    is this build too ridiculous?
    16
    1.1k
    • Vetiundefined
      Veti
      @zapta said in is this build too ridiculous?:
      Will the x/y lead screws allow you to move the head fast enough?
      see (unfortunately in german)
      https://www.thingiverse.com/thing:2929869
      he uses ball screws for x and y and says he achieves 100mm/sec on y with 12v
      the speed will depend on the lead of the ball screw.
      the stepper motors should be fine.
      see
      https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors
      Duet 2 WiFi and Duet 2 Ethernet (maximum motor current 2.4A) => Stepper motor rated current <= 3.0A
      if the weight of the table is too much for the motor you can try a geared stepper motor like
      https://www.omc-stepperonline.com/economy-planetary-gearbox/nema-23-stepper-motor-bipolar-l76mm-w-gear-raio-41-planetary-gearbox-23hs30-2804s-pg4.html
      or if that is not enough
      https://www.omc-stepperonline.com/economy-planetary-gearbox/nema-23-stepper-motor-bipolar-l76mm-w-gear-raio-151-planetary-gearbox-23hs30-2804s-pg15.html
      • Vetiundefined
        Veti
        also there is the duet3 that should be out sometime this year.
        the driver of those will support at least 4A (and maybe even more depending on the actual setup)
        kaduhn1undefined 1 Reply Last reply Reply Quote 1
        • kaduhn1undefined
          kaduhn1 @zapta
          @zapta They have a 5mm pitch which is pretty fast- faster then the normal acme m8 screws that are used.
          I've removed as much material as possible while still keeping it rigid- it's just a big table so weight comes with it- plus we already have a large sheet of milled cast aluminum.
          we've looked at large format printers- they're expensive- specially for how much it would get used. The stratasys machine that is big enough is 180K. we're trying to stay under 5K because we won't need a business case and can just order parts here and there.
          • kaduhn1undefined
            kaduhn1 @Veti
            @veti said in is this build too ridiculous?:
            Looks like they had early production samples a few months ago- so hopefully soon. that would definitely open my options up for bigger motors/ enough power
            I use nema23 stepper motors here for testing products and they get going fast very quickly. I'd thin speed shouldn't be an issue
            • Vetiundefined
              Veti
              not quite the size you need, but i assume you had a look at the
              https://folgertech.com/collections/3d-printer-full-kits/products/folger-tech-ft-6-3d-printer-kit
              • Vetiundefined
                Veti
                or not quite the 5k (6k)
                http://www.modix3d.com/tech-spec/?affcode=aniw
                120X build volume – 1200 X 610 X 610 mm
                kaduhn1undefined 1 Reply Last reply Reply Quote 0
                • kaduhn1undefined
                  kaduhn1 @Veti
                  @veti this is a good option but by the time its all said in done with options and shipping it's over 8K. which makes it so we have to have a business case and ROI vs under 5k we can just piece it together with any leftover monthly budget. it also takes away from building one myself which is half the fun.
                  i'll definitely look into it more though.
                  • Vetiundefined
                    Veti @kaduhn1
                    @kaduhn1 said in is this build too ridiculous?:
                    yes of course. and getting paid to do it is a bonus.
                    • DocTruckerundefined
                      DocTrucker @kaduhn1
                      @kaduhn1 is there no cheaper z motor without an encoder? Unless you're planning someting fancy its only contribution to the system will be a tiny amount of inertia.
                      Edit: Scrub that comment. Encoder ready, not encoder fitted.
                      • Danalundefined
                        Danal
                        Have you considered a large delta? I built a 600 dia (24") by 620 Z for about $1100 that produces EXCELLENT results. One of the advantages of delta for large printers is that the "table" does not move. This becomes a HUGE advantage as printers scale (<=pun intended).
                        I'm using a 24" glass table for a bed. $40 on Amazon (US). 6mm thick. Custom Keenovo heater stuck to the bottom (about $200 to have custom made).
                        You said 2 feet by 3 feet by 1 to 1.5 feet. How about 3 feet dia by 3.5 Z? That would be slightly larger than my printer... I chose a lot of my scaling by choosing 1 meter HWIN Clone slides. That was an arbitrary decision. 3 or 4 feet diameter, and a little more proportional Z, should be easily achievable with 2 meter slides (and appropriate frame size).
                        Yeah, it freaks people out that they are tall. As long as you are not trying to run a large farm that has multi-level shelving, or have some other ceiling constraint... if not, then so what?
                        Anyway, if you want to think about this at all, play with this calculator. Here's and example set for 3' diameter, and 3"4" Z:
                        http://danalspub.com/DKcalc/?he=655&ve=1500&dr=720&lr=1000
                        • mrehorstdmdundefined
                          mrehorstdmd
                          That heavy bed system may require something special to prevent it from dropping when power is cut (as well as some help lifting it in the first place). I used a Rino 30:1 worm drive to lift the bed with belts in my corexy machine, but it could easily be applied to lead screw drive, too. The worm gear prevents bed motion when the motor is powered off, which means it should be possible to resume a print after power failure, etc. The Rino has an integral NEMA-23 motor that's easily driven by a Duet board and very high quality gears.
                          • Arkadiuszundefined
                            Arkadiusz
                            You can get nema 23 motors in low current version, they are rated 1.8A but must be powered with at least 24v PSU
                              Instead of moving a large bed up and down, what about a Voron2 style XY gantry that lifts in Z. If I was going to do a printer that size, that's what I would do. http://vorondesign.com/voron2.1
                              For anything larger I'd probably do an X axis gantry that moved in Y and Z with stationary bed. Like a gantry crane.
                              • kaduhn1undefined
                                kaduhn1 @mrehorstdmd
                                @mrehorstdmd definitely saved that page- probably a good idea regardless. thanks
