    Idiots guide to splash screen
    PanelDue
    897
    • Stevoundefined
      Stevo
      Hi all wondered if one of you would help me out please I have resized an image to 800 x 480 as a bmp then run it though the erscher converter and now have a bin file of that.
      I’m struggling to understand how I integrate this into the 5”-7” int without logo bin
      Ihave both files on the desktop tried many times to the instructions on github I’m just not getting it
        Are you getting an error message?
        You do have to be careful about getting the file names correct.
        • Stevoundefined
          Stevo
          Hi J
          My Logo is WILE E COYOTE and named WILE E.bin the file has converted fine to a bin file and is on the desktop along with the original file for the PanelDue-5.0i-7.0i-nologo.bin
          So instruction is to "Run this Windows command to append it to the binary: copy /b PanelDue-v3-5.0-nologo.bin+myimage.bin PanelDueFirmware.bin"
          I am entering the following at the command prompt and its not working.
          copy /b PanelDue-5.0i-7.0i-nologo.bin+WILE E.bin PanelDueFirmware.bin
          I receive an error message
          Really sorry if Im explaining it badly i think Im nearly there just the letter is throwing me.
          Your help much appreciated.
          • PaulHewundefined
            PaulHew
            It could be that there are spaces in your filename.
            Copy the file to something simple say WILEE.bin and try the command line again.
            HTH
            Paul
            Stevoundefined 1 Reply Last reply Reply Quote 1
            • Stevoundefined
              Stevo @PaulHew
              @paulhew Thanks Paul
              • Stevoundefined
                Stevo
                Should the program for converting the bitmap to bin actually open up
                  No it's all command line only
                    A Former User
                    its good practice to avoid spaces in file names, but if you do use them, then quotes or escaping them is necessary on the command line.
                    copy /b PanelDue-5.0i-7.0i-nologo.bin + "WILE E.bin" PanelDueFirmware.bin would likely work.
                    • Stevoundefined
                      Stevo
                      Thank you all for your help have now got to grips with it much appreciated!
