    Video of delta 4th additional axis sidekick extruder
    Firmware developers
    delta additional axis flying extruder
    • Hutch118undefined
      Hutch118
      I wanted to share a video showing an additional axis on a delta functioning under Release 2.03RC1. Everything seems to be working as intended.
      https://youtu.be/QESD63zZh6g0_1557436580866_IMG_20190509_161552409.jpg
        jay_s_uk
        Where did you get your smart effector mount from?
        Hutch118undefined 1 Reply Last reply Reply Quote 0
        • Hutch118undefined
          Hutch118 @jay_s_uk
          @jay_s_uk I got it from: https://713maker.com/rostock/duet-smart-effector-adaptor
            Looks good! But can't the Bowden tube be made a lot shorter, if you tilt the extruder so that the filament outlet is horizontal or 45deg down, instead of what looks like 45deg up?
            • Hutch118undefined
              Hutch118 @dc42
              @dc42 said in Video of delta 4th additional axis sidekick extruder:
              I believe you're right on a lower angle. It was a big leap for me with all the added complexity - the extruder carrage falls when the motors are not energized pulling the effector down by the bowden. So I was playing it safe until I can work around that. I will probably end up moving the extruder mount to overhang the bed a bit and get the bowden angle closer to overhead.
              The firmware is really great - it basically just worked straight away with minor effort. I was shocked at it's ease of flexibility - and the added motion is highly enjoyable to watch! Thanks for developing the firmware this is great!
              veryevilundefined 1 Reply Last reply Reply Quote 1
              • veryevilundefined
                veryevil @Hutch118
                @Hutch118 Hi, sorry to dig this up but did you ever publish your code or push it back?
                Thanks
                Steven
