IR Probe False Reading
    Synapsis
    I 'm having a problem lately with the IR Probe which while probing will give a IR Probe reading at 33 an stops thinking its homed but at least 6mm from the bed then i move it up 0.05 and home again and then it will home correctly starting at 464 then 540 when its close to the bed.
    Now this was happening a few days ago then stopped but today it started again.
      Have you tried cleaning the sensor with some isopropyl?
        Synapsis
        No but will do so now. Thanks for the suggestion.
          Synapsis
          Ok still not working , Question is why do I have a reading of 29 to 33 when the bed is even a 150mm down.
          Shouldn't it be zero or over 1000 when very far away from the bed?
          undefined 1 Reply Last reply 4 May 2019, 10:25 Reply Quote 0
            dc42 administrators @Synapsis
            @synapsis said in IR Probe False Reading:
            Yes. A reading of around 30 suggests to me that you have a bad connection between the IR sensor and the Duet.
            3 out of 5
