Ajax error after bed probe
1.7k
    Sniffle
    the "Auto Bed Correction" enacts your Bed.g file so yes it does whatever you set it to.
      StephenRC
      @bendy:
      Note that this issue also occurs after using the "Auto Bed Correction" button from the Machine control page (which I am guessing just does some flavour of a G32 in the background)
      Check your bed.g file, there may be a bad gcode in there.
        What we really need to see is the json message that provoked the error. Can you provide a Wireshark pcap file?
          bendy
          Here are the contents of my bed.g -
          [[language]]
          ; bed.g
          ; generated by RepRapFirmware Configuration Tool on Sun Nov 27 2016 09:59:20 GMT+1100 (AEDT)
          ; Clear any bed transform
          M561
          ; Probe the bed at 4 points
          G30 P0 X75 Y110 H0 Z-99999
          G30 P1 X345 Y110 H0 Z-99999
          G30 P2 X345 Y355 H0 Z-99999
          G30 P3 X75 Y355 H0 Z-99999 S
          I will get a packet trace done later on and post it up.
            bendy
            Quick update - I have manually executed the commands in bed.g and the first 4 commands work fine, it is only when the last line -
            [[language]]
            ```Is executed that the system crashes. The probe works as expected but I am guessing when the calculation of the Z plane is done it is causing an issue. I have tried it with both S and S4 with the same result. Packet trace still to come.
              Jackal
              Your probe points have to been in a clockwise order, starting nearest to 0,0
                bendy
                OK, Another update - the Ajax error is masking some other error here related to z plane calculation by the looks of it - If I run the probe for 3 points it works fine, it only fails if I do it for 4 points (am running a cartesian setup so 4 points should be supported?)
                  Qdeathstar
                  @Jackal:
                  Is that true? DC42's calibration calculator suggestions points starting at the z-tower, then moving clockwise moving towards 0,0 with the last probe being 0,0…. should i rearrange the probes?
                    lignumaqua
                    Your sequence is anti-clockwise instead of clockwise, I suggest trying:
                    G30 P0 X75 Y110 Z-99999 ; Bottom Left
                    G30 P1 X75 Y355 Z-99999 ; Top Left
                    G30 P2 X345 Y355 Z-99999 ; Top Right
                    G30 P3 X345 Y110 Z-99999 ; Bottom Right
                    G30 P4 X210 Y232 Z-99999 S0 ; centre, and calibrate compensation
                      Jackal
                      @Qdeathstar:
                      @Jackal:
                      The calibration calculator is for Deltas. For Cartesian machines, you need them in clockwise order.
                      I stumbled upon a similar discussion before, you can find them by searching 'clockwise' in the forum.
                        bendy
                        OK, looks like going clockwise fixed it
                        12 out of 13
