                          And if no tool has been called yet, M109 seems to set Tool 1 (from no tool being selected - this is a problem in its own right, as I cant run the tool Tfree and tPost that I was planning on at the start of a print to ensure everything is where it should be. This is before the axis have been homed.
                          But I noticed that even if I manually tweaked the script so that the weird M109 tool selection behavior happened after G28, I wouldn't get the scripts to fire.
                          Any reason M109 picks a Tool when M104 does not? In S3D's case, it means I cant actually run any of the tool change scripts before printing starts without throwing in a tool switch back and forth which seems kind of clumsy.
                          A geek designing and building his own custom IDEX printer from scratch as seen here: https://joekelly.co/3d/
                            The reason M109 does a tool change is that most slicers assume that a tool is already selected at the start of a print. There used to be many users reporting prints failing, which was because no tool was ever selected. As M109 waits for heating to complete, it's unlikely that you will use it unless you are about to use that tool. Also a slicer that is aware that it is generating code for RepRapFirmware should be using G10 (or possibly M104) and then M116, not M109. So we take the view that any GCode that includes M109 probably doesn't select a tool before it prints, which is why we make tool selection implicit when the firmware sees M109.
                            M104 is used by some slicers to set the temperatures of standby tools, so I didn't consider it appropriate to make it select a tool.
                            • St Tawundefined
                              St Taw
                              Thanks for reply.
                              Does anyone use Slic3r PE for an E3D like tool changer that works without having to edit the gcode file to overcome this issue of no tool being got?
                              The Firmware setting in Slic3r I have set to RepRap/Sprinter. Would one of the other 'Flavors' be better to generate G10 commands?
                              Any E3D toolchange users out there that are using Slic3r? If so how do you get the tool to be physically picked up on print run if currently physically no tool selected and firmware starts with no tool selected.
                                You may have to use the slicer post processing capabilities to convert the M109 to G10.
                                  dc42 administrators @St Taw
                                  @st-taw said in M109 command does not run tool change macro's:
                                  Thanks for reply.
                                  Have you tried putting a T0 command in the start.g file?
                                  • St Tawundefined
                                    St Taw
                                    I tried putting a T0 command in start.g
                                    It appears to run the tfree0.g macro then the T3 tpre3.g and tpost3.g.
                                    The head does go to put T0 back in place at the start of printing even though it does not have the tool in place is a small compromise to get it working.
                                    On a similar note I have
                                    M0 in the Cancel.g which also deselects the tool without running the tfree?.g macro. I have resolved this by putting a T-1 before it.
                                    Is there any documentation which describes which commands select and deselect tools without running there respective free, pre and post macro's?
                                      I will investigate this. Note, you can define what M0 does by creating a stop.g file.
                                      The intention is that the tool change macros are always run, unless one of the following is true:
                                      1. One or more axes are flagged as not having been homed;
                                      2. You use the T command with a P parameter to specify that you do not want some of the tool change files to be run.
                                      In any other situation, not running tool change files on a tool change is a bug.
