    Gcode files: asterisked out, constantly loading, can't print.
    • archindividual
      archindividual last edited by
      Printed successfully, attempted to upload another file, it uploads and I hit OK, then the gcodes directory comes back looking like this -
      http://i.imgur.com/Vx0cNL7.jpg
      Tried m999, tried powering off for several minutes, tried reseating the sd card with power off, tried reinstalling the main firmware.
      I can still upload files (Which do the same thing and can't be deleted.) and create new directories (Which I can delete.)
      If I mouse over the gcode directory piece of the page my mouse cursor switches over to a busy spinner.
      So I guess my question is "What the heck?!?!"
      • deckingman
        deckingman last edited by
        I could be wrong but seem to recall I had something similar a while back which turned out to be a dodgy file name. Maybe it's the apostrophe that DWC doesn't like? In my case, renaming the files fixed the problem but it was a long time ago so I can't be sure that my issue was the same as yours.
        • archindividual
          @deckingman:
          Would that cause the problem for the whole directory?
          "testcube_20mm.gcode" is doing the same thing.
          If so, do I need to put the SD card into a reader and manually delete?
          EDIT: HAHA! You fixed it! Thanks so much!
            I'm glad you solved it. Which Duet firmware and DWC versions are you running? I believe that bug was fixed recently.
