M203 Printing Max Speed
    totalitarian
    How do we define the max speed when printing? I use slic3r which unfortunate doesn't allow you to set the Z speed and as a result, it moves far too fast on z hop moves.
      dragonn
      Just put M203 ZXXX; XXX is speed in mm/min
      Into config.g
      undefined 1 Reply Last reply 26 May 2019, 18:25 Reply Quote 0
        totalitarian @dragonn
        @dragonn I already have it in there, but it's set too 200mm/s (nice speed for homing), I don't want to print at that speed though.
        undefined 1 Reply Last reply 27 May 2019, 08:36 Reply Quote 0
          dragonn
          Then just put M203 Z12000 into homing files end at the end restore it to a lower value at the end of hooming.
          BTW 200mm/s on a z-axis??? This sounds wrong all the way, unless you z-axis is belt driven.
          undefined 1 Reply Last reply 26 May 2019, 18:31 Reply Quote 0
            @dragonn That could be the answer, thanks! It's a belt driven delta yes
              dc42 administrators @totalitarian
              @totalitarian said in M203 Printing Max Speed:
              Z hop moves are short, so it won't get up to anything like full speed because of the acceleration limit. What makes you think that the Z hop is too fast?
              On my delta I normally use 0.3mm of Z hop, with the Z speed configured at 250mm/sec and acceleration 2000mm/sec^2.
              1 out of 6
