Retraction seams to be reversed
1.3k
    Need a lot more information.
    Board version? Firmware? config.g? Slicer settings? Pictures? Video?
    undefined 1 Reply Last reply 12 Feb 2019, 01:32 Reply Quote 0
      gavatron3000
      For me this occurred on S3D v4.1.0. However 4.1.1 has been excellent
        pr0xyfl00d3r @Phaedrux
        @phaedrux said in Retraction seams to be reversed:
        Duet 2 Wifi, v1.04.
        0_1549934973886_config-3.g
        Simplify3d is 4.1.1
        I will try do a video later
        undefined 1 Reply Last reply 12 Feb 2019, 01:35 Reply Quote 0
          Phaedrux Moderator @pr0xyfl00d3r
          @pr0xyfl00d3r looks like your extruder acceleration is 10000 and 80mms retraction is quite fast. I wonder if the motor is perhaps skipping or stuttering which maybe looks like it's going in reverse? Try reducing e acceleration to say 3000.
          Also try disabling wipe.
          undefined 1 Reply Last reply 12 Feb 2019, 01:43 Reply Quote 0
            Ok will give it a go.
              gavatron3000
              I see your esteps are up near 800. You might be over speeding your stepper. With my old bondtech qr I wasnt able to go much past 50mm/s and I was around 500 steps that was roughly 500rpm at the stepper
              undefined 1 Reply Last reply 18 Mar 2019, 15:15 Reply Quote 0
                pr0xyfl00d3r @gavatron3000
                @gavatron3000 said in Retraction seams to be reversed:
                I have an E3D Titan with the compact stepper they sell which in the documentation they say to start of with 837 but after running some config test with extruding some material I found that E797.332 was good,
                I got this after testing extruding 100mm of filament.
                  pr0xyfl00d3r
                  Also during the print when it comes to the point when its about to change layers extra material comes out leaving a lil bump that the nozzle hits
                    From your config.g:
                    M201 X3000.00 Y3000.00 Z250.00 E10000.00 ; Set accelerations (mm/s^2)
                    10000 is a very high acceleration for an extruder, especially with steps/mm as high as 800. Try reducing it.
                      NAK_3D
                      I'm having this same issue with the White Knight belt printer.. Was a solution ever determined?
