    Duet sometimes really slow? - I2C error or?
    Other control boards
    13
    147
    17.6k
    • wilrikerundefined
      wilriker @deckingman
      @deckingman said in motor phase A may be disconnected reported by driver(s) 0 1 2:
      From what I have been able to discover, the earliest thread regarding this issue is from around July 2018. There are no threads or posts reporting I2C errors prior to that date.
      Now, that might be of importance. I checked and in July 2018 RRF 2.01beta1 was released. This means up until RRF 2.0 no one at least reported I2C issues and this at least hints to something change between 2.0 and 2.01beta1.
      @dc42 You know your changes best. Is there anything in 2.01beta1 that persists until this day and also might be responsible for these issues?
      Or was M122 simply only extended to include these numbers? Changelog lists a couple of modifications to M122 but non regarding I2C.
      EDIT: found the discussion in the thread mentioned by @deckingman above and see that there are already cases with RRF 2.0.
      Manuel
      My Tool Collection
        deckingman
        @wilriker Yes. As I stated in the other thread that I linked to, it seems that there were no reports of any of these issue which can be associated with I2C misbehaviour until around the same time that the firmware changed to RTOS. It could of course be pure coincidence but it's the only common denominator that I have been able to find across multiple users with multiple generations of boards. Mine are of the very first pre-production boards, both Duet Ethernet and Duex5, and which had no problems from when I got them in December 2016 until around July 2018. Other users who have reported similar problems have more recent hardware.
        • fulgundefined
          fulg @deckingman
          @deckingman Thank you for this, I was feeling quite alone! I have since downgraded to 2.01, as I know 2.02 is also affected by this (I was discussing with someone else on Discord with the same printer / same problem and they are using 2.02).
          I tend to upgrade RRF only when non-beta/non-RC versions are available, I don't know why I upgraded to 2.03beta3. Last year I was turning off the motors after each print, it is only recently that I've started to keep the steppers powered all the time.
          EDIT: 2.03beta3 not RC3, this is especially important to get this right now that RC1 actually exists.
          VORON V2 CoreXY + Duet3 Mini5+ Ethernet v1.0 with Mini2+ expansion, VORON V0 CoreXY + Duet2 Maestro
            deckingman @fulg
            @fulg The earliest known report of similar issues was in this thread https://forum.duet3d.com/topic/6077/inconsistent-delays-during-homing-and-other-movements and the OP of that thread stated that he was using RRF 2.0. When I first reported my own experiences of these issues I was using 2.01 (RTOS) (2018-07-26b2). Of course, it may just be coincidence that there are no reports of any similar issues with firmware which pre-dates the 2.0 RTOS series.
            fulgundefined 1 Reply Last reply Reply Quote 0
            • fulgundefined
              fulg @deckingman
              @deckingman I found the other threads later and noticed the problem also occurs in 2.0. I had hopes when seeing the I2C resistors hack but sadly you later confirmed it does not fix this problem.
              I will leave my 2.01 setup running for now until the next occurrence (to validate Duex detection with M115 after a soft reset, as asked in another thread), and then downgrade again to 1.21.
              The repro is easy for me, I just leave the steppers powered all the time. As I said before my setup is somewhat unique in that I have 4 Z motors on the Duex that are constantly moving, most printers are not built like that. Sometimes I get the error within a few hours but so far I've always reproduced it with 1 or 2 days of having the steppers powered-but-idling.
              I have never seen the problem occur when turning off the steppers after each print (even if the printer itself stayed on), although I suppose it could have happened mid-print and I was just lucky until now.
                deckingman @fulg
                @fulg For me, it's a bit different. I've only had one or two print failures, neither of which was more than a few of hours long. Usually, I get the failure quite soon after powering up the printer during the first homing moves or shortly after. On many occasions that has been after the printer has been idle pwered down for a few days. I have had the issue during homing, cycled the power, then homed again and done a 30 plus hour print without further problems. The way it manifests itself is long pauses between moves but not reports of motor phase errors.
                It's this randomness, that makes it so hard to track down. Many users report different problems. Some have the Duex5 board well populated, others have only a few things connected. The only thing in common between users is the I2C errors.
                  deckingman
                  In case anyone is following this thread but not one of the other I2C error related threads, I can now confirm that running M199 to reset the firmware fixes the issue so no need to cycle the power. At least that's how it is for me.
                  I can also confirm that when running M115 immediately after M999, it reports that the Duex5 is present. Since I had the error and ran M199 to restart the firmware, without powering down, I've re-homed the printer and it is now happily printing away (at least for now).
                    dc42 administrators @deckingman
                    Thanks for confirming this. Now all I need to do is find a way to reproduce the problem so that I can test possible fixes.
                      deckingman @dc42
                      @dc42 said in motor phase A may be disconnected reported by driver(s) 0 1 2:
                      Best of luck with that !!. I certainly can't find a way a reproduce it - I wish I could. It seems to me like it's just something that randomly happens. But I'm more than happy to try anything you can think of to provoke it.
                      BTW, the print I started after restarting the firmware using M999 was a tad under 4 hours and completed without any further I2C errors or problems.
                        deckingman
                        I thought I might have found a way to provoke the misbehaviour but now I'm not so sure.
                        I started by doing exactly the same thing as yesterday but without physically changing a roll of filament. That is, turn on printer, home all, drop bed 100mm using DWC, extrude 300mm of filament a 5mm/sec using DWC, retract 1mm, home all again. During the second home all, I got the dreaded pauses and I2C errors just like yesterday. I cleared this by resetting the firmware then ran M115 which confirmed that the Duex5 was recognised. Then ran the entire sequence again but this time, I didn't get any issues. The only thing different was that on the second run, I didn't start with the printer powered off. I'll try this when I get time later.
                        • kazolarundefined
                          kazolar
                          I had fitted my duex5 with 2.2k resistors, and have a very beefy and super short ground lines. I could not get to working on the machine due to hiwin rails being on backorder, now everything is assembled, I was running calibration movements to level out the heads and I had exact same thing happen, machine started moving slowly, i2c timeouts. I had previously tried toggling the fans repeatedly to try to trigger i2c timeouts or errors, and i2c was fine, the behavior that triggered it is switching tools and having that tool move to center to verify z alignment. Basically I'm virtually guaranteed to trigger i2c timeouts during a calibration session (about an hour of positioning) anything else I should do?
                          • dragonnundefined
                            dragonn @dc42
                            @dc42 I don't have a Duex but it seems this is a never ending story with the I2C timeouts. Did you consider doing a small redesign of Duet and Duex to use a chip like PCA9615?
                            I think event without a twisted pair cable at this length it should it should greatly increase resistance to any interference.
                            Just my 2 cents, I know it will not help existing users but could help in the future.
                              dc42 administrators @dragonn
                              @dragonn said in Duet sometimes really slow? - I2C error or?:
                              Yes I expect the use of those chips would help. But it would require a redesign of both the Duet and the DueX, and new Duets wouldn't be compatible with older DueX boards, or vice versa.
                              As well as the extra I2C pullup resistors, another hardware change that might help is to put series resistors of around 100 to 180 ohms each in the two I2C conductors in the ribbon cable. If this works, it would be an easy change for us to make to future DueX boards.
                              I'm about to set up a Duet/DueX5 with a deliberately bad ground connection, to see if I can provoke this problem.
                              Ian has shown that when the problem occurs, the I2C subsystem can be recovered without a hardware reset. So recovering from this error should be possible.
                              Martin1454undefined dragonnundefined 2 Replies Last reply Reply Quote 0
                              • Martin1454undefined
                                Martin1454 @dc42
                                @dc42 said in Duet sometimes really slow? - I2C error or?:
                                Well a power cycle is a hardware reset even if it is done using SW to initiate it I think? Or were there any other SW way of recovering other than power cycle?
                                  @martin1454 said in Duet sometimes really slow? - I2C error or?:
                                  There is another thread which has gone OT to be about this same issue. In that thread, Ian said at https://forum.duet3d.com/post/9349:
                                  I am assuming that Ian meant M999, not M199.
                                  Martin1454undefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                                    Martin1454 @dc42
                                    @dc42 ah okay - Will try a M999 next time
                                    • kazolarundefined
                                      kazolar
                                      @dc42 whatever it's worth, whenever I've encountered this behavior a reboot via the stop button on the screen doesn't help.
                                      Also I never ran into these slow behaviors until upgrading to 2.05/7, I will try the code base from prior to the code rewrite. 07 seems making it worse where the end stops just stop working instead of just being slow. Also I can't see how I can make my ground connection any better, literally as short a run as possible, I can't fit a thicker set of wires into a ferule (that would fit into the terminal block) than what's on there now.
                                        deckingman @dc42
                                        Ooops - yes indeed I did mean M999. I managed to type M999 correctly one time out of three ☺
                                        • dragonnundefined
                                          dragonn @dc42
                                          Two jumpers on Duet and Duex that could be used to bypass the PCA chip would allow compatibility with older hardware. I know this adds an extra complexity but it maybe worth it.
                                            deckingman
                                            I might be homing in on a way to provoke this problem but it's difficult. For the third day running I've been able to get it to happen at exactly the same point.
                                            The sequence is as my post above but I have to start with the machine powered off and it has to have been powered off over night. It only happens once a day. If I power down the machine and start the sequence again, it won't misbehave a second time but for 3 days running I've been able to do exactly the same sequence and get exactly the same problem at exactly the same point in the sequence. I've had my suspicions that it seems more likely to happen after the machine has been powered down for a considerable time but I have no idea why that should be. Capacitance that takes a long time to decay?? Not my area of expertise.
                                            For 3 days running, the problem has started at the same point in the second iteration of my homeall file. So to reiterate, the sequence is as follows:
                                            1. Turn on machine and connect to DWC (usig Firerfox)
                                            2. Run home all through DWC
                                            3. Drop bed 100mm through DWC
                                            4. Heat hot end to 190 deg C
                                            5. Extrude 300mm of filament through extruder 0 at 5mm/sec using DWC (as if loading a new reel of filament).
                                            6. Retract 1mm at 5mm /sec through DWC
                                            7. Run home all again through DWC.
                                            My home all file is pretty complicated. Here it is in it's entirety with the point where the I2C errors (or at least the pauses between moves) occur, marked.
                                            TO; select a tool - any one will do
                                            M104 S140; heat to 140 but don't wait
                                            ;*****Home XYUV (lower 2 gantries)
                                            M584 X0 U3 Y1 V4 P5; temporarily map drives to U and V axes
                                            M906 X400 U400 Y400 V400 Z1200 ; reduce motor currents
                                            G91 ; set to use relative coordinates
                                            G1 Z5 F600 ; move bed down 5 mm
                                            G1 X-380 U-380 Y-380 V-380 F4800 S1; move all 4 axes fairly quickly until one or other triggers a switch
                                            G1 X-380 U-380 F4800 S1; now move just X and U fairly quickly left until one or other triggers a switch
                                            G1 X-380 S1; course home X
                                            G1 U-380 S1; course home U
                                            G1 X10 U10 F600 ; Go back a few mm
                                            G1 X-380 U-380 F360 S1; Move slowly to X and U axis endstops once more and stop when one triggers
                                            G1 X-380 F360 S1 ; fine home X
                                            G1 U-380 F360 S1 ; fine home U
                                            G1 Y-380 V-380 F4800 S1; now move Y and V fairly quickly until one or other triggers a switch
                                            G1 Y-380 S1; course home Y
                                            G1 V-380 S1; course home V
                                            G1 Y10 V10 F600; Go back a few mm
                                            G1 Y-380 V-380 F360 S1; Move slowly to Y and V axis endstops once more and stop when one triggers
                                            G1 Y-380 F360 S1 ; fine home Y
                                            G1 V-380 F360 S1 ; fine home V
                                            ;****Now home upper Gantry
                                            M584 X6 Y9 ; map upper motors to X and Y
                                            M574 X1 S1 C5 ; map end stop 5(E2) to X axis
                                            M574 Y1 S1 C6 ; map end stop 6 (E3) to Y axis
                                            G1 X-380 Y-380 F4800 S1; move X and Y fairly quickly until one or other switches triggers
                                            G1 X-380 F4800 S1 ; course home X
                                            G1 Y-380 F4800 S1 ; course home Y
                                            G1 X10 Y 10 F600 ; back off a few mm
                                            M574 X1 S1 C0 ; put X axis end stop switch back to standard mapping
                                            M574 Y1 S1 C1 ; put Y axis end stop switch back to standard mapping
                                            M584 X0:3:6 Y1:4:9 Z2 U10 V11 E5:7:8 P3; Put axes motors back to standard configuration
                                            ;******Now home Z
                                            G90; set to absolute coordinates
                                            G1 X180 Y180 F12000; move to more or less the centre of the bed
                                            M109 S140 ; continue heating hot end to 140 but this time wait
                                            ;change to faster probing speed
                                            M558 F450
                                            G30 ; FAST home Z using values from G31
                                            *********This is the point where pauses due to to I2C errors become apparent
                                            G91 ;relative
                                            G1 Z5 F300 ; lower bed
                                            G90 ;absolute
                                            ;change back to slower probing speed
                                            M558 F180
                                            G30 ; SLOW home Z
                                            G91 ;relative
                                            G1 Z5 F300
                                            G90 ; back to absolute
                                            M906 X1800 U1800 Y1800 V1800 Z1800 ; set motor currents back to defaults
                                            M104 S0; set hot end temp back to zero
                                            End of home all file.
                                            I'll try the entire sequence of power up, home, drop bed, extrude and repeat home again tomorrow to see if I can provoke it for the 4th day in succession.
