Video of delta 4th additional axis sidekick extruder
Firmware developers
delta additional axis flying extruder
    Hutch118
    I wanted to share a video showing an additional axis on a delta functioning under Release 2.03RC1. Everything seems to be working as intended.
    https://youtu.be/QESD63zZh6g0_1557436580866_IMG_20190509_161552409.jpg
      jay_s_uk
      Where did you get your smart effector mount from?
      undefined 1 Reply Last reply 10 May 2019, 06:52 Reply Quote 0
        Hutch118 @jay_s_uk
        @jay_s_uk I got it from: https://713maker.com/rostock/duet-smart-effector-adaptor
          Looks good! But can't the Bowden tube be made a lot shorter, if you tilt the extruder so that the filament outlet is horizontal or 45deg down, instead of what looks like 45deg up?
          undefined 1 Reply Last reply 10 May 2019, 13:16 Reply Quote 0
            Hutch118 @dc42
            @dc42 said in Video of delta 4th additional axis sidekick extruder:
            I believe you're right on a lower angle. It was a big leap for me with all the added complexity - the extruder carrage falls when the motors are not energized pulling the effector down by the bowden. So I was playing it safe until I can work around that. I will probably end up moving the extruder mount to overhang the bed a bit and get the bowden angle closer to overhead.
            The firmware is really great - it basically just worked straight away with minor effort. I was shocked at it's ease of flexibility - and the added motion is highly enjoyable to watch! Thanks for developing the firmware this is great!
            undefined 1 Reply Last reply 7 Nov 2019, 13:40 Reply Quote 1
              veryevil @Hutch118
              @Hutch118 Hi, sorry to dig this up but did you ever publish your code or push it back?
              Thanks
              Steven
