Duet homing on Ender 5
Firmware installation
1.4k
    Brian_K
    Thanks, I’ll implement your changes. However as I cannot even get the printer to home yet I haven’t looked at the extruder.
    I did put in some conservative setting to give me time to switch the printer off should anything go awry, which it did with the home test macro.
    Not sure those changes will do anything to get the printer to home, is there anything else I need to look at?
      jay_s_uk
      Have you checked the endstop status to ensure you have set them up correctly and they trigger correctly using M119?
        Brian_K
        I haven’t ran an M119 yet (print head won’t reach the endstops). The endstop LED’s are lit up and go out when I depress each endstop switch - does that sound correct?
        undefined 1 Reply Last reply 2 May 2019, 10:17 Reply Quote 0
          jay_s_uk
          No. They should light when triggered, not the other way round.
          Hence using M119. If it says triggered when not triggered, you need to swap your endstops round in the firmware. It would stop you from homing.
            Brian_K
            Excellent, thanks, I'll do that later today and report back.
              dc42 administrators @Brian_K
              @brian_k said in Duet homing on Ender 5:
              If they are normally closed switches (the most common type), then that's correct. But check that the Duet is reading them correctly, using M119.
                Brian_K
                Sorry, just to be clear, do you mean switch the endstops from “Active Low (NO)” to “Active High (NC)” in the RRF config tool?
                Or should I switch the wires over on the connectors?
                David, thanks I'll do that first when I get back from lunch.
                  Melfesto
                  Active High (NC) and at low end should fix it. Also make sure your end stop cables are right to.
                    Brian_K
                    M119 is producing a comment of "Not Stopped" on X,Y and Z axis.......also on Z probe, which I did not set up???
                    Should I go ahead with Active High at low end?
                      Melfesto
                      I don't have my Z probe setup yet so can't comment as to what that should be set for but the other stops I am running are from the original ender 5 and I have mine all set to Active High (NC) and at low end and they all work fine on the duet 2 wifi.
                        Brian_K
                        Thanks, not worried about the Z probe yet, just want to get the printer running.
                          Brian_K
                          It is with great pleasure that I can inform fellow forum members that the printer is now functioning as expected. Setting the endstops to active high at the low end did indeed do the trick.
                          For reference the endstop LED’s are on and go off when the switches are activated.
                          Many thanks one and all for your input.
                          14 out of 16
