    M203 Printing Max Speed
    • totalitarianundefined
      totalitarian
      How do we define the max speed when printing? I use slic3r which unfortunate doesn't allow you to set the Z speed and as a result, it moves far too fast on z hop moves.
      • dragonnundefined
        dragonn
        Just put M203 ZXXX; XXX is speed in mm/min
        Into config.g
        totalitarianundefined 1 Reply Last reply Reply Quote 0
          totalitarian @dragonn
          @dragonn I already have it in there, but it's set too 200mm/s (nice speed for homing), I don't want to print at that speed though.
          • dragonnundefined
            dragonn
            Then just put M203 Z12000 into homing files end at the end restore it to a lower value at the end of hooming.
            BTW 200mm/s on a z-axis??? This sounds wrong all the way, unless you z-axis is belt driven.
              @dragonn That could be the answer, thanks! It's a belt driven delta yes
                dc42 administrators @totalitarian
                @totalitarian said in M203 Printing Max Speed:
                Z hop moves are short, so it won't get up to anything like full speed because of the acceleration limit. What makes you think that the Z hop is too fast?
                On my delta I normally use 0.3mm of Z hop, with the Z speed configured at 250mm/sec and acceleration 2000mm/sec^2.
