    Can't deploy BLTouch clone (3D Touch) Duet 2 Wifi
    2.3k
    • Vetiundefined
      Veti
      post your deployprobe file
      • Oct_opusundefined
        Oct_opus
        Hi veti,
        here it is:
        ; deployprobe.g
        ; called to deploy a physical Z probe
        ; generated by RepRapFirmware Configuration Tool v2 on Sat May 11 2019 10:43:23 GMT+0200 (Central European Summer Time)
        M280 P7 S10 I1
        • Vetiundefined
          Veti
          try the self test using
          M280 P7 S120 I1
          • Oct_opusundefined
            Oct_opus
            Still nothing 😕
            I wonder if the probe being able to self test at boot but not deploying it manually shows that its either my wiring or an error in the config?
            Here are the product info if it might help:
            Solenoid Push-pin Up servo signal 90Degree(ex : M280 P0 S90 )
            Solenoid Push-pin Down ➡ servo signal 10Degree(ex : M280 P0 S10 )
            Manual Self-test ➡ servo signal 120Degree(ex : M280 P0 S120)
            Alarm Release ➡ servo signal 160Degree(ex : M280 P0 S160)
            3D printer z-probe Touch can be operated in the following condition.
            • One I/O (PWM or Software PWM) for control
            • One I/O for Zmin
            • GND and +5V power
              If you use this on an Anet A8 then you need to cross over the YELLOW & BLUE wires. Couldn't figure out why it wouldn't work until I read the head unit. The Yellow is the endstop and the Blue is the pwm input, I just cut them and reversed them
            Thanks
              Can you post a photo of your wiring between the probe and the Duet?
                A Former User
                The P0 parameter in the product info needs to be adapted to whichever pin you used on your Duet.
                But just to cover the basics, when you power on the printer the probe deploys and retracts a few times, and has a steady red light after?
                Oct_opusundefined 1 Reply Last reply Reply Quote 0
                • Oct_opusundefined
                  Oct_opus
                  Hi, yes here it is
                  Imgur album
                  • Oct_opusundefined
                    Oct_opus @A Former User
                    @bearer The probe deploys and retracts a few times at boot and then has a steady blue light
                    • Vetiundefined
                      Veti
                      switch the blue and yellow wire
                      • Oct_opusundefined
                        Oct_opus @Veti
                        @veti
                        I'v switched the yellow and blue wires,
                        with and without the resistor between blue and black wire as well
                        still blue led and nothing 😕
                        • Oct_opusundefined
                          Oct_opus
                          @Veti @dc42 @bearer Thank you very mutch for you help I have found my error It is sad sorry 😓 0_1557651607251_IMG_0018.JPG
                          • Exerqtorundefined
                            Exerqtor
                            The next question now is if you get a trigger signal from that 3DTouch, I've seen several people having problem's on FB groups the last couple weeks including me 🐷
                            • Oct_opusundefined
                              Oct_opus @Exerqtor
                              @exerqtor I can get it to deploy and work but some time the probe extends two times and other times it does not trigger when colliding with the bed 😓
                              Here is a video
                              Video on imgur
                              Exerqtorundefined 1 Reply Last reply Reply Quote 0
                              • Exerqtorundefined
                                Exerqtor @Oct_opus
                                @oct_opus
                                Tbh i just think those sensors are next to snakeoil 😂 Given how cheap the real probes are, it's not worth the potential headache and anoyance any of the knocnoffs can make.
                                A Former User? 1 Reply Last reply Reply Quote 2
                                  A Former User @Exerqtor
                                  Some are hampered by steep fees and taxes when importing stuff, clones are usually declared incorrectly and/or below a duty free limit - I think that makes a bigger difference than $15 clone vs $50 real probe, the latter could easily be closer to $100 by the time it is delivered to me.
                                  But thanks to your comment, I checked out their site and found their Ali Express store had a sale, $35 shipped, below the free import limit - yay!.
