PT 100 not working
did you do the Troubleshooting part of?
https://duet3d.dozuki.com/Wiki/Connecting_PT100_temperature_sensors#mainand you double checked that you used the right one of the 3 headers and its in the correct orientation?
I used the reference page you mention and followed the procedure, my daughter board did not come with the 100Ω resistor so no i didnt do the troubleshooting as described. I have plugged a normal thermistor cartrage into the threaded hole with some extra wire to firm up the connection and that works fine for testing the extruder but of course not suitable for actual printing.
can you post a quick pic of your daughter board and wiring please I have an idea but need to see a pic before I comment also make sure the daughter board is sitting correctly on its headers?
@dougal1957 Sorry i'm used to drag and drop, dont understand the antiquated methods used here to display a pic, but heres a link to a quick vid https://youtu.be/VGM_1qKaR1g
i just switched to rtd2 to see if that would help but no.
that looks to be fine to me only thing I can think is that you may either have a faulty port in which case you could try RTD2 and change to X201 or you have wired it up incorrectly it is hard to tell (and very easy to get wrong) if you use the same colour wiring.
It looks like you have taken four wires to the sensor so you need to check that pins 1 and 2 are a pair and 3 and 4 are the other pair.
other than those 2 ideas I am not sure what to suggest
@dougal1957 Perhaps a faulty PT100 sensor or daughter board.
@brian possible I guess but I would try the other channel first
@dougal1957 done that
next step I guess is to get a 100 ohm resistor to check the daughter board ports!
@dougal1957 where am i going to get that?
check the resistance of your pt100 with a multimeter
ok thanks
