    motor phase A may be disconnected reported by driver(s) 0 1 2
    3.1k
      Do the warnings appear only when you run the motors at high speeds? What are your axis steps/mm?
      • fredvmundefined
        fredvm
        No, i don't think so. I'm running at an avereage speed of 45 mm/s.
        M92 X80 Y80 Z80 ; Set axis steps/mm
        i'll put my full config.g below:
        ; Configuration file for SeeMeCNC Rostock MAX V3
        ; Communication and general
        M111 S0 ; Debug off
        M550 PSeeMeCNCRostockMAXV3 ; Machine name and Netbios name (can be anything you like)
        M551 Retteket3t ; Machine password (used for FTP)
        ;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
        M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xEA ; MAC Address
        ;*** Wifi Networking
        M552 S1 ; Enable WiFi
        M555 P2 ; Set output to look like Marlin
        M575 P1 B57600 S1 ; Comms parameters for PanelDue
        G21 ; Work in millimeters
        ; Axis and motor configuration
        M569 P0 S1 ; Drive 0 gaxioes forwards
        M569 P4 S0 ; Drive 4 goes forwards
        M574 X2 Y2 Z2 S1 ; set endstop configuration (all endstops at high end, active high)
        ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration
        M665 R144.158 L291.06 B120 H392.701 X0 Y0 Z0 ; set delta radius, diagonal rod length, printable radius and homed height
        M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
        M350 X16 Y16 E16 I1 ; Set 16x microstepping with interpolation
        M906 X1000 Y1000 Z1000 E1200 I60 ; Set motor currents (mA) and increase idle current to 60%
        M201 X1000 Y1000 Z1000 E1000 ; Accelerations (mm/s^2)
        M203 X20000 Y20000 Z20000 E3600 ; Maximum speeds (mm/min)
        M566 X1200 Y1200 Z1200 E1200 ; Maximum instant speed changes mm/minute
        ; Thermistors
        M305 P0 T100000 B3950 R4700 H30 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
        M305 P1 T100000 B3974 R4700 H30 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
        ;M305 P2 T100000 B3974 R4700 H30 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction
        M570 S180 ; Hot end may be a little slow to heat up so allow it 180 seconds
        M106 P1 H-1 ; disable thermostatic mode for fan 1
        ; Tool definitions
        M563 P0 D0 H1 ; Define tool 0
        G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
        ;*** If you have a single-nozzle build, comment the next 2 lines
        ;M563 P1 D1 H2 ; Define tool 1
        ;G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
        M92 E450:450 ; Set extruder steps per mm
        ; Z probe and compensation definition
        M558 P5 X0 Y0 Z1 H5 F1200 T2400
        ; grid compensation
        M557 R110 S15
        G31 X0 Y0 Z-0,5 P500 ; Set the zprobe offset and threshold (determine your printer's Z offset value). For a delta, use zero X and Y offset.
        ;*** If you are using axis compensation, put the figures in the following command
        M556 S78 X0 Y0 Z0 ; Axis compensation here
        M501;
        T0 ; select first hot end
          Phaedrux Moderator @fredvm
          @fredvm said in motor phase A may be disconnected reported by driver(s) 0 1 2:
          Your M350 is missing a value for Z and your M92 is missing a value for E
          • fredvmundefined
            fredvm
            M350
            wow, thanks for noticing that!
            I'll add the right values and see what happens.
            • fredvmundefined
              fredvm
              Nope, still got the warning:
              G32
              Warning: motor phase A may be disconnected reported by driver(s) 0 1
              Warning: motor phase B may be disconnected reported by driver(s) 0 1
              • wilrikerundefined
                wilriker @Phaedrux
                @phaedrux said in motor phase A may be disconnected reported by driver(s) 0 1 2:
                Just for the sake of completeness: default value for M350 is 16x interpolated (all axes) and default for M92 Ennn is 420 (X, Y=80 and Z=4000).
                Manuel
                My Tool Collection
                • Vetiundefined
                  Veti @wilriker
                  @wilriker said in motor phase A may be disconnected reported by driver(s) 0 1 2:
                  not 400?
                  • wilrikerundefined
                    wilriker @Veti
                    @veti said in motor phase A may be disconnected reported by driver(s) 0 1 2:
                    not 400?
                    Here's the responsible part of Configuration.h
                    constexpr float DefaultXYDriveStepsPerUnit = 80.0;		// steps/mm
                    constexpr float DefaultZDriveStepsPerUnit = 4000.0;
                    constexpr float DefaultEDriveStepsPerUnit = 420.0;
                    Manuel
                    My Tool Collection
                    • Vetiundefined
                      Veti
                      i would say that might be an oversight. 400 is way more common than 4000. I dont even know how you would get that.
                      • wilrikerundefined
                        wilriker @Veti
                        M5 threaded rod with a lead of 0.8mm. I think this was the default in Mendel printers - and Adrian Bowyer the original author of RRF is also the creator of that printer. I guess that setting stuck since. 😄
                        Manuel
                        My Tool Collection
                          Phaedrux Moderator @wilriker
                          @wilriker Having used a printer with 0.8mm M5 threaded rod I can say that it actually worked quite well. So long as the rods were straight and the threads of the rod and nuts held out. Proper lubrication was a must. Those things would get hot during a long Z axis move.
                            I have moved a number of posts from this thread to topic "Duet sometimes really slow? - I2C error or?".
