    [solved] : Issue with standard ATX_PSU and PS_ON pin
    2.6k
    • Pumluxundefined
      Pumlux
      Is anyone using the PS_ON functionality with the Duet Wifi and can provide some details how he has wired it ?
      I have currently no clue what might be wrong here.
      Using a own build of a Mendel Max , Duet Wifi, Bed 8 mm Aluminium PEI 500 x 280 x 400 230 V 850 W, original E3D Chimera hotend with bowden length 700 mm, since short time with a BL-Touch, Steppers : mostly Nema 17 and one Nema 23 for Y-axis
        In case it's a firmware issue, please make the connection between PS_ON and your PSU again, send M80 and then measure the voltage on the PS_ON pin. It it still shows 5V then I think your Duet is faulty.
        • Pumluxundefined
          Pumlux
          Hi David,
          thanks for the advice.
          PS_ON signal seems to be working, but a bit different than from the 0.8.5.
          I connected the PS_ON , +5 V BSB and GND to the external 5 V connector and the Duet Wifi is powered.
          I can use the M80 to power the PSU and M81 to power off, I can do the same with the ATX buttons from the Duet web frontend.
          Power ATX on and off.
          But I can not controll the PS_ON signal with just a short triggering of the PS_ON to GND like on the 0.8.5.
          Looks like the default behavior on the Duet Wifi is PS_ON off and on the 0.8.5 was PS_ON on.
          Is there a different way (pin) that I can use to have a normal power on hardware button ?
            I'll check the firmware. Have you tried putting a M80 command at the start of config.g?
            • Pumluxundefined
              Pumlux
              I just tried it.
              I have put the command M80 into the first line of the config.g file.
              This works as expected, when pressing the push button for > 3 seconds. Looks like the Duet Wifi needs some seconds for booting
              up and reading the config.g file.
              May be some change of the hardware design is responsible for the different default behavior of the board during powering on.
              Anyhow it works now as expected, many thanks for your fast support David.
              update
              One thing I need to mention. If the M80 command is inserted into the config.g file and +5V VSB ( standby) power is conencted, you can not switch off the board by
              doing a reset, as after reset the config.g is read and the board powered complete on again. So this is only a solution in a case like mine, powering on via push button.
              Regards
              Andreas
                I have just checked the code, and the firmware starts up with the ATX power pin not active (and has done for many versions). So what I don't understand is how it worked for you on the Duet 0.8.5, if you didn't have a M80 command in config.g before.
                • peridotundefined
                  peridot
                  I'd like to point out that there's an easier way to try to use the PS_ON pin: supply the Duet with an always-on 5V. Then the Duet can freely switch the ATX supply on or off as needed without affecting its own ability to execute commands or respond to WiFi. ATX supplies provide such an always-on 5V supply, so people using an ATX supply can easily do this.
                  It sounds like you're trying to do something trickier: allow the Duet to turn itself off completely. For that you have to keep the power on until the Duet can command it to stay on, as you have discovered.
                    I think that a long time ago, I may have had the firmware start up with ATX power enabled, but I changed it to disabled because of user requests. Perhaps that was to avoid power getting turned on when you apply USB power.
                      T3P3Tony administrators
                      It certainly makes more sense to not turn ATX power on until commanded to do so.
                      I have extended the Power Supply section of the documentation a bit in light of this thread:
                      https://duet3d.com/wiki/Power_wiring#Standby_power
                      • Pumluxundefined
                        Pumlux
                        One short update here, may be a info that could go into the wiki also.
                        I use the switched +5 V power ot the ATX PSU to power the Duet and for switching on the duet I need to
                        keep the PS_ON lead from the ATX PSU grounded manually for ~3 seconds, after the blue LED near the wifi module
                        flashes a bit brighter and goes off.
                        Than the duet PS_ON pin goes to GND and I can release my mechanical push button.
                        Note : I decided to go this way, because I do not want all the electronics to consume power without any purpose.
                        I have (currently) no plan/need to switch the printer on remotely without being there to watch the print start.
