    Pressure advance question
    • Alexander Mundy
      Alexander Mundy last edited by
      Can pressure advance (M572) be set on the fly during printing?
        Yes. Just be careful not to set it too high without also reducing retraction.
        • Alexander Mundy
          Thanks, going to make a calibration test object then insert M572 lines with incremental increasing value. Thinking of a single wall inverted cone with a 2 layer sawtooth pattern increasing in width cut out of it starting about 5 layers up and increasing pressure advance slightly at each new sawtooth ledge. Is there a direct inverse correlation for retract I should also use, or will that be another variable permutation to be set, or would it be best to not do retraction across the gaps?
            The reason I warn about retraction is that when you use a large amount of pressure advance, the firmware will start retracting before the end of a printing move that slows to a low speed at the end. When this is followed by a slicer-commanded retraction prior to a travel move, this can result in too much totaL retraction for all-metal hot ends, causing a jam. But if you don't reach this point, then I don't think you need to treat retraction as another variable in your tests.
