2.03RC5 leveling issue
@spax, what type of Z probe do you have on your delta printer?
After run G32 a few times, if you then run G29, what does the height map look like?
@dc42, I use your IR probe.
22:32:26G29
109 points probed, min error -0.158, max error 0.575, mean 0.214, deviation 0.150
Height map saved to file heightmap.csv
22:26:15G32
Calibrated 6 factors using 16 points, deviation before 0.178 after 0.100
22:25:04G32
Calibrated 6 factors using 16 points, deviation before 0.239 after 0.095
22:23:55G32
Calibrated 6 factors using 16 points, deviation before 0.371 after 0.126 -
I have 6mm aluminium plate + 0.5 heatsink pad + 4mm glass (back side painted in black).
@dc42 any thoughts?
Can you rerun the G29 heightmap with a piece of plain paper covering the bed surface? The idea being to eliminate any inconsistencies in the IR probe reading the surface.
Also please post a screen shot with the height map rotated so that we are looking along the X axis.
19:36:16G29
97 points probed, min error -0.587, max error 1.307, mean 0.383, deviation 0.415
Height map saved to file heightmap.csv19:28:00M500
19:27:48G32
Calibrated 6 factors using 16 points, deviation before 0.254 after 0.09119:26:43M500
19:26:37G32
Calibrated 6 factors using 16 points, deviation before 0.132 after 0.11119:25:31M500
19:25:01G32
Calibrated 6 factors using 16 points, deviation before 0.209 after 0.08019:23:54M500
19:23:44G32
Calibrated 6 factors using 16 points, deviation before 0.379 after 0.108 -
That height map looks terrible, as if you are probing off the edge of the bed or something like that.
@dc42 Coz idea with paper is bad idea) Paper of sheet not 100% flat...
@spax said in 2.03RC5 leveling issue:
That height map has high points "0.25mm of more" and low points "-0.25 or less." A sheet of paper isn't going to deviate in thickness by over 0.5mm!
Time to get a bigger sheet of paper?
