    Can't change current for new stepper
    1.6k
    • PuterProundefined
      PuterPro
      Thx. Do it later today and report back.
      • PuterProundefined
        PuterPro @dc42
        @dc42 said in Can't change current for new stepper:
        Yes. 2.02 release and DWC 1.22.6 are current
        Updated.
        (because I normally run DWC 2.0, which has no Machine Properties page)
        I misread that.
        So Machine Properties is depreciated?
        (I found it switching to the old interface after upgrade and the current listed was still wrong).
        If it's depreciated I wouldn't have made a discussion of it, I'm not much for beating dead horses!!
        Thanks! Sorry if it was a time suck I'd never do that to you of all people! Still have a stepper currents Q but I'll separate post it.
          I'm not sure that the Machine Properties page is deprecated, it may just be that chrishamm hasn't implemented it yet in DWC2. In particular, the facility to see the endstop states is useful.
          • Florentundefined
            Florent
            For my part.
            If I do not display the current values in the web page, there is a problem with the configuration.
            For engines that the value does not change, I redo a configuration in another location (in the config.g), I think there are conflicts following the instructions that are used later.
            In my case, I had a problem with extruders on the DUEX5, which remained at 0mA, while on the DUET the command worked.
            Putting this line further in the code corrected the problem.
            M906 E800:800 ; Set motor currents (mA);pour test>> necessaire sinon pas de courant du tout
