    Status of DUE&RADDS support
    4.7k
    • mb0undefined
      mb0
      thanks! re-indexing fixed the red.
      i grepped through dcnewmans coreng and rrf forks. he provides pin configurations in the /RADDS subdirectory.
      there are some changes to coreng as well. one is related to spi dual use or something. rest is more or less just jitter.
      there is one #ifdef which defines DUET if SAM3X is defined. this logic needs to be revised as well, but this is of
      course trivial.
      actually he introduced SCons as build system so i guess he didn't bother using eclipse as build platform. this is
      unnecessary.
      best is i make a fork on github and send a pull request. i think i can start working on it as soon as my dyzend stuff
      is working on the duetwifi (it is heating but auto-tune does not work so the pid is very slowly approaching temp,
      but then rock solid). i hope i manage to finish the printer by the end of next week.
      how is the esp connected to the duetwifi? would be awesome to bolt that onto radds as well.
        @mb0:
        On the Duet WiFi the high speed SPI interface on the SAM4E mcu is dedicated to communicating with the ESP so that we can achieve high data transfer speeds.
        • mb0undefined
          mb0
          i tried to make sense of eclipse project management and now i am wondering what the canonical way is to maintain the .cproject files. if noticed you added the RADDS build configuration to the firmware part. of course it is also needed in coreng. but unfortunately eclipse maintains paths to arduino gcc stuff in the same .cproject as it maintains build targets. unbelievable i now. thus i can't make clean git patches.
          how can we colaborate without these stupid config conflicts? isn't there some kind of user profile overlay for cross toolchains?
            It's possible to declare build variables in Eclipse, so it might be possible to declare the path to gcc in a build variable and refer to that build variable in the .cproject file. I suspect that this may just move the problem to the .project file, but the .project file is rarely changed anyway.
            I'm sorry I forgot to check in the changes to CoreNG. I'll check them in shortly.
            • mb0undefined
              mb0
              nice thanks! when you're at it dcnewman defines the following in SConstruct build file:
              [[python]]
              if platform == 'radds':
                 env.Append( CCFLAGS = [
                       '-D__RADDS__=1',
                       '-DSD_MMC_SPI_MODE',
                       '-DSPI_PIN=77',
                       '-DSPI_CHAN=0',
                       '-DSD_SS=4',
                       '-DSD_DETECT_PIN=14',
                       '-DSD_DETECT_VAL=0',
                       '-DSD_DETECT_PIO_ID=ID_PIOD',
                       '-DUSE_SAM3X_DMAC=1',
                       '-DDMA_TIMEOUT_COMPUTE' ] )
                 if use_usb_combo:
                       '-DUSE_USB_COMBO',
              	 '-DUSB_DEVICE_VENDOR_ID=0x2341',
              	 '-DUSB_DEVICE_PRODUCT_ID=0x003e',
              	 '-DUSB_DEVICE_PRODUCT_NAME=\\"Arduino Due\\"',
              	 '-DUSB_DEVICE_MANUFACTURE_NAME=\\"Arduino LLC\\"' ] )
              you might want to add these flags as well to the RADDS build configuration. then i can keep a local copy of the .cproject and ignore it (hoping so).
                When Dan did the RADDS port, my fork didn't have code for accessing SD cards over SPI, but it does now. So it makes more sense to define those parameters (except for RADDS) in the Pins_RADDS file, just as they for the Duet and Duet WiFi. I already put most of them in Pins_RADDS,h except for the ones I didn't know the values for.
                I think you should be able to use the CoreNG SAM3X build from my githib repo as-is for RADDS, except that you will need to change variant.cpp and variant.h to set up the pins appropriately.
                  PS - I've updated my copy of CoreNG with Dan's copy of variant.cpp and variant.h, ma de a few other changes, and now I can actually build a RADDS version of CoreNG. I'll commit it to GitHub tomorrow when I have tested that I haven't broken anything in the Duet builds.
                  • mb0undefined
                    mb0
                    thanks! i'll have a look at it when i'm back from very short vacation!
                    you are right after writing my post i realized that these defines should go into a header instead.
                    there are only a few other mentions of RADDS in coreng. One is in AnalogIn.cpp line 94:
                    [[c]]
                    #if SAM3XA
                    #ifdef __RADDS__
                    			if (ADC_TEMPERATURE_SENSOR != GetAdcChannel(channel))
                    #endif
                    				adc_enable_channel(ADC, GetAdcChannel(channel));
                    			if (GetAdcChannel(channel) == ADC_TEMPERATURE_SENSOR)
                    				adc_enable_ts(ADC);
                    #endif
                    1st i disklike nested #ifdef whatever, this makes everything unreadable. 2nd yoda style (ADC_TEMPERATURE_SENSOR != GetAdcChannel(channel) is a no no.
                    however i'm asking myself if this is actually needed because in any case it would call adc_enable_ts if needed. in the RADDS case not calling adc_enable_channel
                    before then. so either there is a bug when doing this when using the radds board or it is not neccessary and can be forgotten.
                    if your time permits you might want to look into SharedSpi.cpp as well. in dcnewmans fork are a 2 more #ifdef's for the RADDS case in lines 186 and 386
                    [[c]]
                    #if defined(USE_SAM3X_DMAC) && !defined(__RADDS__)
                    you know better than me if these are necessary or not facing the current implementation. Afaics, these were the only changes to the actual source which depend
                    on anything radds related. if so coreng would be radds safe after your changes.
                    i looked at the radds schematics and think that using a small adapter pcb the esp could also be connected to spi and the sdcard rewired to the hsmci port. thus
                    enabling high speed uploads there as well (preventing however the use of an lcd but not serial panel or whatever).
                      I've checked everything in. The RADDS version builds but I haven't tested it.
                      The change to AnalogIn shouldn't be needed, because the RADDS version of RRF shouldn't ask to use the temperature sensor channel.
                      The changes to SharedSpi are because he got it working under DMA, but my build doesn't use DMA for the shared SPI. I think I left the sspi_start_transmit and sspi_start_receive functions there so that he could use them, but he seems to be calling spi_start_transmit and spi_start_receive instead, and I don't know where he defines those. You may find that it works OK without using DMA anyway, although using DMA would be preferable because on the RADDS all SD card access goes over SPI.
                      • mb0undefined
                        mb0
                        managed to build the RADDS flavour as well. There were some minor quirks (arm-*-objcopy was unable to locate the .elf because the path to it is wrong objcopy -binary /RepRapFirmware.elf /RepRapFirmware.bin) i checked the eclipse settings but they seamed correct. Anyway, did it by hand. Ahh and i switched from external make
                        to internal build tool in eclipse. Maybe you can change this setting as well in the project file to reduce one more error one can have. I copied the gcc from my arduino install
                        to the directory you have in the eclipse config, so in the future i don't have to touch this settings (at least under windows).
                        to use bossa (under Tools/Windows) you need to set the corresponding COM port to 1200 baud. This is done using the command
                        [c]mode comN:1200[/c] where N is the port number of the due. under linux you do [c]stty -F /dev/ttyACM0 1200[/c].
                        The target binary of RRF for RADDS should be renamed to RepRapFirmware-RADDS.bin for clarity.
                        After uploading the firmware to the due i could connect to it using pronterface and issue some commands. It seems that only the external SDCard
                        is working, maybe some configuration issue. I couldn't test the full deal because i ran out of time. Will do tomorrow. Just wanted to drop a quick note…
                          @mb0:
                          …. It seems that only the external SDCard is working, maybe some configuration issue....
                          Does RADDS support 2 SD card sockets then? I only allowed for one in the Pins.h file.
                          • StephenRCundefined
                            StephenRC
                            The RADDS has a microsd card slot and a SD extern connector that's used by the lcd sold for it.
                              Ok so you need to change the SD cards section of thea RADDS pins.h file to define both cards. If the external card is working, then I suspect that the CS pin in the existing definition is for the external card however the CD pin may be for the internal card. You can use the M122 command to see the state of the CD pin, from that you can work out which one it is.
                              • mb0undefined
                                mb0
                                thanks, there are two chip selects (CS0 and CS1), the CD (card detect) is shared between both.
                                http://www.dr-henschke.de/LCD_Enc_SD_12.pdf
                                i think the default config for RADDS should use the onboard SDCARD slot because one can not expect the lcd (which is not supported) to be connected.
                                  Do you know what the pin assignments are for CS0 and CS1?
                                  • bruce356undefined
                                    bruce356
                                    Hi, I am not a technical person, wondering if I could use the firmware that you are working on here for my dual x carriage Cartesian (Mendel) printer with Due/RADDS. I would probably require a bin file as I know nothing about compiling this type of firmware.
                                    Thanks and regards - bruce
                                    • mb0undefined
                                      mb0
                                      CS0 -> Arduino Pin 10 -> SAM3X PA28/PC29 -> Physical 102
                                      CS1 -> Arduino Pin 4 -> PA29/PC26 -> Physical 137
                                      btw. the printer is running now for >4h without any issues (related to the firmware).
                                      the current setup is RADDS&RAPS128@1/128 0.9 stepper for x/y. z@1/32, extruder@1/16.
                                      24V. It can't go full speed at this microstepping rate. i noticed some "pauses" when printing
                                      large rounded corners. it seems that braking after travel movement is quite aggressive, i get
                                      strange sounds as if the hotend would have bumped into the print.
                                      edit: after setting the raps to 1/32 for all steppers the bumping is gone. is suspect planner
                                      errors because out-of-time situations.
                                        @bruce356:
                                        RRF 1.16 and later support multiple X carriages in the standard binaries. See https://duet3d.com/wiki/Configuring_multiple_independent_X-carriages_on_a_Cartesian_printer. So if someone produces a stable RADDS build of 1.16 or 1.17, you should be able to use the binary.
                                          @mb0:
                                          What were your steps/mm @ 128x ?
                                          I have provisionally changed the SD card section in Pins_radds.h to this:
                                          // SD cards
                                          const size_t NumSdCards = 2;
                                          const Pin SdCardDetectPins[NumSdCards] = { 14, 14 };
                                          const Pin SdWriteProtectPins[NumSdCards] = { NoPin, NoPin };
                                          const Pin SdSpiCSPins[2] = { 87, 77 };
                                          You will also need to change line 73 of asf/conf_sd_mmc ni CoreNG to:
                                          #define SD_MMC_SPI_MEM_CNT			2			// Number of SPI card slots supported
                                          i.e. change 1 to 2.
                                          I think this should address the internal SD card as card 0 and the external one as card 1. Please can you test this. I have assumed that the CD pin of both sockets are wires in parallel, but if the external card has no CD pin then change the second 14 to No Pin, otherwise the external SD card won's work unless the internal SD card is present.
                                          • mb0undefined
                                            mb0
                                            my steps/mm @ 128x where
                                            [[language]]
                                            M92 X905.414787 Y905.414787 Z1280   ; set axis steps/mm
                                            M92 E152                            ; set extruder 0 steps/mm
