    Duet wifi 24 V short - Ethernet Module VERY hot.
    1.8k
      That's right. Download DuetWiFiSocketServer version 1.23 from the Releases section of https://github.com/dc42/RepRapFirmware. Rename it to exactly DuetWiFiSocketServer.bin and copy it to the /sys folder of the SD card. Put the SD card in the Duet, restart the Duet and send M997 S1 from YAT or a GCode sending program.
      EdChamberlainundefined 1 Reply Last reply Reply Quote 1
      • EdChamberlainundefined
        EdChamberlain @dc42
        @dc42 The duet is up and running again! I never thought it would work again. Thanks a ton for the help.
        I am having a slightly strange issue with the web interface though. Wherever there are SDcard contents on display it will load the contents repeatedly in the list. The lists listing things like macros or gcodes just keep growing repeating the contents of the SD card.
        I only have one Gcode (test.g) and it just keeps loading it over and over as fast as it can so the list is effectively endless! See example: https://imgur.com/a/yCz6RWn
          Phaedrux Moderator @EdChamberlain
          @edchamberlain It sounds like you may be using an out of date version of the DWC.
            EdChamberlain
            My current setup is:
            Firmware Version: 1.21 (2018-03-21)
            WiFi Server Version: 1.21
            Web Interface Version: 1.22.6
            Im not sure if those versions are all correct as I cant find version numbers on the releases page. Is it worth moving up to 2.X yet?
              Yes I think you're going to want to upgrade to 2.02 for the main firmware and 1.23 for the wifi server. The 2.02 release should have all you require.
                EdChamberlain
                Do I just drop the binary into the web updater and let it work some magic or are there some more steps?
                  The full procedure is here: https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
                  But in your case, going from 1.21 to 2.02 is pretty straight forward. You can upload the two main firmware and wifi server firmware bin files in the settings page and it should install them both for you.
                  Once you are on the 2.0 branch you will be able to complete future upgrades by simply uploading the entire zip file and it will do the rest.
                    EdChamberlain
                    I find that page somewhat confusing! Am I right just going straight to 2.02 or do i need to go via 2.0?
                    So upload DuetWiFiServer-1.21.bin and Duet2CombinedFirmware.bin ?
                    What about DuetWebControl-1.22.3.zip?
                      You should be able to go straight to 2.02.
                      You already have the updated DWC files, so you won't need to upload those again.
                      For the wifi server you'll want https://github.com/dc42/RepRapFirmware/releases/download/2.02/DuetWiFiServer-1.23.bin
                      and the combined firmware file is indeed the one you want.
                        EdChamberlain
                        Seems to be all updated! Thanks a lot.
                        Now just to build the rest of the printer....!
                        • VoodooBaneundefined
                          VoodooBane @EdChamberlain
                          @edchamberlain said in Duet wifi 24 V short - Ethernet Module VERY hot.:
                          @voodoobane Youre Right! I forgot to flash the firmware to the wifi board (Doh!). Have done that now and can confirm after forgetting my wifi password a few times it is now working! I can accsess the DWC and will now assume it is fully working.
                          Your welcome! I didn't think it was be that easy you know? hahaha I am really you glad you got it working!
