    Indication of print in progress
    1.6k
    • rubillosundefined
      rubillos
      I guess I could do start and stop in the slicer gcode, but also have the codes in pause/cancel/resume.
      Was hoping there was a start macro... there's always poking around in the source code and doing a custom build 🙂
        Another way would be to configure the RPi as an HTTP client and have it make rr_status requests to the Duet. The response includes whether or not a file is being printed.
        rubillosundefined 1 Reply Last reply Reply Quote 0
        • DocTruckerundefined
          DocTrucker
          The automatic call of an optional start.g gcode does seem like an ommision. @dc42 is there anything on the horizon?
          • rubillosundefined
            rubillos @dc42
            @dc42 has having start.g and end.g files ever been considered? Is there any reason not to have those?
              DocTrucker @rubillos
              @rubillos end.g = stop.g
              • rubillosundefined
                rubillos
                And that is also called when a print is canceled?
                DocTruckerundefined dc42undefined 2 Replies Last reply Reply Quote 0
                  DocTrucker
                  The http method @dc42 recommends has a few benefits.
                  • No extra wiring or failure points.
                  • If in the (unlikely) event of a process hang the http will stop responding and you can cancel your capture.
                    @rubillos https://duet3d.dozuki.com/Wiki/Macros#Section_Pause_stop_and_power_fail
                      dc42 administrators @DocTrucker
                      @doctrucker said in Indication of print in progress:
                      I implemented this many releases ago.
                      DocTruckerundefined rubillosundefined 2 Replies Last reply Reply Quote 0
                        dc42 administrators @rubillos
                        @rubillos said in Indication of print in progress:
                        No, cancel.g is called instead.
                          DocTrucker @dc42
                          @dc42 documentation hasn't caught up yet.
                          • rubillosundefined
                            rubillos @DocTrucker
                            @doctrucker True. That might be the way to go... I'll have a look at modifying my time-lapse code.
                            There are just so many I/O pins on the Duex5, seemed like an easy thing to hook up 🙂
                            • rubillosundefined
                              rubillos @dc42
                              @dc42 So start.g is called when a print starts?
                                Yes, whenever a print from SD card starts. I have updated the documentation at https://duet3d.dozuki.com/Wiki/Macros.
                                rubillosundefined 1 Reply Last reply Reply Quote 1
                                • rubillosundefined
                                  rubillos @dc42
                                  @dc42 Awesome! Thank you!
                                    @resam has a raspberry pi camera solution as well, though I can't seem to find the thread at the moment.
                                      Here it is: https://forum.duet3d.com/topic/6058/timelapse-pictures-videos-with-duet-and-webcam-on-layer-change
                                      • rubillosundefined
                                        rubillos @Phaedrux
                                        @phaedrux Thanks for the link!
