    bug in french mode I7 paneldue
    PanelDue
    1.6k
      dc42 administrators @PaulHew
      The top right one is "Connection en cours" which in English is "Connecting".
      The other ones that are likely to be too long are "Téleverser le firmware" and "Changement d'outil".
      • E1ixirundefined
        E1ixir
        There's another bug in french translation: when duet is connected, the top right corner indicates "Connectéenpause" au lieu de "Connecté".
        To shorter "Ventilateur 0%" I would rather go for "ventilo 0%" . "Le fan" seems very strange to me (maybe Canadian translation?).
        • E1ixirundefined
          E1ixir
          To shorter "Connection en cours", you can just state for "Connection", which is sufficient.
          fmaundefined 1 Reply Last reply Reply Quote 0
          • E1ixirundefined
            E1ixir
            To translate "téléverser le firmware", I can suggest: "flasher firmware.
            For "changement d'outil" I would say "changer outil".
              dc42 administrators @E1ixir
              @e1ixir said in bug in french mode I7 paneldue:
              Can you provide a photo of this, and confirm which firmware version you are using? I can't find the text "Connecté" in the source code.
              Thanks, I will update those in the next firmware build.
              E1ixirundefined lenain31undefined 2 Replies Last reply Reply Quote 0
              • fmaundefined
                fma @E1ixir
                In french, it is 'Connexion', not 'Connection'!
                You could add dots, after, to show it is in progress: 'Connexion...'
                Frédéric
                • E1ixirundefined
                  E1ixir
                  @fma : you're right, sorry, I made a mistake. Right spelling is "connexion..."
                  • E1ixirundefined
                    E1ixir @dc42
                    @dc42 said in bug in french mode I7 paneldue:
                    @dc42 , my firmware is 1.23. Seems that this bug does not appear at every print... Couldn't manage to take a screenshot of it today. Will show you as soon as it will reappear
                    • E1ixirundefined
                      E1ixir
                      Hello @dc42,
                      Well, it did it again.
                      Seems that sometimes PanelDue is showing 2 different status at once: here you can see "Occupé" and "Pause" at the same time.
                      • lenain31undefined
                        lenain31 @dc42
                        @dc42 or "liaison en cours"
                        • E1ixirundefined
                          E1ixir
                          There is another mispelled word on this screenshot: please write "matière" instead of "matiére"
                            I've made a note to investigate this and I've fixed a possible cause. Is your firmware 1.23.2 or plain 1.23 ?
                            Thanks, I've just corrected the source code.
                            I can provide you with a temporary new firmware build if you would like to check these changes. Which PanelDue do you have?
                            E1ixirundefined 1 Reply Last reply Reply Quote 0
                            • E1ixirundefined
                              E1ixir @dc42
                              @dc42 said in [bug in french mode I7 paneldue](/post/97497
                              hello David,
                              M'y firmware is 1.23.2
                              yes, my pleasure.
                              I have PanelDue 7 with a separate controller board (V3)
                              Thanks you very much for these improvements
                                Please try https://www.dropbox.com/s/fvrtfd2hrhdn8te/PanelDue-v3-7.0.bin?dl=0.
                                • E1ixirundefined
                                  E1ixir
                                  Hello David,
                                  Well I tried this new firmware, which seems much better.
                                  However, I noticed some issues again:
                                  • The "OccupéPause" issue is still there. See: 0_1560072581052_IMG_20190608_155224.jpg
                                  • On the "Setup" screen, I noticed a large number of very weird translations ☺ ☺ ☺ To make it much better , I can propose:
                                         "Affichage en négatif"   => "Mode miroir"
                                         "Calibre touch"  => "Calibrer écran"
                                         "Effacer paramêtre"  => "Réinitialiser"
                                         "Inverser affichage" => "Ecran inversé"
                                          "Toujours dim" => "Veille écran"
                                          "Jamais dim"   => "Pas de veille"
                                          "idle dim" = > "Veille auto"
                                           "fond blanc" => "Thème clair"
                                           "fond noir 1" => "Thème sombre 1"
                                           "fond noir 2" => "Thème sombre 2"
                                           "Volume x" =>  "Volume son x"
                                  • On the "Control screen" could you change the "macro" label by "macros"
                                  ... And finally, I couldn't find anywhere the "Téléverser le firmware" (= > "Flasher firmware") and "Changement d'outil" (=> "Changer outil") labels you were talking about the other day:
                                    I'll add this to the work list, but it may be some time before I work on PanelDue again. You can find the full list of language strings at https://github.com/dc42/PanelDueFirmware/blob/master/src/Strings.hpp.
                                    • E1ixirundefined
                                      E1ixir @dc42
                                      @dc42 , thank you very much, David for all the work you do.
