Extruder Motor Stuttering
did you change the cable as well?
most of the time the pinout of the motors are not the same. -
I purchased both of the motors (old and new) from "StepperOnline".
Both are wired (pined) the same. -
That looks and sounds like pressure advance to me. What does M572 output during printing?
also there are only 1.68A and 2A bipolar 0.9 stepper motors from steppersonline.
75% of those does not equal the 1A you configured.which one did you purchase.
Thanks again for your reply.
I purchased stepper Part # 17HM19-2004S.
2.80 VOC
2.00A
0.90 Step AngleDo I have an incorrect setting in my config.g's M906?
On the reprap G-code wiki M574 is the command used to set endstop configuration?
@vacalos M572, corrected
I think you are correct.
After watching the printer closely during a print, I can see that the 'stutters" coincide with a change in direction in the X-Y plane. This motion is obviously intentional and probably due to pressure advance as you suggested. I guess I never watched the extruder gears closely enough to have noticed that motion before. Thanks for the advise.
What would you suggest an acceptable Pressure Advance setting is for a bowden tube approximately 500mm long?
you will have to measure the pressure advance for your printer yourself. As each setup is different.
There are threads on this forum about pa calibration. -
As already suggested, it very much depends on the machine. It could be anywhere from 0.1 to 1.0. After running some calibration from these forums, pay attention to your prints. Blobby corners -> increase PA. Rounded corners -> decrease PA. Make sure the Bowden tube sits as firmly as possible.
