    manual bed levelling and using multiple independent Z motors ?
    • pipersw
      pipersw last edited by
      I have a Anet A8 cartesian printer, with two Z motor, each on independent driver (Z and E1).
      which is the better : manual bed levelling assistant or Bed levelling using multiple independent Z motors ?
      It's possible to combine the two method ?
      • Veti
        Veti last edited by
        Bed levelling using multiple independent Z is for adjusting the 2 z axis because they can become out of sync.
        mesh bed leveling is for correction of uneven print surfaces.
        normally you would do both.
        • pipersw
          @veti said in manual bed levelling and using multiple independent Z motors ?:
          mesh bed leveling
          I'm not speak about mesh bed leveling, but manual bed levelling, for level the bed with the four srew at each corner.
          • Veti
            Veti last edited by
            on the anet a8 you will still need to do corner leveling now and then because the springs and y gantry quality is severely lacking. the independant z leveling can only correct it for the x plane and not the y plane.
