SeeMeCNC Accelerometer probe board
@curieos remind me - does the accelerometer board output a signal to indicate triggered/not triggered or does the I2C signal go all the way back to the RAMBO etc?
@t3p3tony said in SeeMeCNC Accelerometer probe board:
It goes all the way back to the controller.
I recall from the SeeMeCNC forum that users reported issues with noise interfering with the I2C signal. AFAIR they had to probe with the hot end heater off. I think I also saw a report that the triggering was OK with a glass bed but not consistent enough when using a PEI bed.
This is the best to use stock seemecnc or trick laser arms and trucks with smart effector.
https://713maker.com/rostock/duet-smart-effector-adaptor -
@jmjcoke Yeah, someone already posted that
@curieos said in SeeMeCNC Accelerometer probe board:
@T3P3Tony @dc42 I did see the note about repeatability, though that seems to be due to MHackney having multiple beds he swaps out. I only have one bed I plan to use. Is this something you can add compatibility for, or do you think the user experience is too poor?
Adding support to the main firmware for an I2C device such as this was discussed a long time ago and from memory we decided it was too unreliable, and there were better options out there (including the SeeMeCNC replacement).
Cheap Solution
Okay, thanks Tony. I'll figure out a solution.
The FSRs wont work for this, the bed isn't mounted the way it used to be.
Picture?
The bed mounts on 6 of these specially shaped plastic pieces, and then the clamps press down on the glass. I can conceive of a way to mount them, but there's a multitude of problems it creates (how does the glass get clamped to the bed? how does the PCB get clamped to the insulator? The insulator has a new design that would require a properly mating part to act as the support on the FSR). Plus I'd have to run 3 wires down the towers of my already nearly finished printerI'm going to use a Teensy (I have so many) to communicate with the accel probe and then have that act as the in-between. I'll probably use the onboard DAC to set the trigger voltage so I can adjust the trigger point on the duet, or just use PWM and a cap to smooth it out a little. If I get some money later on and decide it's worth it I'll get one of the smart effectors.
Looks like the accel board straight up won't work with the Duet. The thermistor ground is common with all the fans, so if I connect it to the thermistor header it causes the bed and hotend thermistors to vary wildly.
