    Curl + KISS in RRF
    2.9k
    • JoergS5undefined
      JoergS5 @sinned6915
      @sinned6915 I would try the syntax in the examples in the thread I mentioned. There the file= has the meaning to set the target path IMO, so f:\ ist not understandable by a system which uses / syntax for directories.
      • sinned6915undefined
        sinned6915
        i am getting popup saying my post is being flagged as spam.....
        you mean the Duet is not understanding the f:\ ?
        that is the drive letter where the file is being up loaded from.
        its part of the output from Windows.
        • JoergS5undefined
          JoergS5 @sinned6915
          @sinned6915 yes I meant the f:\ , the destination path should be some LINUX similar path.
          spam maybe because we communicate too fast...
            sinned6915
            ok, so the filename coming through the post-process scrip call is the full path AND filename. here i tried to simply output whatever it was given-
            ECHO ON
            ECHO FILNAME=@%1
            output is -
            F:\3D_Printer\Kiss_1.6.3>ECHO ON
            F:\3D_Printer\Kiss_1.6.3>ECHO FILNAME=@"F:\3D_Printer\Kiss_1.6.3\EV2\Preload\KS_Wizard(0).gcode"
            • JoergS5undefined
              JoergS5 @sinned6915
              @sinned6915 I mean somthing like:
              curl -v -F "file=@"/KS_Wizard.gcode"" http://192.168.0.25/rr_upload?name=gcodes/@"F:\3D_Printer\Kiss_1.6.3\EV2\Preload\KS_Wizard.gcode"
              or if only the output path is expected:
              curl -v -F "file=@"/"" http://192.168.0.25/rr_upload?name=gcodes/@"F:\3D_Printer\Kiss_1.6.3\EV2\Preload\KS_Wizard.gcode"
              (I am offline now. Good luck!)
                sinned6915
                @JoergS5 thanks for your help- i am making baby steps...
                curl -v -F "file=@%1" "http://192.168.0.25/rr_upload?name=gcodes/%~nx1"
                is parsing the filename out of the path but now i am getting timeouts from the Duet.
                F:\3D_Printer\Kiss_1.6.3>curl -v -F "file=@"F:\3D_Printer\Kiss_1.6.3\EV2\Preload\KS_Wizard(8).gcode"" "http://192.168.0.25/rr_upload?name=gcodes/KS_Wizard(8).gcode"
                *   Trying 192.168.0.25...
                * TCP_NODELAY set
                * Connected to 192.168.0.25 (192.168.0.25) port 80 (#0)
                > POST /rr_upload?name=gcodes/KS_Wizard(8).gcode HTTP/1.1
                > Host: 192.168.0.25
                > User-Agent: curl/7.55.1
                > Accept: */*
                > Content-Length: 2017542
                > Expect: 100-continue
                > Content-Type: multipart/form-data; boundary=------------------------941032cdc9b01eb3
                * Done waiting for 100-continue
                < HTTP/1.1 200 OK
                < Cache-Control: no-cache, no-store, must-revalidate
                < Pragma: no-cache
                < Expires: 0
                < Access-Control-Allow-Origin: *
                < Content-Type: application/json
                < Content-Length: 9
                < Connection: close
                {"err":0}* Closing connection 0
                • JoergS5undefined
                  JoergS5 @sinned6915
                  @sinned6915 was your try in http://www.kisslicertalk.com/viewtopic.php?f=13&t=2263 succesful, so you can compare it to today's try? Possible reasons could then be changed curl version or OS.
                  Another idea is, maybe it's possible to set debug mode on Duet side.
                    sinned6915
                    I was using that script to connect windows 10 to Octoprint- same one i started with and posted above.
                    I was not able to get it to connect to duet. One of the posters was using a Mac and the script options are different.
                    good idea on trying to enable the debugging! i know M111 P2 (?) sets debug in HTTP. I will try that. P1 is network and floods the terminal buffers
                    Currently, I am either getting that 'continue' error or an authentication error. I do not have any password set but something tells me i should try to connect with no password regardless to start the connection.
                    • JoergS5undefined
                      JoergS5 @sinned6915
                      @sinned6915 maybe your timeout is because Duet doesn't close the connection, dc42 has commented in https://forum.duet3d.com/topic/867/duet-wifi-s3d/42 to use additional:
                      dc42:
                      You may wish to add the following line at the end:
                      curl "http://XXX.XXX.XXX.XXX/rr_disconnect"
                      This will avoid RRF buffering up messages that S3D isn't going to fetch.
                      Another idea:
                      Your curl command seems to be ok, the connection reported 100 and 200, which means successful. It transmitted 9 bytes. Are you sure it is not a link which you want to upload (the (8) file), which is only 9 bytes long? And you could try -X POST in the command additionally.
                      Edit: the content-length comment was wrong, the 9 bytes are the response. But the sending is about 2 MB, maybe there is a file limit somewhere. E.g. https://forum.duet3d.com/topic/4355/maximum-g-code-file-size/3 the SD card clustered.
                        sinned6915
                        @JoergS5 I saw the content lengths and thought it was odd, but assumed that it was HTTP not file system.
                        I have an overnight print going so I will test it out after it gets done. I remember reading about the cluster size somewhere and it prompted me to seek out the official SD card formatter. I can not remember what I used when i formatted the card. Its worth checking out.
                        I did try playing with the -X POST but I thought that it complained about being redundant with the -F option. I am not sure why the syntax changes color on this so much, but the first tan line says POST and I assumed that it was using POST. I will have to double check.
                        What I can not figure out is if its waiting for a server response- 'multpart' form boundary.
                        JoergS5undefined 3 Replies Last reply Reply Quote 0
                        • JoergS5undefined
                          JoergS5 @sinned6915
                          @sinned6915 my last few ideas:
                          to test whether your connection (with authentication) works correctly, you could start a print with curl of an existing file.
                          I saw curl has an alternative to multipart, for post also. You could try this also. But as I understood, curl manages the multipart formatting.
                          Kiss may produce specific gcode, you could try the curl with a little general gcode file.
                          I saw a curl option like --data-binary, maybe this helps.
                          • JoergS5undefined
                            JoergS5 @sinned6915
                            @sinned6915 I just discovered an intersting tool HTTPie: https://github.com/jakubroztocil/httpie#file-upload-forms which allows to run http commands interactively. This may help finding the problem.
                            • JoergS5undefined
                              JoergS5 @sinned6915
                              @sinned6915 I checked the documentation https://github.com/chrishamm/DuetWebControl, the chapter rr_upload says, a response {"err":0} means, that the transfer was successful.
                              So I suspect the target path makes problems.
                                sinned6915
                                So I am making some headway I think-
                                You are right, the transfer is getting initiated, but the payload is empty.
                                Here is the partial output of
                                M111 S1 P2 - https://pastebin.com/UE2ytPLr
                                all it shows is that the connections are initiated and accepted .
                                The gcode file list shows the file is there but with 0 length.
                                • JoergS5undefined
                                  JoergS5 @sinned6915
                                  @sinned6915 I would try using a more current curl version, current is 7.65.1. There were lots of bug fixes since 7.55.1 (list: https://curl.haxx.se/changes.html)
                                    A Former User
                                    Sure about the quoting?
                                    Looks like you either need to escape or change the inner qoutes, or more likely remove the outer ones?
                                      sinned6915
                                      i updated curl to latest version. no luck
                                      i played with the quotes, it does not seem to matter.
                                      I am using DWC 1.22.6 and curl 7.65.1
                                      can i request that someone who uses curl to do this it add the flag for verbose messages and post the output?
                                      are you using username and passwd to connect to the DWC or it public?
                                      • JoergS5undefined
                                        JoergS5 @sinned6915
                                        @sinned6915 I just saw another possibility: https://reprap.org/forum/read.php?416,819219
                                        sinned6915undefined 1 Reply Last reply Reply Quote 0
                                          sinned6915 @JoergS5
                                          i finally got this figured out. Windows is a little bit different-
                                          In KISS the script call from the Printer ->Post-Process command is
                                           <KSPATH>\EV2RRF.BAT "<FILE>"
                                          the EV2RRF.BAT script contains-
                                          ECHO ON
                                          curl -# -v --data-binary "@%1" -X POST http://192.168.0.25/rr_upload?name=gcodes/%~nx1
                                          curl "http://192.168.0.25/rr_disconnect"
                                          PAUSE
                                          the %~nx1 is to parse the filename
                                          CAUTION: something does not like dashes / minus signs in the filenames. I have not been able to determine if its KISS or CURL, but its easier to just avoid them all together.
                                          thanks to all who helped me figure this out.
                                          EDIT: The resulting command window will open and show you the progress of the transfer. It will then prompt you to hit any key to close the command window -
                                          F:\3D_Printer\Kiss_1.6.3>curl -# -v --data-binary "@"F:\3D_Printer\Models\Microscope_Stand\files\arm_base.gcode"" -X POST http://192.168.0.25/rr_upload?name=gcodes/arm_base.gcode
                                          Note: Unnecessary use of -X or --request, POST is already inferred.
                                          *   Trying 192.168.0.25:80...
                                          * TCP_NODELAY set
                                          > POST /rr_upload?name=gcodes/arm_base.gcode HTTP/1.1
                                          > Host: 192.168.0.25
                                          > User-Agent: curl/7.65.1
                                          > Accept: */*
                                          > Content-Length: 6109076
                                          > Content-Type: application/x-www-form-urlencoded
                                          * We are completely uploaded and fine
                                          * Mark bundle as not supporting multiuse
                                          < HTTP/1.1 200 OK
                                          < Pragma: no-cache
                                          < Expires: 0
                                          < Content-Length: 9
                                          < Connection: close
                                          F:\3D_Printer\Kiss_1.6.3>curl "http://192.168.0.25/rr_disconnect"
                                          {"err":0}
                                          F:\3D_Printer\Kiss_1.6.3>PAUSE
                                          Press any key to continue . . .
                                          • JoergS5undefined
                                            JoergS5 @sinned6915
                                            @sinned6915 nice that you found the reason finally! Could you please post the command line which works for you, in case someone needs the command also. Would be a good documentation project.
