    Jerky movements, again
    6.2k
    • roboduetundefined
      roboduet
      I'm just created simple script that produces segmented (0.5 mm) straight movement from X-50 Y-50 to X50 Y50 and then goes back to X-50 Y-50 with single g-code:
      [[language]]
      T0
      G21 ; set units to millimeters
      G90 ; use absolute coordinates
      M83 ; use relative distances for extrusion
      G1 X-50 Y-50 Z10.300 F4800
      G1 X-49.5 Y-49.5 F960
      G1 X-49 Y-49
      G1 X-48.5 Y-48.5
      G1 X-48 Y-48
      G1 X-47.5 Y-47.5
      G1 X-47 Y-47
      G1 X-46.5 Y-46.5
      G1 X-46 Y-46
      G1 X-45.5 Y-45.5
      G1 X-45 Y-45
      G1 X-44.5 Y-44.5
      G1 X-44 Y-44
      G1 X-43.5 Y-43.5
      G1 X-43 Y-43
      G1 X-42.5 Y-42.5
      G1 X-42 Y-42
      G1 X-41.5 Y-41.5
      G1 X-41 Y-41
      G1 X-40.5 Y-40.5
      G1 X-40 Y-40
      G1 X-39.5 Y-39.5
      G1 X-39 Y-39
      G1 X-38.5 Y-38.5
      G1 X-38 Y-38
      G1 X-37.5 Y-37.5
      G1 X-37 Y-37
      G1 X-36.5 Y-36.5
      G1 X-36 Y-36
      G1 X-35.5 Y-35.5
      G1 X-35 Y-35
      G1 X-34.5 Y-34.5
      G1 X-34 Y-34
      G1 X-33.5 Y-33.5
      G1 X-33 Y-33
      G1 X-32.5 Y-32.5
      G1 X-32 Y-32
      G1 X-31.5 Y-31.5
      G1 X-31 Y-31
      G1 X-30.5 Y-30.5
      G1 X-30 Y-30
      G1 X-29.5 Y-29.5
      G1 X-29 Y-29
      G1 X-28.5 Y-28.5
      G1 X-28 Y-28
      G1 X-27.5 Y-27.5
      G1 X-27 Y-27
      G1 X-26.5 Y-26.5
      G1 X-26 Y-26
      G1 X-25.5 Y-25.5
      G1 X-25 Y-25
      G1 X-24.5 Y-24.5
      G1 X-24 Y-24
      G1 X-23.5 Y-23.5
      G1 X-23 Y-23
      G1 X-22.5 Y-22.5
      G1 X-22 Y-22
      G1 X-21.5 Y-21.5
      G1 X-21 Y-21
      G1 X-20.5 Y-20.5
      G1 X-20 Y-20
      G1 X-19.5 Y-19.5
      G1 X-19 Y-19
      G1 X-18.5 Y-18.5
      G1 X-18 Y-18
      G1 X-17.5 Y-17.5
      G1 X-17 Y-17
      G1 X-16.5 Y-16.5
      G1 X-16 Y-16
      G1 X-15.5 Y-15.5
      G1 X-15 Y-15
      G1 X-14.5 Y-14.5
      G1 X-14 Y-14
      G1 X-13.5 Y-13.5
      G1 X-13 Y-13
      G1 X-12.5 Y-12.5
      G1 X-12 Y-12
      G1 X-11.5 Y-11.5
      G1 X-11 Y-11
      G1 X-10.5 Y-10.5
      G1 X-10 Y-10
      G1 X-9.5 Y-9.5
      G1 X-9 Y-9
      G1 X-8.5 Y-8.5
      G1 X-8 Y-8
      G1 X-7.5 Y-7.5
      G1 X-7 Y-7
      G1 X-6.5 Y-6.5
      G1 X-6 Y-6
      G1 X-5.5 Y-5.5
      G1 X-5 Y-5
      G1 X-4.5 Y-4.5
      G1 X-4 Y-4
      G1 X-3.5 Y-3.5
      G1 X-3 Y-3
      G1 X-2.5 Y-2.5
      G1 X-2 Y-2
      G1 X-1.5 Y-1.5
      G1 X-1 Y-1
      G1 X-0.5 Y-0.5
      G1 X0 Y0
      G1 X0.5 Y0.5
      G1 X1 Y1
      G1 X1.5 Y1.5
      G1 X2 Y2
      G1 X2.5 Y2.5
      G1 X3 Y3
      G1 X3.5 Y3.5
      G1 X4 Y4
      G1 X4.5 Y4.5
      G1 X5 Y5
      G1 X5.5 Y5.5
      G1 X6 Y6
      G1 X6.5 Y6.5
      G1 X7 Y7
      G1 X7.5 Y7.5
      G1 X8 Y8
      G1 X8.5 Y8.5
      G1 X9 Y9
      G1 X9.5 Y9.5
      G1 X10 Y10
      G1 X10.5 Y10.5
      G1 X11 Y11
      G1 X11.5 Y11.5
      G1 X12 Y12
      G1 X12.5 Y12.5
      G1 X13 Y13
      G1 X13.5 Y13.5
      G1 X14 Y14
      G1 X14.5 Y14.5
      G1 X15 Y15
      G1 X15.5 Y15.5
      G1 X16 Y16
      G1 X16.5 Y16.5
      G1 X17 Y17
      G1 X17.5 Y17.5
      G1 X18 Y18
      G1 X18.5 Y18.5
      G1 X19 Y19
      G1 X19.5 Y19.5
      G1 X20 Y20
      G1 X20.5 Y20.5
      G1 X21 Y21
      G1 X21.5 Y21.5
      G1 X22 Y22
      G1 X22.5 Y22.5
      G1 X23 Y23
      G1 X23.5 Y23.5
      G1 X24 Y24
      G1 X24.5 Y24.5
      G1 X25 Y25
      G1 X25.5 Y25.5
      G1 X26 Y26
      G1 X26.5 Y26.5
      G1 X27 Y27
      G1 X27.5 Y27.5
      G1 X28 Y28
      G1 X28.5 Y28.5
      G1 X29 Y29
      G1 X29.5 Y29.5
      G1 X30 Y30
      G1 X30.5 Y30.5
      G1 X31 Y31
      G1 X31.5 Y31.5
      G1 X32 Y32
      G1 X32.5 Y32.5
      G1 X33 Y33
      G1 X33.5 Y33.5
      G1 X34 Y34
      G1 X34.5 Y34.5
      G1 X35 Y35
      G1 X35.5 Y35.5
      G1 X36 Y36
      G1 X36.5 Y36.5
      G1 X37 Y37
      G1 X37.5 Y37.5
      G1 X38 Y38
      G1 X38.5 Y38.5
      G1 X39 Y39
      G1 X39.5 Y39.5
      G1 X40 Y40
      G1 X40.5 Y40.5
      G1 X41 Y41
      G1 X41.5 Y41.5
      G1 X42 Y42
      G1 X42.5 Y42.5
      G1 X43 Y43
      G1 X43.5 Y43.5
      G1 X44 Y44
      G1 X44.5 Y44.5
      G1 X45 Y45
      G1 X45.5 Y45.5
      G1 X46 Y46
      G1 X46.5 Y46.5
      G1 X47 Y47
      G1 X47.5 Y47.5
      G1 X48 Y48
      G1 X48.5 Y48.5
      G1 X49 Y49
      G1 X49.5 Y49.5
      G1 X-50 Y-50
      Update: also click frequency directly depends on frequency of g-codes, seems like this clicks going between g-code commands. Maybe something like fill of next command queue or read-ahead of g-codes freezing movements?
      Example of low-frequency clicks with longer segments:
      [[language]]
      T0
      G1 X-50 Y-50 Z10.300 F4800.000
      G1 X-50 Y-50 F960
      G1 X-45 Y-45
      G1 X-40 Y-40
      G1 X-35 Y-35
      G1 X-30 Y-30
      G1 X-25 Y-25
      G1 X-20 Y-20
      G1 X-15 Y-15
      G1 X-10 Y-10
      G1 X-5 Y-5
      G1 X0 Y0
      G1 X5 Y5
      G1 X10 Y10
      G1 X15 Y15
      G1 X20 Y20
      G1 X25 Y25
      G1 X30 Y30
      G1 X35 Y35
      G1 X40 Y40
      G1 X45 Y45
      Now I'm sure that this clicks are result of a lot of g-code fragments. David, I think that something wrong.
      • roboduetundefined
        roboduet
        @dc42:
        Thanks for your example. My printers are out of action until my office refurbishment is complete, but I'll try it out when I can. Feel free to remind me on Wednesday if you don't get a response before then.
        David, did you have time to check this? It seems to me that RRF produces very small pauses after each g-code, this pauses causes jerky moves. Even linear (straight?) movement of effector on my delta produces this pauses. You can view example g-codes in my previous post. But 1-line (w/o segments) g-code does not produce this pauses.
        Now I can hear this pauses almost in every print with smooth curved movements 🙂
        • botundefined
          bot
          I think if I listen very carefully to my delta running a 0.8.5 I can hear similar sounds. Can you post photos of the surface defects it creates on the sides of the print? I'm sorry if you posted this already and I missed it.
          *not actually a robot
          • roboduetundefined
            roboduet
            @bot:
            I said earlier that I'm unable to take macro photos of differences with acceptable quality of photo. I will try later with another plastic colors and right light. UPD: this defects looks like vertical columns of very small plastic blobs on surface of printed part.
            Also I said before that print quality isn't a problem for me, I'm happy Duet WiFi owner, but I still think that something is wrong here with g-code processing or something another.
            That's why I'm trying to draw David's attention to this problem. But seems like he is very busy in the last month and haven't time to check this.
            • botundefined
              bot
              Okay, no worries. I just figured since I checked the other day and noticed a faint sound that is similar to yours, and with the same consistency, that I'd let you know. I don't notice any print defects at all that I can attribute to this noise, however.
                I am sorry, it is still on my list to investigate.
                  I finally got round to testing this. I can hear and feel clicks on my deltas but they are very faint, perhaps because my printer has 0.9deg motors.
                  At this stage I can think of two possible explanations:
                  1. At the boundaries between segments, the motor positions each have to be rounded to the nearest microstep. Interpolation doesn't help here. The clicks may just be the result of this rounding.
                  2. Or there could be a problem with the precise time interval between the start of the old move and the start of the new move. Currently, the new move starts as soon as the old move has taken its last step; but the first step of the new move won't happen until it is due.
                  I will investigate further.
                  • roboduetundefined
                    roboduet
                    Thank you, David!
                    Also I noticed that in 1/256 microstepping mode this clicks not audible nor feeling. Maybe this can help to investigate.
                    • roboduetundefined
                      roboduet
                      Hello, David. Do you have any news? Maybe I can help you testing/debugging this issue?
                        My best guess is that the clicks are due to the boundaries between segments having to be rounded to the nearest microstep for each motors. That would explain why reduces or goes away at higher microstepping. But I have it on my list to check the pulse time with an oscilloscope, to make sure that each move is starting at the correct time and is not early or late.
                        • roboduetundefined
                          roboduet
                          Seems like beta boards does not have pins for step signals for onboard drivers or I just overlooked something.
                          I remapped drivers to expansion header pins (M584 X6 Y5 Z8) and connected logic analyzer to this pins.
                          Then I manually pressed homing switches during homing to cheat homing procedure and printer "homed" correctly. Then I captured X/Y/Z step signals during g-code printing with segmented straight movement with this clicks.
                          I see pauses in step signal generation but I can not interpret this information correctly.
                          If you wish I can upload logic analyzer dump file. I'm using Seleae Logic software, it's free to download. Also I can export data in other formats.
                          • botundefined
                            bot
                            Would it be possible to take screenshots of the output of the software and post the results here? Thanks, roboduet, for being persistent and proactive about what you feel is an underlying issue. This may turn out to be a very useful avenue of exploration, even if to simply determine that this behaviour is unavoidable.
                            • roboduetundefined
                              roboduet
                              Yes, I can post images. I also want to say again that I do not fully understand what happens and who is responsible for this (logic analyzer hardware, usb bus, software or Duet itself).
                              Pauses are selected with marker (blue icons). X channel is first from top, Y is second, Z is third (bottom).
                              @bot - thanks for your support 🙂
                                Thanks for posting those traces.
                                I see that each pause is less than twice the normal pulse interval for that motor, and the pauses do not occur on all motors at the same point. Also there is sometimes a reduction in the interval between pulses instead of a pause.
                                I think this confirms my suspicion that the pauses are caused by the need to round each motor position to the nearest microstep at the junction between each pair of segments. Such rounding is unavoidable. Increasing the microstepping is the only real cure I can think of.
                                Whereas all other delta printer firmwares chop moves into short segments, RRF doesn't except when grid bed compensation is enabled, and even then the segments are quite long (about as long as the grid spacing). So this should be much less of an issue with RRF than with other firmwares.
                                btw you can use M584 to map each motor to more than one driver, allowing you to use the internal drivers as well as putting the pulses on the expansion connector.
                                • roboduetundefined
                                  roboduet
                                  Yet another two examples. I just created g-code with 50 millisecond segments (F1200, 1mm movements), so pauses (or step signals with shorter interval) going exactly every 50 ms, easy to find in analyzer logs:
                                  All three motors paused at 7.420+ s position
                                  Pause for X step, premature step for Y and Z at 7.520+ s position
                                  Pause for X and Y, premature step for Z at 7.670+ s position, also steps are skewed at 7.770+ s position
