    Delta printing PVDF
    1
    221
    • andornotundefined
      andornot
      Finally moved my delta to the fume cupboard to print PVDF. If the PVDF over temperatures 300 plus then it can give off Hydrogen Fluride, nasty gas.
      Printing PVDF at 260 degrees, 60 degree bed on glass with 3dluc to aid adhesion, speed 15mm/s with 0.4mm retract. Good material to print, bonds very well between layers.
      We are using the PVDF as it is chemically compatible with solvents we are using the prints for. Below are some pictures of the setup.
      SpatialOne custom delta printer, upgrading to print PEEK, PEKK & Ultem
