G30 won't go far enough to reach probe
1.1k
    RedWagon
    I have an endstop setup as a Z probe so it can be assigned to multiple axes
    https://forum.duet3d.com/topic/10918/one-endstop-for-multiple-axes
    When I run G30 the printer only goes down about 10mm (default dive height x2?) then throws the error:
    Error: Z probe was not triggered during probing move
    I've been searching around but I haven't found anything that can get it to move down further to hit the probe.
    homeall.g
    ; Home All
    G91 ; relative movement
    G1 Z4 F100 H1; ensure head is clear of the bed
    G1 S1 X-200 F3000 ; move radius towards minimum until the endstop switch is triggered
    G1 S2 X5 ; move radius out by 5mm
    G1 S1 X-20 F600 H1; move radius slowly to the endstop switch again
    ; Home Bed
    G90 ; absolute movement
    G1 S2 X10 ; move to 10mm from centre of bed
    G92 X10 Y0 ; define current position as X10 Y0
    ; Home Z
    G30 ; lower head, stop when probe triggered and set Z to trigger height
    homez.g
    G1 Z4 F200 H1; raise head 4mm to ensure it is above the Z probe trigger height
    G90 ; back to absolute mode
    My best guess is to assign a Z endstop to the Z probe so I can do a G1 move down until the endstop is triggered but that seems unnecessarily convoluted.
    Printer is a Polar3D.
    config.g
    ; Configuration file for factory testing Duet Ethernet and Wifi with V2.02 firmware
    FOR TESTING ONLY! USE https://configurator.reprapfirmware.org/ to generate configuration files for your printer!
    ; Communication and general
    M111 S0                            		; Debug off
    M550 PDuetTest					; Machine name and Netbios name (can be anything you like)
    M551 redacted              			; Machine password (used for FTP)
    ;*** Networking
    M587 redacted
    M552 S1						; Turn network on
    M555 P2						; Set output to look like Marlin
    G21						; Work in millimetres
    G90						; Send absolute coordinates...
    M83						; ...but relative extruder moves
    ; No bed heater
    M140 H-1
    ; Disable Fan 1 thermostatic mode
    M106 P1 H-1
    ; Axis and motor configuration
    M569 P0 S0					; Drive 0 goes forwards
    M569 P1 S1					; Drive 1 goes forwards
    M569 P2 S0					; Drive 2 goes forwards
    M569 P3 S1					; Drive 3 goes forwards
    M558 P4 I1
    M574 X1 S2
    M574 Y0					; radius homing switch present, no turntable homing switch
    M669 K7 R0:150 H0.3 F30 A30 			; set Polar kinematics parameters
    M666 X0 Y0 Z0					; put your endstop adjustments here, or let auto calibration find them
    M350 X16 Y16 Z16 E16:16 I1			; Set 16x microstepping with interpolation
    M92 X80 Y80 Z2560			 	; Set axis steps/mm
    M906 X1000 Y1000 Z1000 E800 I60			; Set motor currents (mA) and increase idle current to 60%
    M201 X1000 Y1000 Z1000 E1000			; Accelerations (mm/s^2)
    M203 X6000 Y6000 Z100 E3600 			; maximum linear speeds mm/minute
    M566 X1200 Y1200 Z1200 E1200			; Maximum instant speed changes mm/minute
    ; Thermistors
    M305 P1 T100000 B3974 R4700 H30 L0		; Put your own H and/or L values here to set first nozzle thermistor ADC correction
    M570 S180					; Hot end may be a little slow to heat up so allow it 180 seconds
    M106 P1 S-1					; disable thermostatic mode for fan 1
    ; Tool definitions
    M563 P0 D0 H1					; Define tool 0
    G10 P0 S0 R0					; Set tool 0 operating and standby temperatures
    M92 E80:80					; Set extruder steps per mm
    ; Z probe and compensation definition
    ;*** If you have a switch instead of an IR probe, change P1 to P4 in the following M558 command.
    ; M558 P4 F100 T6000 X0 Y0 Z0 H3		; Z probe is a Smart Effector and is not used for homing any axes R0.4 not used. Reduced F300 to 100
    ; G31 P100 X0 Y0 Z-0.25				; Set the zprobe height and threshold for Smart Effector
    ;*** If you are using axis compensation, put the figures in the following command
    M556 S78 X0 Y0 Z0				; Axis compensation here
    M208 S1 Z-0.2					; set minimum Z
    T0						; select first hot end
    ; M117 Use https://configurator.reprapfirmware.org/ to set up your printer config
    undefined 1 Reply Last reply 16 Jun 2019, 21:00 Reply Quote 0
      Phaedrux Moderator @RedWagon
      @redwagon said in G30 won't go far enough to reach probe:
      All your probe definition commands are commented out.
        You need to set the Z axis maximum using M208. A plain G30 with no other parameters or just one S parameter will go down up to 1.1 times the length of the Z axis that you declare using M208.
          Nightreaver
          That happens to me once in a while. For homeall and homez is replaced all G30 with G30 Z-99999
          I think that fixes it.
            RedWagon
            Sorry, I commented out the default ones but the probe is defined earlier with:
            M558 P4 I1
            I've tried several combinations of the suggestions above but they all do the same thing.
            G20
            G30 Z-99999
            G30 Z-200
            M208 Z200
            G30
            G30 Z-99999
            G30 Z-200
            M208 S1 Z-200
            G30
            G30 Z-9999
            M208 Z0:200
            G30
            G30 Z-999999
            M208 Z-200:200sG30 Z-9999
            G30
            G30 Z-99999
            I measured and it dives for 10mm then returns to its original height.
            From reading the docs it doesn't really sound like I should be doing a large dive for G30. Do I need to run G28 first with the endstop assigned to Z probe?
              Does your Z axis move the correct amount? For example, if you send G91 followed by G1 S2 Z50 does it move the print head up or the bed down 50mm?
                RedWagon
                It's off by a little bit; right now it's travelling 8mm per 10mm. Shouldn't be enough for it to run through the max axis settings and not trigger the probe. I tested by doing a G92 Z0 then moving it around manually.
                undefined 1 Reply Last reply 18 Jun 2019, 15:34 Reply Quote 0
                  dc42 administrators @RedWagon
                  It sounds to me that either your Z steps/mm is a little off, or your Z speed or acceleration is set too high. I suggest you find out which:
                  • Calculate the Z steps/mm from the pitch/lead of your leadscrew mor the belt pitch and number of pulley teeth
                  • If you think you have set the correct Z steps/mm, try reducing Z speed and/or acceleration in M203 and M201
                  When you have the Z movement sorted, try plain G30 with no parameters.
                    RedWagon
                    I've adjusted the Z steps/mm and lowered speed and acceleration. No changes; G30 by itself still lowers 10mm and throws the "Z probe was not triggered during probing move" error.
                      RedWagon
                      config.g
                      ; No bed heater
                      M140 H-1
                      M106 P1 H-1
                      M558 P4 I1					; use E0 endstop as Z probe
                      M574 X1 S2					; bind X homing switch to Z probe
                      M92 X80 Y80 Z3200			 	; Set axis steps/mm
                      M201 X1000 Y1000 Z100 E1000			; Accelerations (mm/s^2)
                      ; Thermistors
                      ; Tool definitions
                      M208 Z-0.2:200					; set axis travel limits
                      homeall.g
                      ; Home All
                      ; Home Bed
                      ; Home Z
                      ; G1 X0 Y0 ; put head over the centre of the bed, or wherever you want to probe
                      homebed.g
                      G1 Z4 F100 H1 ; ensure head is clear of the bed
                      G1 S2 X0 ; move to centre of bed
                      G92 X0 Y0 ; define current position as X0 Y0
                      G1 Z-4 F100 H1; restore original Z position
                      homedelta.g
                      ; Example Homing file for RepRapFirmware on delta printer
                      ;M117 Use https://configurator.reprapfirmware.org/ to set up your printer config
                      ;G91							; use relative positioning
                      ;******* Change F250 in the following line to F2500 when you are finished commissioning
                      ;******* Change 320 in the following to a higher value if your Kossel has taller towers
                      ;G1 S1 X320 Y320 Z320 F2500	; move all carriages up 320mm, stopping at the endstops
                      ;G1 S2 X-3 Y-3 Z-3			; move all carriages down 3mm
                      ;G1 S1 X6 Y6 Z6 F250			; move carriages slowly up 6mm, stopping at the endstops
                      ;G1 Z-5 F2000				; down a few mm so that we can centre the head
                      ;G90							; back to absolute positioning
                      ;G1 X0 Y0 F2000				; centre the head and set a reasonable feed rate
                      homeradius.g
                      G1 S1 X-20 F600 ; move radius slowly to the endstop switch again
                      homez.g
                      ;G1 X0 Y0 ; put head over the centre of the bed, or wherever you want to probe
                        Have you tested the Z probe? https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                          RedWagon
                          I ran through those tests and still get the same results. I have to manually move the printer within 5mm of the Z probe triggering or it will give the error "Z probe was not triggered during probing move"
                            RedWagon
                            Finally fixed it!
                            The missing command was setting the Z endstop to the Z probe with M574 Z1 S2
