    IR Probe False Reading
    • Synapsisundefined
      Synapsis
      I 'm having a problem lately with the IR Probe which while probing will give a IR Probe reading at 33 an stops thinking its homed but at least 6mm from the bed then i move it up 0.05 and home again and then it will home correctly starting at 464 then 540 when its close to the bed.
      Now this was happening a few days ago then stopped but today it started again.
        Have you tried cleaning the sensor with some isopropyl?
        • Synapsisundefined
          Synapsis
          No but will do so now. Thanks for the suggestion.
          • Synapsisundefined
            Synapsis
            Ok still not working , Question is why do I have a reading of 29 to 33 when the bed is even a 150mm down.
            Shouldn't it be zero or over 1000 when very far away from the bed?
              dc42 administrators @Synapsis
              @synapsis said in IR Probe False Reading:
              Yes. A reading of around 30 suggests to me that you have a bad connection between the IR sensor and the Duet.
