Short to ground on driver 3
887
    Veti
    which duet?
    have you measured the resistance of each wire of that stepper?
      falcar
      A maestro. No I haven't done anything like that
        If you only get that report occasionally, it probably means that you are using stealthchop at too high a speed on that driver. Are you using firmware version 2.02 ?
          falcar
          Yes I'm on 2.02. This is the first time I've seen it. Which driver is 3?
            Driver 3 is the one labeled E0. What M569 P3 command do you have in config.g, if any? If you send M569 P3 with no additional parameters, what does it report?
              falcar
              In my config.g:
              Command run:
              2:31:16 PMM569 P3
              Drive 3 runs forwards, active low enable, step timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, tpwmthrs 2000 (1.0 mm/sec)
              undefined 1 Reply Last reply 22 Apr 2019, 19:39 Reply Quote 0
                dc42 administrators @falcar
                @falcar, those values look OK to me.
                Are you quite certain that there isn't an intermittent short circuit? Sometimes when crimping a wire, one strand can escape being crimped and cause a short to an adjacent pin. Also check that the back of the Duet can't be shorting against something underneath it.
                How long is that stepper motor cable, and what sort of cable is it? It might be that a cable with a particularly high capacitance between the wires or to ground could trigger the short-circuit detection.
                To check whether the reports are related to stealthChop, you could put the extruder into spreadCycle mode by adding parameter D2 to your M569 P3 command in config.g, and see whether that stops the reports.
                  falcar
                  The wire isn't very long. It's one I purchased off of Amazon. I will check to make sure there are no wires loose or shorting.
                  I'll also try the other mode too if I don't find anything.
                  If I discover the problem will this error have caused any irreparable damages ?
                    Veti
                    stealthchop2 can be problematic on the extruder as it will skip easily
                    add M569 P3 D2 to your config to disable stealthchop for the extruder.
                      falcar
                      Rewiring seems to have solved the issue. For safety sake I think I will also remove stealthchop.
                      Thanks guys!
                      Any idea a good source to purchase more of them connector ends? I used all of the ones that came with my wifi on my maestro!
                      undefined 1 Reply Last reply 25 Apr 2019, 07:24 Reply Quote 0
                        Veti
                        depends on how low you want to wait. search amazon for KF2510 set
                          @falcar said in Short to ground on driver 3:
                          See https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers for the connector part numbers.
                          11 out of 13
