    Duet Wifi - G29 causes extremely rapid Z movement and head crash
    1.5k
      M558 P9 H5 F1200
      Your probing speed is an order of magnitude faster than it should be for the BLTouch. Try F120 instead. This is in addition to the change Veti has suggested.
      • lowracerundefined
        lowracer
        Thanks for the tips. I re-tried the G29 with the speed and probing settings suggested. Now it goes slowly enough that I can see more detail of what is happening.
        During the slow rising of the bed, the BLTouch lights up red and is not extending its metal probe as it usually does at the beginning of a print.
        Also, simultaneously with the Z axis motion, the Y axis is moving ever so slowly to the left.
          Does the probe work if you go through this procedure?
          https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
          • lowracerundefined
            lowracer
            Those linked tests work, M401 & M402 behave as expected, G30 properly extends the probe, raises the bed slowly and detects the bed with the probe, then stops.
            To clarify, this printer is working and has been working very well to make prints, always using BLTouch probe before printing. It's just that the G29 is behaving oddly. And it hasn't always been this way because I'm using G29 S1 in the startup GCODE of each print to load up a heightmap generated from a previous G29 some time ago.
              Phaedrux Moderator @lowracer
              @lowracer said in Duet Wifi - G29 causes extremely rapid Z movement and head crash:
              That is very odd behaviour and I can' explain why it would be doing that, but then homing fine.
              • lowracerundefined
                lowracer
                I'm suspecting something scrozzled the firmware. Will try re-flashing new firmware tonight to see if that fixes it.
                • lowracerundefined
                  lowracer
                  Reflashing firmware did not fix the problem, unfortunately.
                    Can you post a video of it in action?
                    • lowracerundefined
                      lowracer
                      Here's a dropbox link to the video of the G29 operation in action (7.78MB .mp4):
                      https://www.dropbox.com/s/u8qfz1u7khgt8f5/G29 UM2%2B Duet Wifi.mp4?dl=0
                      • Vetiundefined
                        Veti
                        please post all your homing scripts.
                        • lowracerundefined
                          lowracer
                          Flashed firmware up to 2.03RC1, G29 still exhibits the same behavior. Here are the homing files as requested:
                          ; homex.g
                          ; called to home the X axis
                          ; generated by RepRapFirmware Configuration Tool on Fri Mar 15 2019 21:53:32 GMT-0700 (Pacific Daylight Time)
                          G91 ; relative positioning
                          ;G1 Z5 F6000 S2 ; lift Z relative to current position
                          G1 S1 X-228 F9200 ; move quickly to X axis endstop and stop there (first pass)
                          G1 X5 F6000 ; go back a few mm
                          G1 S1 X-228 F360 ; move slowly to X axis endstop once more (second pass)
                          ;G1 Z-5 F6000 S2 ; lower Z again
                          G90 ; absolute positioning
                          ; homey.g
                          ; called to home the Y axis
                          ; generated by RepRapFirmware Configuration Tool on Fri Mar 15 2019 21:53:29 GMT-0700 (Pacific Daylight Time)
                          G1 S1 Y228 F9200 ; move quickly to Y axis endstop and stop there (first pass)
                          G1 Y-5 F6000 ; go back a few mm
                          G1 S1 Y228 F360 ; move slowly to Y axis endstop once more (second pass)
                          ;homez.g
                          G91 ; relative mode
                          G1 S1 Z210 F7000 ; move Z towards the switch until it triggers
                          ;G1 S2 Z-5 F100 ; move Z back 5mm
                          ;G1 S1 Z10 F100 ; move Z slowly towards the switch until it triggers
                          G90 ; back to absolute mode
                          ; homeall.g
                          ; called to home all axes
                          ;home Z to max extent (bottom of enclosure) first
                          G91 ; relative mode
                          G1 S1 Z250 F7000 ; move Z towards the switch until it triggers
                          G1 S1 X-228 Y228 F9000 ; move quickly to X and Y axis endstops and stop there (first pass) (was F1800)
                          G1 X5 Y-5 F7200 ; go back a few mm
                          G1 S1 X-228 Y228 F360 ; move slowly to X and Y axis endstops once more (second pass)
                          G1 X110 Y110 F7200 ; go to first probe point (approx center of bed)
                          ;G30 ; home Z by probing the bed
                          ;G91 ; relative positioning
                          ;G1 S2 Z5 F100 ; lift Z relative to current position
                          ;G90 ; absolute positioning
                          • Vetiundefined
                            Veti
                            you move your bed up by 250mm? why
                            you disabled your probing of the bed. so no wonder the probe is not deploying.
                            lowracerundefined 1 Reply Last reply Reply Quote 1
                            • lowracerundefined
                              lowracer @Veti
                              @veti said in Duet Wifi - G29 causes extremely rapid Z movement and head crash:
                              Thanks for the response.
                              Original Ultimaker 2+ (UM2+) behavior (no BLTouch) has the bed "zero" to the bottom of the case before printing and after print is completed. Moving it 250 sends down it to where it will trip the Z endstop at the bottom of the cage.
                              The problem described in the original post occurs when issuing a G29 command from the web interface. I was not aware these homing scripts get called by the G29 command.
                              I commented out that G30 because I do not want "homing" behavior to include probing the bed. I have that done in the startup script in the GCODE of the file being printed, e.g.:
                              G28 XY ;Home XY
                              M561 ; Clear any bed transform that might be in place
                              G1 X104.5 Y130 ; Move Probe to middle of bed
                              G30 ; Do a single probe
                              G29 S1; load heightmap
                              G1 Z20.0 F6000 ; Move Z to 20
                                So before you run G29 it needs to accurately know where Z0 is. If you are homing to Zmax, how confident are you that When you move the bed back up Z0 will mean the nozzle is touching the bed? Are you running a G30 before doing G29?
                                • lowracerundefined
                                  lowracer @Phaedrux
                                  @phaedrux said in Duet Wifi - G29 causes extremely rapid Z movement and head crash:
                                  Bingo. That fixed it.
                                  Thanks for the help. Got a new heightmap generated and printing away.
