    Short-to-ground on drivers - Please help
    673
    • YanivKundefined
      YanivK
      Did not find any short on the board
      • Vetiundefined
        Veti
        first its always a good idea to update to the latest firmware.
        second. post the motor specifications.
        also check the resistance of each phase of the motors. they could be damaged.
        • YanivKundefined
          YanivK
          @yanivk said in Short-to-ground on drivers - Please help:
          All Motors all phases resistance 2.4-2.5 Ohm
          Will try to update firmware
          • Vetiundefined
            Veti
            are you sure the specs are correct? 2.4Ohm vs 1.5Ohm
            if you are sure that it is correct. adjust the motor current to 85% or the rated current(1.7A). you currently run them at 800mA
            • YanivKundefined
              YanivK
              I tested then on the wire end. without the wire it's 1.9-2.0 ohm
              I am trying to understand what file do i need for the firmware update: is it Duet2Firmware-2.03.zip or Duet2CombinedFirmware.bin ?
              Thanks for the help
              • Vetiundefined
                Veti
                see
                https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
                you will need to update the wifi firmware and the dwc as well.
                • YanivKundefined
                  YanivK
                  All updates are done!
                  Current is now 1.4A
                  Nothing changed 😞
                  Any other direction ?
                  Thanks again, Yaniv
                  • Vetiundefined
                    Veti
                    does the messages appear as soon as you move anything. or sometime in between?
                    does it repeat?
                    • YanivKundefined
                      YanivK
                      The messages appear as soon as i move X or Y and it repeats forever (every 5 seconds)
                      • Vetiundefined
                        Veti
                        possibilities.
                        • you damaged the driver by having a short circuit in your stepper motor wiring.
                        • drivers failed during the first few hours of use for no apparent reason. (unlikely to happen to all drivers at the same time)
                        • your wiring is incorrect. bad crimp. phases not connected correctly.
                        maybe dc42 can weigh in on this.
                        • YanivKundefined
                          YanivK
                          Same motors with the same wiring works on driver 2,
                          I connected the Z motor (the one that always worked) to E2 just to check and it had the same behavior from the first try.
                          This is the first time i use the board not hours, seconds...
                          Thanks, Yaniv
                            Something clearly isn't right. Please ask your supplier to replace your Duet. If it's a genuine UK-manufactured one, https://www.duet3d.com/warranty.
                            • YanivKundefined
                              YanivK
                              It is "genuine UK-manufactured" got it from E3D
                              Thanks you, Yaniv
