Laser power adjustment/speed
Laser Cutters
2.4k
    clearlynotstef
    Given it might be a few days before I have the gear to test it, and I'd prefer to order whatever board I'll use in the interim, could I ask if you had a chance to test it, and how it went? I'm inclined to just order another duet on the theory that if you've already thought to integrate it either a) it already works perfectly or b) it probably will by the time the second board arrives here!
    undefined 1 Reply Last reply 19 Jun 2019, 14:01 Reply Quote 0
      dc42 administrators @clearlynotstef
      I tested it this morning, and it's not working properly yet. I should get a chance to look at it again tomorrow.
        clearlynotstef
        So, as a general point, you're looking to continue to support lasers and related features right? Obviously you having started this task before I said anything is a good sign; even if it doesn't work yet, it will eventually, right? I really would prefer to use a duet instead of the equally pricy cohesion board that is purposed for lasers specifically, but otherwise doesn't look as capable as my duet. I just don't want to buy in for using it on a laser-exclusive machine to find you didn't continue support in that direction.
        Thanks for your time and help with this DC!
          clearlynotstef
          DC, could I ask you you to check out this forum post about duet's suitability for laser engraving? I think it might be helpful for you as you work on laser support, and it would definitely be helpful to me to know your thoughts on it:
          https://forum.lightburnsoftware.com/t/diode-laser-recommended-hardware-firmware/4405/6
            I'm not sure if that comment that the Duet doesn't support G1 S moves to control the laser is accurate anymore as of firmware 2.02
            https://duet3d.dozuki.com/Wiki/Gcode#Section_G0_G1_Move
            Snnn In firmware 2.02 and later, when switched into Laser mode (see M452), this parameter sets the laser power. When not switched into Laser mode, and always in firmware 2.01 and earlier, it defines the move type (see the description of the H parameter).
            Very important! If you use M452 to put your machine into Laser mode, when upgrading firmware from 2.01 or earlier to 2.02 or later you must replace all S parameters in G0/G1 commands in homing files etc. by H parameters. This is because S is now used to control laser power, for compatibility with programs that generate GCode files for laser cutters.
            undefined 1 Reply Last reply 20 Jun 2019, 03:19 Reply Quote 0
              raykholo @Phaedrux
              @phaedrux said in Laser power adjustment/speed:
              Oh cool! I'm not up to date on Duet/ RRF since firmware 2.0 came out. So then the question will become how well RepRapFirmware handles these lines such as G1 X0.1 S0.6 F6000 (that's Smoothieware syntax, or in RRF case S255) when receiving several thousands of them a second for image rastering.
              I don't know what the performance of that will be like.
              Speeds were slow when we tested it with the "Marlin-resembling" previous syntax, and to be clear, that was the source of my comments in the LightBurn Forum.
              undefined undefined 2 Replies Last reply 20 Jun 2019, 07:57 Reply Quote 0
                clearlynotstef @raykholo
                @raykholo ha! I expected you'd find your way here eventually, but not in practically real time! Small world of people with these overlapping interests I suppose. I appreciate your help so far!
                  dc42 administrators @raykholo
                  @raykholo said in Laser power adjustment/speed:
                  You can choose the S value (255, 1.0 or any other value you like) that represents full laser power, see the R parameter in the M452 command.
                  We are already talking to LighBurn about high speed rastering and I have proposed a laser rastering extension to the G1 command. See https://docs.google.com/document/d/1SMWFJUXfRSxe-p-veWEP-NU3A9ESKU_TVGB1Y1ADAV8/edit?usp=sharing.
                    A Former User
                    @dc42 said in Laser power adjustment/speed:
                    requires access, you want do deal with the requests or make it public?
                    undefined 1 Reply Last reply 20 Jun 2019, 10:08 Reply Quote 0
                      I'm sorry about that, I've updated the link in my post above. Try again.
                        Laser velocity ramping is now working in the RRF 3 beta at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0.
                          A Former User
                          Perfect timing, just got a new low power uv laser to use with photosensitive pcbs - hope to test it asap
                            The laser power is adjusted every 5 milliseconds at present during acceleration and deceleration. I hope this is OK. In the longer term I will probably make the adjustment interval the greater of 3ms and 5 cycles at the laser PWM frequency.
                              clearlynotstef
                              Wow this post has been so helpful! I will be following the progress with lightburn integration closely, I'm so excited to hear that you're already working on it. RRF has the potential to be outstanding with laser as it is with filament!
                              Best,
                              Stefan
                                clearlynotstef
                                Do you have any idea of when Lightburn compatibility might come to fruition? I'm so happy to hear that you were working on it, but I can't get a sense of if its moving along or just something that was discussed and left alone.
                                Thanks,
                                Stefan
                                undefined 1 Reply Last reply 23 Jun 2019, 18:19 Reply Quote 0
                                  @clearlynotstef said in Laser power adjustment/speed:
                                  Thanks,
                                  Stefan
                                  LightBurn compatibility in what sense? I am fairly certain that firmware 2.03 and 3.0beta are already compatible with LightBurn. The difference is that 3.0beta implements velocity ramping.
                                    TonyPagett
                                    Do I need to activate this velocity ramping or does it just work as is when in laser mode?
                                    undefined 1 Reply Last reply 1 Dec 2019, 20:33 Reply Quote 0
                                      dc42 administrators @TonyPagett
                                      @TonyPagett said in Laser power adjustment/speed:
                                      RRF3 implements velocity ramping when in laser mode, provided that you specify the laser power using S parameters on the G1 commands. So you don't need to enable it in Lightburn. RRF2 does not.
                                      undefined 1 Reply Last reply 2 Dec 2019, 07:45 Reply Quote 0
                                        TonyPagett @dc42
                                        @dc42 Thank you.
                                        My next question is this. The following code moves the laser (CNC) in the defined square but only switches the laser on for the first line (or one side of the square).
                                        M3 S255
                                        G1 Y75.0000 Z0.01000 F2500.0
                                        G1 X75.00000
                                        G1 Y25.00000
                                        G1 X25.00000
                                        M03 S0
                                        If I add an S command to each line it works OK
                                        Is there a way round this?
                                        undefined 1 Reply Last reply 2 Dec 2019, 07:48 Reply Quote 0
                                          Select "laser power sticky" in your M452 command. Preferably, don't use M3 to set the laser power, just use a S parameter on the first G1 move.
                                          undefined 1 Reply Last reply 2 Dec 2019, 14:04 Reply Quote 0
