    Short-to-ground on drivers - Please help
    673
    • Vetiundefined
      Veti
      are you sure the specs are correct? 2.4Ohm vs 1.5Ohm
      if you are sure that it is correct. adjust the motor current to 85% or the rated current(1.7A). you currently run them at 800mA
      • YanivKundefined
        YanivK
        I tested then on the wire end. without the wire it's 1.9-2.0 ohm
        I am trying to understand what file do i need for the firmware update: is it Duet2Firmware-2.03.zip or Duet2CombinedFirmware.bin ?
        Thanks for the help
        • Vetiundefined
          Veti
          see
          https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
          you will need to update the wifi firmware and the dwc as well.
          • YanivKundefined
            YanivK
            All updates are done!
            Current is now 1.4A
            Nothing changed 😞
            Any other direction ?
            Thanks again, Yaniv
            • Vetiundefined
              Veti
              does the messages appear as soon as you move anything. or sometime in between?
              does it repeat?
              • YanivKundefined
                YanivK
                The messages appear as soon as i move X or Y and it repeats forever (every 5 seconds)
                • Vetiundefined
                  Veti
                  possibilities.
                  • you damaged the driver by having a short circuit in your stepper motor wiring.
                  • drivers failed during the first few hours of use for no apparent reason. (unlikely to happen to all drivers at the same time)
                  • your wiring is incorrect. bad crimp. phases not connected correctly.
                  maybe dc42 can weigh in on this.
                  • YanivKundefined
                    YanivK
                    Same motors with the same wiring works on driver 2,
                    I connected the Z motor (the one that always worked) to E2 just to check and it had the same behavior from the first try.
                    This is the first time i use the board not hours, seconds...
                    Thanks, Yaniv
                      Something clearly isn't right. Please ask your supplier to replace your Duet. If it's a genuine UK-manufactured one, https://www.duet3d.com/warranty.
                      • YanivKundefined
                        YanivK
                        It is "genuine UK-manufactured" got it from E3D
                        Thanks you, Yaniv
