    Requested speed is not reached
    6.3k
    • PuddingBaer91undefined
      PuddingBaer91 @Veti
      @veti said in Requested speed is not reached:
      @puddingbaer91 said in Requested speed is not reached:
      M305 P0 T100000 B4138 C0 R4700 X2 ; Set thermistor + ADC parameters for heater 0 and remap it to channel 2
      M143 H0 S80 ; Set temperature limit for heater 0 to 80C
      M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
      M143 H1 S250 ; Set temperature limit for heater 1 to 250C
      the tronxy x5s on marlin uses thermistor table 1
      which is
      // R25 = 100 kOhm, beta25 = 4092 K, 4.7 kOhm pull-up, bed thermistor
      4138 is the default in the configurator. so you might be printing at the wrong temperature
      interesting what do i have to change here?
      is this right?
      M305 P1 T100000 B4092 C0 R4700
      • Vetiundefined
        Veti
        the ender 3 uses epocs 100k as well
        see
        https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+2:+Configuration/38
        step 7 (the r2200 is maestro specific)
          PuddingBaer91
          sorry i forget that i use this thermistor: https://www.ebay.de/c/22025877022
          Phaedruxundefined Vetiundefined 2 Replies Last reply Reply Quote 0
            Phaedrux Moderator @PuddingBaer91
            That's a heating cartridge.
            • Vetiundefined
              Veti @PuddingBaer91
              that is some random other stuff. not a genuine e3d thermistors
              according to a comment on amazon
              https://www.amazon.de/NTC-Thermistor-Patrone-V6-Hotend-Prusa-i3-RepRap-3D-Drucker/dp/B077MLDBF1
              the beta value for that is 4276
              edit:
              it might be a semitec 104-GT
              https://atcsemitec.co.uk/wp-content/uploads/2019/01/Semitec-NT-4-Glass-NTC-Thermistor.pdf
              in that case use
              β: 4725 K
              C : 7.060000e-8
                PuddingBaer91
                4276
                hey thank you for your help. I asked the seller for data. Also ordered PT100 daugtherboard and PT100 sensor. Will inform you if i have new results
                  PuddingBaer91
                  because i can't wait for the new sensor i have done the calibration for pressure advance again at 245°C and i ended up somewhere at 0.8 - 0.9. It really seems to be a temperature problem.
                  Could you tell me if the temp read out drops or goes up by lowering the B value? Because you found out lower values i am interested in if this is the right direction for getting lower temps so i have to heat up more...
                    Increasing the beta value reduces the temperature reading, for temperatures above 25C. Therefore, if you think the hot end temperature is lower than the reading, increase the beta. If you think the hot end temperature is higher than the reading, reduce the beta.
                      PuddingBaer91
                      Today i installed the PT100 sensor and now it's much better. Now i need a pressure value of 0.7. But another problem is the higher Extruder jerk (600mm/min instead of 300). Because of this i hear the extruder and that sound is not cool as with jerk=300. But to get the full speed i need a higher value like you said. Using Bondtech extruder.
                      Do you ignore this sounds and is it normal? I read some articles where people use 3000mm/min but i can't imagine how terrible this will sound... Is there another thing i have to adjust to get rid of this sounds?
                        deckingman @PuddingBaer91
                        ................But another problem is the higher Extruder jerk (600mm/min instead of 300). Because of this i hear the extruder and that sound is not cool as with jerk=300. But to get the full speed i need a higher value like you said. Using Bondtech extruder.
                        600mm/min (10mm/sec is still far too low IMO). I use 3600 mm/min and run Bondtech BMGs (5 of them). I'd expect that with extruder jerk set to 3000+ then you might even be able to get PA down further. What sort of sound do you get? Is it a clicking noise or something else?
                        P.S. I haven't looked at this thread for a while but you seem to have made good progress since I spotted that you were using crazy high PA.
                        PuddingBaer91undefined 1 Reply Last reply Reply Quote 1
                          PuddingBaer91 @deckingman
                          @deckingman said in Requested speed is not reached:
                          thank you i will try. What acceleration you use for bmg extruder?
                            Bear in mind that I have 5 BMGs feeding a Diamond "mixing" hot end so my settings might not be relevant to your situation but this is what I use.
                            M92 X80 Y80 U80 V80 Z3200 E409:403:407:405:403 ; steps per mm
                            M566 X1200 Y1200 U1200 V1200 Z100 E3600:3600:3600:3600:3600 ; maximum instantaneous speed (mm/min)
                            M203 X50000 Y35000 U50000 V35000 Z450 E3600:3600:3600:3600:3600 ; maximum speeds (mm/min)
                            M201 X1000 Y1000 U1000 V1000 Z100 E3600:3600:3600:3600:3600 ;accelerations (mm/s^2)
                              PuddingBaer91
                              600:3600:36
                              thank you. I wonder why we need these high values. Even the Ultimaker2 only uses 300mm/min for e-jerk?!?
                              see: https://github.com/Ultimaker/Ultimaker2Marlin/blob/master/Marlin/Configuration.h
                                So what? The Ultimaker2 also has a cantilevered bed that flops around like a field or corn in a breeze. Unless you set it on a concrete slab, you'll likely upset the layer height just by walking past the printer. So I wouldn't hold it up as being any sort of standard to which all printers must aspire (good marketing hype though).
                                On the subject of E "jerk", the only time it will come into play is either when pressure advance is used or if it is set lower than the instantaneous speed threshold of the X or Y motors. In that case, all it does is slow the entire print down. "Jerk" is the speed threshold to which axes and the extruder must slow down before a change of direction can occur. In RepRap firmware (which the Duet uses), "Jerk" is not applied to the start of a move from zero speed - only when the print head is moving and there is a change of direction. So before a change of direction can occur, the printer will slow down to the lowest "jerk" speed of either X, Y or E. So unless you want the print head speed to be controlled by extruder "jerk" rather than X or Y "jerk", then set it higher than those two axes. ("Axes" in this case is the plural of "axis" - not something that is used to chop wood) ☺
                                  PuddingBaer91
                                  000
                                  i made a video to show what my extruder sounds like with these high jerk values @ PA=0.6:
                                  https://photos.app.goo.gl/jUapfqh28hwszUDT8
                                  It's like the extruder will blow up in a few seconds.
                                  Can't belive you print also with these sounds. Also the print is not possible as you see. Even with pa=0.1 it makes these sounds
                                    @puddingbaer91 None of my BMGs make that noise. The movement is visually the same as yours but not the sound. I'd say there is something loose somewhere. Maybe the hobbed gear on the shaft? Maybe the Bowden fitting inside the housing? Maybe worn teeth? Or maybe it's just the Bowden tube a bit loose in the fitting. You need to take the extruder apart and investigate.
                                      dc42 administrators @deckingman
                                      I guess there is also a chance that the motor current is too low to provide the required torque, causing the motor to skip steps when jerk is applied. What motor are you using, and what extruder motor current have you set?
                                        PuddingBaer91
                                        There should be nothing loose.
                                        I use These ACT steppers:
                                        https://www.roboter-bausatz.de/2554/act-nema-17-schrittmotor-17hs5425l20p1-x2
                                        Current in Data Sheet is 3.1 Ampere
                                        It's in German i Hope Google can help
                                        Current ist set to 1300mA.
                                        • Vetiundefined
                                          Veti
                                          see
                                          https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors
                                          So the usual practice is to set the motor current to no more than about 85% of the rated current. Therefore, to get maximum torque out of your motors without overheating them,
                                          also
                                          Duet 2 WiFi and Duet 2 Ethernet (maximum motor current 2.4A) => Stepper motor rated current <= 3.0A
                                            PuddingBaer91
                                            Okay Data seems to be wrong on the Website. My Motor ist labeled with 2.5A
                                            https://photos.app.goo.gl/CSqKTi9TxJZBSTX27
                                            Should i ran the Motors near 85% ? 2A?
